Detailed Specifications & Technical Data
METRIC MEASUREMENT VERSION
76614TS Multi-Conductor - 300V Shielded, Continuous Flexing Data Applications Up to 6 Million FLex Life Cycles
For more Information
please call
1-800-Belden1
General Description:
24 AWG stranded (10x34) tinned copper conductors, PVC insulation, aluminum/polyester foil shield, tinned
copper braid shield, 85% coverage, oil-resistant overall PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material Dia. (mm)
14
24
10x34
TC - Tinned Copper 0.610
Total Number of Conductors:
28
Insulation
Insulation Material:
Insulation Material
Wall Thickness (mm) Dia. (mm)
PVC - Polyvinyl Chloride 0.254
1.118
Outer Shield
Outer Shield Material:
Type
Outer Shield Material Coverage (%)
Foil Shield Alum/Mylar
100.000
Braid
85.000
Tinned Copper
Outer Shield Drain Wire AWG:
Component AWG Stranding Drain Wire Conductor Material
Drain Wire
26
7x34
TC - Tinned Copper
Outer Shield Separator Material:
Tissue Tape, 25% Overlap, Min.
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (mm)
PVC - Polyvinyl Chloride 1.346
Overall Cable
Overall Nominal Diameter:
11.760 mm
Pair
Pair Color Code Chart:
Number Color
1
BLACK-RED
2
BLACK-WHITE
3
BLACK-GREEN
4
BLACK-BLUE
5
BLACK-BROWN
6
BLACK-YELLOW
7
BLACK-ORANGE
8
RED-GREEN
9
RED-WHITE
10
RED-BLUE
11
RED-YELLOW
12
RED-BROWN
13
RED-ORANGE
14
GREEN-BLUE
Mechanical Characteristics (Overall)
Bulk Cable Weight:
183.049 Kg/Km
Max. Recommended Pulling Tension:
435.924 N
Min. Bend Radius/Minor Axis:
116.840 mm
Min. Bend/Installation:
116.840 mm
Min. Bend Radius (Continuous Flexing):
175.260 mm
Flex Cycle Rating:
6 Million Flexes
Page 1 of 2
10-02-2017
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CM
AWM Specification:
UL Style 20006
CSA Specification:
600 V AWM I/II A/B
EU Directive 2011/65/EU (ROHS II):
Yes
Other Specification:
AWM/STYLE 10002, AWM/STYLE 2661, CM, AWM I/II A/B, C(UL) TYPE CMG, FT4, EU Low Voltage
Directive 2014/35/EC, EU Directive 2011/65/EU(RoHS2)
Flame Test
CSA Flame Test:
FT4
Suitability
Sunlight Resistance:
Yes
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Description
Impedance (Ohm)
Characteristic Impedance 82.000
Nom. Inductance:
Inductance (µH/m)
0.623
Nom. Capacitance Cond. to Other Cond. & Ground:
Description
Freq. (kHz) Capacitance (pF/m)
Mutual Capacitance 1.000
75.791
Ground Capacitance 1.000
137.802
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/km)
98.430
Nominal Outer Shield DC Resistance:
DCR @ 20°C (Ohm/km)
7.382
Notes (Overall)
Notes: Temperature Range -10 to 105°C(static), +5 to 105°C (dynamic)
Put Ups and Colors:
Item #
Revision Number: 0
Putup
Ship Weight
Color
Notes
Item Desc
Revision Date: 09-27-2017
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Page 2 of 2
10-02-2017
很抱歉,暂时无法提供与“76614TS 0081000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+112.306631000+14.57170
