7838A 0601000
7838A 0601000
    BELDEN
    2 FSPR #22 PP/FPE PVCPAR1=1000'
7838A 0601000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7838A Multi-Conductor - T1/DS1 Central Office Interconnect/Cross Connect Cable For more Information please call 1-800-Belden1 General Description: 22 AWG solid tinned copper conductors, twisted pairs, Datalene® insulation, individually shielded with 100% Beldfoil® shield, 24 AWG solid tinned copper drain wire each pair, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 2 22 Solid TC - Tinned Copper .0254 Total Number of Conductors: 4 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® PO w/Foam PO - Polyolefin w/Foam Polyolefin Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Stranding: Solid Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.202 x 0.360 in. Pair Pair Color Code Chart: Number Color 1 Blue & White/Blue 2 Orange & White/Orange Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 33 lbs/1000 ft. Max. Recommended Pulling Tension: 31 lbs. Min. Bend Radius/Minor Axis: 2 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CM EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 Page 1 of 2 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7838A Multi-Conductor - T1/DS1 Central Office Interconnect/Cross Connect Cable EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Description Impedance (Ohm) @ 1 MHz 100.000 Nom. Inductance: Inductance (µH/ft) 0.24 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 14.5 Nominal Velocity of Propagation: VP (%) 72 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 16.7 Nom. Attenuation: Freq. (MHz) Attenuation (dB/1000 ft.) 0.772 4.300 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 3.5 Amps per conductor @ 25°C Differential Impedance @ 1 MHz: 105 Notes (Overall) Notes: Single conductors are dual insulated. The outer layer of insulation must be stripped off before attaching modular connectors. Use a stripping tool such as Cooper Tools Xcelite model 103-S, or equivalent with a mechanical stop to avoid nicking the inner insulation. RJ-45 Compatible. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7838A 0601000 1,000 FT 37.000 LB CHROME C 2 FS PR #22 PP/FPE PVC PARA 7838A 0602000 2,000 FT 74.000 LB CHROME C 2 FS PR #22 PP/FPE PVC PARA 7838A 0605000 5,000 FT 180.000 LB CHROME C 2 FS PR #22 PP/FPE PVC PARA Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 02-23-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 02-27-2017
7838A 0601000 价格&库存
很抱歉,暂时无法提供与“7838A 0601000”相匹配的价格&库存,您可以联系我们找货
