76302WS 008500
76302WS 008500
    BELDEN
    CBL 2COND 22AWG SHLD MACHFLEX
76302WS 008500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 76302WS Multi-Conductor - 300V Foil/Spiral Shield, Continuous Flexing Data Applications Up to 6 Million Flex Life Cycles For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (19x34) tinned copper conductors, PVC insulation, Aluminum/Polyester Foil Shield, Tinned copper spiral shield, 90% coverage, oil-resistant PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 2 22 19x34 TC - Tinned Copper Insulation Insulation Material: Insulation Material Wall Thickness (mm) PVC - Polyvinyl Chloride 0.254 Insulation Color Code Chart: Number Color 1 Black 2 Red Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Tape 2 Serve TC - Tinned Copper Aluminum/Mylar 100.000 90.000 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 1.016 Overall Cable Overall Nominal Diameter: 5.283 mm Mechanical Characteristics (Overall) Bulk Cable Weight: 44.646 Kg/Km Max. Recommended Pulling Tension: 74.285 N Min. Bend Radius/Minor Axis: 43.180 mm Min. Bend/Installation: 43.180 mm Min. Bend Radius (Continuous Flexing): 43.180 mm Flex Cycle Rating: 6 Million Flexes Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes MII Order #39 (China RoHS): Yes Customer Part Number Reference Specification: AWM/STYLE 10002, AWM/STYLE 2661, CSA AWM I/II A/B, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California Proposition 65 Flame Test CSA Flame Test: FT4 Suitability Suitability - Burial: Yes Electrical Characteristics (Overall) Nom. Characteristic Impedance: Description Impedance (Ohm) Characteristic Impedance 45.000 Page 1 of 2 10-02-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 76302WS Multi-Conductor - 300V Foil/Spiral Shield, Continuous Flexing Data Applications Up to 6 Million Flex Life Cycles Nom. Inductance: Inductance (µH/m) 0.558 Nom. Capacitance Conductor to Conductor: Freq. (MHz) Capacitance (pF/m) 0.001 141.083 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 50.199 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 19.030 Max. Operating Voltage - UL: Voltage 300V Notes (Overall) Notes: Temperature Range -10 to 105°C(static), +5 to 105°C (dynamic) Put Ups and Colors: Item # Revision Number: 0 Putup Ship Weight Color Notes Item Desc Revision Date: 09-27-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 10-02-2017
76302WS 008500
物料型号:76302WS 器件简介:22 AWG绞合(19x34)镀锡铜导体,PVC绝缘,铝/聚酯箔屏蔽,镀锡铜螺旋屏蔽,90%覆盖率,耐油PVC护套。
引脚分配:未提供 参数特性: - 导体:22 AWG,绞合(19x34),镀锡铜 - 绝缘:PVC-聚氯乙烯,壁厚0.254mm - 外屏蔽:100%铝/聚酯,90%镀锡铜 - 护套:耐油PVC - 电缆重量:44.646 Kg/Km - 最大推荐拉力:74.285 N - 最小弯曲半径/小轴:43.180 mm - 弯曲寿命:6百万次 - 特性阻抗:未提供 - 电感:0.558 µH/m - 电容:141.083 pF/m(1 MHz) - 导体直流电阻:50.199 Ohm/km(20°C) - 外屏蔽直流电阻:19.030 Ohm/km(20°C) - 最大工作电压:300V 功能详解:适用于连续弯曲数据应用,弯曲寿命高达600万次。
应用信息:适用于需要连续弯曲的数据线应用。
封装信息:耐油PVC护套,整体尺寸和重量符合特定标准。
请注意,以上信息基于PDF文档内容,实际应用时可能需要进一步的工程评估和测试。
76302WS 008500 价格&库存
很抱歉,暂时无法提供与“76302WS 008500”相匹配的价格&库存,您可以联系我们找货
