Part Number: 19216
Portable Cordage, (4) 12 AWG (65x30) BC, EPDM/Rubber, Type SO
Product Description
Two 12 AWG stranded (65x30) bare copper conductors, EPDM insulation, rubber jacket.
Technical Specifications
Physical Characteristics (Overall)
Conductor
AWG Stranding
12
65x30
Material
No. of Conductors
BC - Bare Copper 4
Conductor Count:
4
AWG Size:
12
Insulation
Material
Nominal Wall Thickness
EPDM - Ethylene Propylene Diene Monomer Rubber 0.052 in
Color Chart
Color
Black
White
Green
Red
Outer Shield Material
Material
Unshielded
Outer Jacket Material
Material Nominal Diameter Nominal Wall Thickness Separator Material
Rubber
0.69 in
0.102 in
Paper Tape
Construction and Dimensions
Type of Cordage:
SO
Stranding
Lay Length
Black mm
Cabling
Filler
Jute
Electrical Characteristics
Current
Max. Recommended Current [A]
20 Amps per conductor @ 25°C; 15 Amps per conductor @ 25°C over 50 ft
15 Amps per conductor @ 25°C over 50 ft.
Voltage
Dielectric Withstand Voltage UL Voltage Rating
3000 V AC Applied for 1 Min.
600V RMS
Electrical Characteristics Notes:
Dielectric Withstand Voltage: 3000 V AC Applied for 1 Min
Temperature Range
UL Temp Rating:
90°C
Mechanical Characteristics
Oil Resistance:
Yes
Bulk Cable Weight:
284 lbs/1000ft
Min Bend Radius/Minor Axis:
7 in
Standards
NEC/(UL) Specification:
SO
CSA AWM Specification:
SO
Applicable Environmental and Other Programs
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2003/96/EC (BFR):
Yes
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2012/19/EU (WEEE):
Yes
EU Directive Compliance:
EU Directive 2003/11/EC (BFR)
EU CE Mark:
Yes
EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flammability, LS0H, Toxicity Testing
CSA Flammability:
FT2
Part Number
Plenum (Y/N):
No
Variants
Item #
Color
Footnote
19216 010200 BLACK C
Footnote:
C - CRATE REEL PUT-UP.
© 2018 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's
inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product
itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
很抱歉,暂时无法提供与“19216 010200”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+247.43355200+31.02865
