2202ENH.00500
2202ENH.00500
    BELDEN
    BELDEN - 2202ENH.00500 - CATEGORY 6A, 4P, S/FTP SHIELDED, CABLE
2202ENH.00500 数据手册
Product: 2202ENH Cat 6A Cable, S/FTP, LSZH, 4 Pair, AWG 23, Indoor CPR Eca Product Description Category 6A (500MHz), 4-Pair, S/FTP shielded, Premise Horizontal Cable, 23 AWG Solid Bare Copper conductors, Foam Polyolefin insulation, each pair with Beldfoil® shield, tinned copper braid shield (30%), LSZH jacket, CPR Euroclass Eca Technical Specifications Product Overview Suitable Applications: Horizontal and building backbone cable; Support current and future Category 6A and 6 applications, such as: 10GBase-T (10 Gigabit Ethernet), 1000Base-T (Gigabit Ethernet), 100 Base-T, 10 Base-T, FDDI, ATM Patent: This product has one or more applicable patents. More information on patents can be found at https://www.belden.com/resources/patents. Physical Characteristics (Overall) Conductor AWG Stranding 23 Solid Material No. of Pairs BC - Bare Copper 4 Conductor Count: 8 Total Number of Pairs: 4 Insulation Type Material Nominal Diameter Dielectric PO - Polyolefin (Foam) 1.32 mm Bonded-Pair: No Color Chart Number Color Pair 1 White & Blue Pair 2 White & Orange Pair 3 White & Green Pair 4 White & Brown Inner Shield Material Type Material Coverage [%] Tape Bi-Laminate (Alum+Poly) 100% Table Notes: Aluminum facing outside Outer Shield Material Type Material Min. Coverage [%] Braid Tinned Copper (TC) 30% Outer Jacket Material Material Nominal Diameter Diameter +/- Tolerance Ripcord LSZH - Low Smoke Zero Halogen (Flame Retardant) 7.0 mm Construction and Dimensions Min Elongation at Breakof Conductors: 10 % 0.3 mm Yes Min Elongation at Breakof Insulation: 100 % Min Elongation at Breakof Jacket: 100 % Min Tensile Strength of Jacket: 9 MPa Electrical Characteristics Conductor DCR Max. Conductor DCR Max DCR Unbalanced Between Pairs [%] Max. DCR Unbalanced Within Pair [%] 95 Ohm/km 4% 2% Capacitance Max. Capacitance Unbalance Max. Mutual Capacitance 1,600 pF/km 56 pF/m Impedance Nominal Characteristic Impedance 100 Ohm Delay Max. Delay Skew 45 ns/100m High Freq Frequency [MHz] Min. NEXT [dB] Max. Insertion Loss (Attenuation) Min. PSNEXT [dB] Min. ACR [dB] Min. PSACR [dB] Min. ACRF (ELFEXT) [dB] Min. RL (Return Loss) [dB] Min. PSACRF (PSELFEXT) [dB] Min. PSANEXT Min. PSAACRF Min. Min. TCL [dB] ELTCTL [dB] 1 MHz 2.1 dB/100m 75.3 dB 72.3 dB 73.2 dB 70.2 dB 68 dB 65 dB 20 dB 67 dB 67 dB 40 dB 35 dB 4 MHz 3.8 dB/100m 66.3 dB 63.3 dB 62.5 dB 59.5 dB 56 dB 53 dB 23 dB 67 dB 66.2 dB 34 dB 23 dB 10 MHz 5.9 dB/100m 60.3 dB 57.3 dB 54.4 dB 51.4 dB 48 dB 45 dB 25 dB 67 dB 58.2 dB 30 dB 15 dB 16 MHz 7.5 dB/100m 57.2 dB 54.2 dB 49.8 dB 46.8 dB 43.9 dB 40.9 dB 25 dB 67 dB 54.1 dB 28 dB 10.9 