49911A 010S2
49911A 010S2
    BELDEN
    CABLE ASSY DB09 SHLD BLK 457.2MM
49911A 010S2 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 49911A Molded Cable Assemblies - D-Subminiature Assembly For more Information please call 1-800-Belden1 General Description: 9-position shielded D-Sub retractile, for keyboard-to-CRT use where 9-pin retractile is desired, male straight handle one end, polypropylene insulation, polyurethane jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material Dia. (in.) 9 26 19x38 TC - Tinned Copper .021 Total Number of Conductors: 9 Number of Pins: 9 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PP - Polypropylene 0.006 Connector Characteristics Connector Characteristic (not terminated) Drain Wire Solder Dip: .25 +/- .125 Connector Characteristics (not Terminated) Jacket Removal Dimension: 1 +/-.125 Connector Characteristics - First End # of Connector Contacts/positions: 9 Connector Characteristics - First End Connector Gender: Male Connector Characteristics - First End Connector Shielding Type: Metal Backshell Connector Characteristics - First End Connector Type: D-Sub Connector Characteristics - First End Overmold Color: Black Connector Characteristics - First End Overmold Compound Material: PVC Connector Characteristics - First End Overmold Type: 9 Position D-Sub Connector Characteristics - First End Retention Hardware: Thumbscrew Connector Characteristics - Second End Connector Type: No Connector Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 20 42x36 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PUR - Polyurethane 0.065 Overall Cable Overall Nominal Diameter: 0.250 in. Assembly Dimensional Assembly Dimensional For Retractile Coil Body Length (extended): 90 Assembly Dimensional for Retractile Coil Body Length (relaxed): 18 +/- 1 Tail Length 1st End Tail Length: 6 +/- 2 Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 49911A Molded Cable Assemblies - D-Subminiature Assembly 2nd End Tail Length: 18 +/- 1.5 Wiring Wiring Diagram Color Code Chart: Number Color 1 Brown 2 Red 3 Orange 4 Yellow 5 Green 6 Blue 7 Purple 8 Gray 9 White Mechanical Characteristics (Overall) UL Temperature Rating: 60°C (UL AWM Style 20197) Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs AWM Specification: UL Style 20197 (30 V 60°C) (cable only) EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Max. Operating Voltage - UL: Voltage 30 V RMS (UL AWM Style 20197) Notes (Overall) Notes: Polyurethane jacket provides superior retractile properties at a reasonable cost. Molded handles are 100% shielded to assist in FCC compliance and guard against EMI/RFI. All connectors tin-plated with detents for positive ground connection. Notes (Cont'd.): The end opposite the conductor is stripped. Jack screw retention on male connector. Put Ups and Colors: Item # Putup Ship Weight Color 49911A 010S2 1 EA 14.050 LB BLACK Revision Number: 1 Notes Item Desc RETR ASSY 9POS RI37966 Revision Date: 09-19-2008 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 01-05-2017
49911A 010S2 价格&库存
很抱歉,暂时无法提供与“49911A 010S2”相匹配的价格&库存,您可以联系我们找货
