73805W 0081000
73805W 0081000
    BELDEN
    5 芯 多芯 线缆 灰色 18AWG 1000.0'(304.8m)
73805W 0081000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 73805W Multi-Conductor - 600V Unshielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (16x30) bare copper conductors, PVC insulation, oil-resistant PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 4 18 16x30 BC - Bare Copper Total Number of Conductors: 5 Ground Wire Ground Wire (Y/N): Y Ground Wire AWG: 18 Ground Wire Stranding: 16x30 Ground Wire Conductor Material: BC - Bare Copper Ground Wire Insulation Material: PVC - Polyvinyl Chloride Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride 0.022 Insulation Color Code Chart: Color Description Black Individually Numbered Yellow/Green Ground Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.035 Overall Cable Overall Nominal Diameter: 0.326 in. Mechanical Characteristics (Overall) Storage Temperature Range: -40°C To +90°C Installation Temperature Range: Flexing: -5°C To +90°C Bulk Cable Weight: 132 lbs/1000 ft. Max. Recommended Pulling Tension: 63 lbs. Min. Bend Radius/Minor Axis: 1.600 in. Min. Bend/Installation: 1.600 in. Min. Bend Radius (Continuous Flexing): 1.600 in. Flex Cycle Rating: 1 Million Flexes Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs AWM Specification: UL Style 2587 (600 V 90°C) CSA Specification: 600 V AWM I/II A/B EU Directive 2011/65/EU (ROHS II): Yes MII Order #39 (China RoHS): Yes Other Specification: VDE 0472, Section 803 Oil Test, EU Low Voltage Directive 2014/35/EC, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California Proposition 65 Page 1 of 2 10-02-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 73805W Multi-Conductor - 600V Unshielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles Flame Test CSA Flame Test: FT1 Suitability Suitability - Burial: Yes Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) 0.190 Max. Capacitance Conductor to Conductor: Freq. (MHz) Capacitance (pF/ft) 0.001 31.000 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.700 Max. Operating Voltage - UL: Voltage 600V Put Ups and Colors: Item # Putup Ship Weight Color 73805W 008100 100 FT 16.500 LB GRAY 18AWG 19/30 5C UNSHIELDED 73805W 0081000 1,000 FT 136.000 LB GRAY 18AWG 19/30 5C UNSHIELDED 73805W 008500 500 FT 70.000 LB GRAY 18AWG 19/30 5C UNSHIELDED Revision Number: 0 Notes Item Desc Revision Date: 09-27-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 10-02-2017
73805W 0081000
物料型号:73805W
器件简介:这是一种用于轻到中等弯曲应用的600V未屏蔽多芯电缆,可承受高达100万次的弯曲寿命周期。
引脚分配:共有5个18 AWG的绞合导体,以及一个18 AWG的接地导体,所有导体材料均为裸铜。
参数特性: - 绝缘材料:PVC(聚氯乙烯),壁厚0.022英寸 - 外护套材料:PVC,名义壁厚0.035英寸 - 整体电缆直径:0.326英寸 - 存储温度范围:-40°C至+90°C - 安装温度范围:弯曲时-5°C至+90°C - 电缆重量:132磅/1000英尺 - 最大推荐拉力:63磅 - 最小弯曲半径/次轴:1.600英寸 - 弯曲周期评级:100万次弯曲
功能详解:电缆符合多种标准和环境计划,如UL 2587(600V 90°C)、CSA 600V AWM I/II A/B、欧盟RoHS II指令等。
应用信息:电缆适用于埋地,具有油阻性,适合油测试。
封装信息:电缆有100英尺、1000英尺和500英尺的卷装选项,颜色为灰色。
73805W 0081000 价格&库存
很抱歉,暂时无法提供与“73805W 0081000”相匹配的价格&库存,您可以联系我们找货