dB 31.2 MHz 10.5 dB/100m 52.9 dB 49.9 dB 42.4 dB 39.4 dB 38.1 dB 35.1 dB 23.6 dB 67 dB 48.3 dB 25.1 dB 5.1 dB 62.5 MHz 15 dB/100m 48.4 dB 45.4 dB 33.4 dB 30.4 dB 32.1 dB 29.1 dB 21.5 dB 65.6 dB 42.3 dB 22 dB 100 MHz 19.1 dB/100m 45.3 dB 42.3 dB 26.2 dB 23.2 dB 28 dB 25 dB 20.1 dB 62.5 dB 38.2 dB 20 dB 125 MHz 21.5 dB/100m 43.8 dB 40.8 dB 22.3 dB 19.3 dB 26.1 dB 23.1 dB 19.4 dB 61 dB 36.3 dB 19 dB 200 MHz 27.6 dB/100m 40.8 dB 37.8 dB 13.2 dB 10.2 dB 22 dB 19 dB 18 dB 58 dB 32.2 dB 17 dB 250 MHz 31.1 dB/100m 39.3 dB 36.3 dB 8.3 dB 5.3 dB 20 dB 17 dB 17.3 dB 56.5 dB 30.2 dB 16 dB 300 MHz 34.3 dB/100m 38.1 dB 35.1 dB 3.9 dB 0.9 dB 18.5 dB 15.5 dB 17.3 dB 55.3 dB 28.7 dB 500 MHz 45.3 dB/100m 34.8 dB 31.8 dB -10.4 dB -13.4 dB 14 dB 11 dB 17.3 dB 52 dB 24.2 dB Table Notes: Limits below 4 MHz are for information only. Reference standard: IEC 61156-5 General Electrical Parameters Notes: Reference standard: ISO/IEC 61156-5 Coupling Attenuation Class: Type Ib Segregation class according EN50174-2: d Transfer Impedance Frequency [MHz] Description Transfer Impedance 1 Mhz Grade 2 Max. 50 mOhm/m 10 Mhz Max. 100 mOhm/m 30 Mhz Max. 200 mOhm/m 100 Mhz Max. 1000 mOhm/m Transfer Impedance Class: Grade 2 Current Max. Recommended Current [A] 1.5 Amps per Conductor Voltage Voltage Rating [V] 72 V Temperature Range Installation Temp Range: 0°C To +50°C Operating Temp Range: -30°C To +60°C Mechanical Characteristics Bulk Cable Weight: 52 kg/km Max. Pull Tension: 85 N Min Bend Radius During Installation: 58 mm Min Bend Radius During Operation: 29 mm Standards IEC Compliance: ISO/IEC 11801-1 CPR Euroclass: Eca CENELEC Compliance: EN 50173-1 Data Category: Category 6A ANSI Compliance: ANSI/TIA 568.2-D (2018) IEEE Compliance: PoE: IEEE 802.3bt Type 1, Type 2, Type 3, Type 4 Applicable Environmental and Other Programs Environmental Space: Indoor - Euroclass Eca EU RoHS Compliance Date (yyyy-mm-dd): 2018-01-03 Flammability, LS0H, Toxicity Testing IEC Flammability: IEC 60332-1-2 Burning Load: 500 kJ/m IEC 60754-1 (EN50267-1)- Halogen Amount: Zero IEC 60754-2 (EN50267-2)- Halogen Acid Gas Amount Max. Conductivity: 2.5 µS/mm IEC 60754-2 (EN50267-2)- Halogen Acid Gas Amount Min. pH: 4.3 IEC 61034-2 (EN 61034-2) (VDE 0482-1034) - Smoke Density Min. Transmittance: 60% Part Number Variants Item # Color Putup Type Length 2202ENH.00500 Blue Reel 500 m EAN 8719605159236 Product Notes Notes: Electrical values are expected performance based on cable testing and representative performance within a typical Belden system. History Update and Revision: Revision Number: 0.93 Revision Date: 02-17-2021 © 2021 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
2202ENH.00500 价格&库存
很抱歉,暂时无法提供与“2202ENH.00500”相匹配的价格&库存,您可以联系我们找货
