38212 0105000
38212 0105000
    BELDEN
    HOOK-UP STR 12AWG XLPE
38212 0105000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 38212 Hook-up/Lead - UL Type PV Wire For more Information please call 1-800-Belden1 General Description: 12 AWG stranded (65x30) tinned copper conductors, XLPE insulation, non-integrally PVC jacketed, sunlight resistant, photovoltaic wire. Usage (Overall) Suitable Applications: Interconnection wiring of grounded and ungrounded photovoltaic power systems as described in Section 690.31(A) of the 2008 NEC. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 12 65x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) XLPE - Cross Linked Polyethylene 0.048 Separator Separator Material over Conductor: Y Jacket Jacket Material: PVC - Polyvinyl Chloride Jacket Thickness: .033 Overall Cable Overall Nominal Diameter: 0.255 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +90°C UL Temperature Rating: 90°C Wet/Dry Bulk Cable Weight: 44 lbs/1000 ft. Max. Recommended Pulling Tension: 84.500 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 600V, 90C UL Type: PV, USE-2, RHW-2 EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 09/01/2009 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 38212 Hook-up/Lead - UL Type PV Wire Suitability Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.500 Max. Operating Voltage - UL: Voltage 600 V RMS Max. Recommended Current: Description Current Single conductor in free air @ 30 ambient 40 amps Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 38212 0105000 5,000 FT 235.000 LB BLACK C #12 XLPE PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 09-24-2010 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 01-05-2017
38212 0105000 价格&库存
很抱歉,暂时无法提供与“38212 0105000”相匹配的价格&库存,您可以联系我们找货
