4300FE.00100
4300FE.00100
    BELDEN
    BELDEN - 4300FE.00100 - Multicore Cable, Security Alarm, Screened, 2 Core, 18 AWG, 0.823 mm², 328 ft...
4300FE.00100 数据手册
TECHNICAL DATA SHEET concept 4300FE NON-PAIRED code version 1 date 2004-04-20 page 1/2 APPLICATION Commercial applications shielded CONSTRUCTION 1. 2. 3. 4. 4. Conductor Diameter of conductor Material 1.22mm (AWG18) stranded bare copper (7xAWG26) Insulation Material Diameter over insulation Wallthickness PE 1.72 ± 0.05 mm 0.25 mm Overall Cabling Colour code Outer shield Shield Shield Material Shield Thickness Alu Shield coverage Drainwire black – red Beldfoil®) Aluminium / Polyester tape 9 µm 100% AWG20 (7xAWG28) tinned Cu Sheath Material Colour Nominal thickness of sheath Diameter over sheath FRNC Grey 0.38 mm 4.2 ± 0.30 mm REQUIREMENTS AND TEST METHODS Electrical: Nominal resistance conductor Nominal resistance shield Nom. capacitance conductor to conductor @ 1kHz Nom. capacitance cond. to shield + other cond. @ 1kHz Testvoltage conductor-conductor Testvoltage conductor-screen Voltage rating Maximum continues current per conductor @ 25 °C 21.3 Ω/km 23.6 Ω/km 125 pF/m 224 pF/m 2500 VDC, 3 seconds 2500 VDC, 3 seconds 300 V RMS 3.5 A per conductor @ 25 ˚C © Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner TECHNICAL DATA SHEET concept 4300FE NON-PAIRED Mechanical and physical: Temperature range processing and operating Temperature range storage Minimum bending/setting radius Maximum pulling tension Halogen free according to Non dense smoke according to Non corrosive gas according to Flame Retardant according to code version 1 date 2004-04-20 page 2/2 -20 to +70 ˚C -30 to +70 ˚C 5*D/10*D 26 N IEC 60754-1 IEC 61034-1 and 61034-2 IEC 60754-2 IEC 60332-1 MARKING NEW GENERATION(R) BY BELDEN 4300FE HALOGEN FREE 70C 2C18 SHIELDED + sequential meter marking. © Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner
4300FE.00100 价格&库存
很抱歉,暂时无法提供与“4300FE.00100”相匹配的价格&库存,您可以联系我们找货
4300FE.00100
  • 1+1858.10971
库存:2300
