43776.
43776.
    BELDEN
    BELDEN - 43776. - Sensor Cable, M12 Plug, 90° M12 Receptacle, 4 Positions, 2 m, 6.6 ft
43776. 数据手册
M12-Round-Plug Connector, Double-Ended Cordsets, According to IEC 61076-2-101 RST-RKT 3-, 4-, 5-, and 8-Poles RST -RKT | RST-RKWT Actuator/sensor cordset, double-ended, M12, 3-, 4-, 5-, and 8-poles, male straight to female straight connector with self-locking thread and molded cable, IEC color code. Actuator/sensor cordset, double-ended, M12, 3-, 4-, 5-, and 8-poles, male straight to female 90° connector with self-locking thread and molded cable, IEC color code. RST-RKWT Pin Assignments M12 - Male 3 poles 4 poles 1= 2 = 3= 4= 150 brown n.c. blue black 5 poles 1= 2= 3 = 4= brown white blue black 6 poles 1= 2= 3 = 4= 5 = brown white blue black green/yellow 1-717-217-2299 8 poles 1= 2= 3 = 4= 5 = 6 = 7 = 8= white green yellow grey brown n.c. blue n.c. 1= 2= 3 = 4= 5 = 6 = 7 = 8= white brown green yellow grey pink blue shield www.lumberg-automationusa.com Cordsets Double-Ended Be Certain with Belden M12-Round-Plug Connector, Double-Ended Cordsets, According to IEC 61076-2-101 RST-RKT | RST-RKWT Technical Data Environmental Degree of protection Operating temperature range Cable Specifications IP 67 / NEMA 6P -25°C (-13°F) / +80°C (+176°F) TPU TPU RST: CuSn, pre-nickeled and 0.8 microns gold-plated RKT / RKWT: CuSn, pre-nickeled and 0.3 microns gold-plated CuZn, nickel-plated FKM (only RKT / RKWT) Electrical Contact resistance Nominal current at 40°C Nominal voltage Rated voltage Test voltage Insulation resistance Pollution degree ≤ 5 mΩ 3–5 poles 4 A 6-8 poles 2 A 3–4 poles 240 V 5 poles 60 V, 6-8 poles 30 V 3–4 poles 250 V 5 poles 63 V, 6-8 poles 36 V 3–4 poles 2.0 kV eff. / 60 s 5–8 poles 1.5 kV eff. / 60 s > 109 Ω 3 Part Number Pins Conductor Size Jacket Color OD 224 PUR, halogen-free 3 x 0.34 mm2 Black .169” (4.3 mm) 225 PUR, halogen-free 4 x 0.34 mm2 Black .185” (4.7 mm) 228 PUR, halogen-free 5 x 0.50 mm2 Black .213” (5.4 mm) 251 PUR, halogen-free 4 x 0.34 mm2 welding spark proof Orange .185” (4.7 mm) 259 PUR, halogen-free 5 x 0.50 mm2 welding spark proof Orange .217” (5.5 mm) 268 PUR, halogen-free 6 x 0.34 mm2 welding spark proof Orange .236” (6.0 mm) 282 PUR, halogen-free 7 x 0.25 mm2 Black .236” (6.0 mm) 337 PUR, halogen-free 6 x 0.34 mm2 Black .236” (6.0 mm) Outer Jacket Standard Cable Lengths RST 3-RKT 4-3-224/...M RST 3-RKWT 4-3-224/...M 3 PUR, halogen-free 0.3 M / 0.6 M / 1 M / 1.5 M / 2 M / 5 M RST 4-RKT 4-225/...M RST 4-RKWT 4-225/...M 4 PUR, halogen-free 0.3 M / 0.6 M / 1 M / 1.5 M / 2 M / 5 M 0.3 M / 0.6 M / 1 M / 1.5 M / 2 M / 5 M 5 PUR, halogen-free, weld spark proof PUR, halogen-free PUR, halogen-free, weld spark proof PUR, halogen-free, weld spark proof PUR, halogen-free 0.3 M / 0.6 M / 1 M / 1.5 M / 2 M / 5 M PUR, halogen-free 0.3 M / 0.6 M / 1 M / 1.5 M / 2 M / 5 M RST 4-RKT 4-251/...M RST 5-RKT 5-228/...M RST 5-RKT 5-259/...M RST 8-RKT 8-6-268/...M RST 8-RKWT 8-6-268/...M RST 8-RKT 8-6-337/...M RST 8-RKWT 8-6-337/...M RST 8-RKT 8-282/...M RST 8-RKWT 8-282/...M www.lumberg-automationusa.com 6 8 1-717-217-2299 Characteristics 0.3 M / 0.6 M / 1 M / 1.5 M / 2 M / 5 M 2 M / 5 M / 10 M 2 M / 5 M / 10 M 151 Cordsets Double-Ended Mechanical Housing / Molded body Insert Contact Coupling nut O-ring Cable No. Outer Jacket
43776. 价格&库存
很抱歉,暂时无法提供与“43776.”相匹配的价格&库存,您可以联系我们找货
