Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
7895A Multi-Conductor - DeviceBus® for ODVA DeviceNet™
For more Information
please call
1-800-Belden1
General Description:
20 and 18 AWG stranded tinned copper conductors, PVC insulation (power), FPE insulation (Data),
individually foil shielded (100% coverage) and an overall tinned copper braid (65% coverage),
sunlight/oil-resistant PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors # Pairs AWG Stranding Conductor Material
4
1
18
19x30
TC - Tinned Copper
1
19x32
TC - Tinned Copper
Insulation
Insulation Material:
Insulation Material
AWG
PVC - Polyvinyl Chloride
18
FPE - Foam Polyethylene 20
Inner Shield
Inner Shield Material:
Layer #
Type Inner Shield Material
Coverage (%)
18 AWG Pair Tape Aluminum Foil-Polyester Tape 100
20 AWG Pair Tape Aluminum Foil-Polyester Tape 100
Inner Shield Drain Wire AWG:
AWG
Inner Shield Drain Wire Stranding:
19x32
Inner Shield Drain Wire Conductor Material:
TC - Tinned Copper
Outer Shield
Outer Shield Material:
Type Outer Shield Material Coverage (%)
Braid TC - Tinned Copper
65
Outer Jacket
Outer Jacket Material:
Overall Cable
Overall Nominal Diameter:
0.378 in.
Pair
Pair Color Code Chart:
Number
Color
18 AWG Pair Red & Black
20 AWG Pair Blue & White
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +75°C
UL Temperature Rating:
75°C (UL AWM Style 20201)
Bulk Cable Weight:
68 lbs/1000 ft.
Max. Recommended Pulling Tension:
65 lbs.
Min. Bend Radius/Minor Axis:
3.800 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
Page 1 of 3
01-05-2017
NEC/(UL) Specification:
CMG, PLTC
CEC/C(UL) Specification:
CMG
AWM Specification:
UL Style 20201 (600 V 75°C)
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Other Specification:
ODVA Cable III
Flame Test
UL Flame Test:
UL1685 FT4 Loading
CSA Flame Test:
FT4
Suitability
Sunlight Resistance:
Yes
Oil Resistance:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Description Impedance (Ohm)
20 AWG Pair 120
Nom. Capacitance Conductor to Conductor:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Capacitance (pF/ft)
20 AWG Pair 1
12.0
Nominal Velocity of Propagation:
Description VP (%)
20 AWG Pair 75
Maximum Delay:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Delay (ns/ft)
20 AWG Pair
1.36
Maximum Conductor DC Resistance:
Description DCR @ 20°C (Ohm/100 m)
18 AWG
6.9
20 AWG
10.9
Nominal Outer Shield DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
3.2
Max. Attenuation:
Description
Freq. (MHz)
.29 20 AWG Pair Only .125
.50
.500
.70
1.000
Max. Operating Voltage - UL:
Voltage
Description
300 V RMS PLTC, CMG
600 V RMS UL AWM
Notes (Overall)
Notes: Mid. Meter marks on jacket to aid users in installation. ODVA DeviceNet is an Open DeviceNet Vendor Association, Inc. trademark.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Page 2 of 3
Item Desc
01-05-2017
7895A T5U1000
1,000 FT
84.000 LB
GRAY T5U
7895A T5U500
500 FT
41.000 LB
GRAY T5U
7895A T5U5000
5,000 FT
440.000 LB
GRAY T5U
C
2#18 PVC, 2#20 FHDPE SH PVC
CZ
Notes:
C = CRATE REEL PUT-UP.
Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN.
Revision Number: 1
Revision Date: 05-14-2007
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“7895A T5U500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+66.95479500+8.64331
- 1000+63.545801000+8.20323
- 1500+61.614721500+7.95395
- 国内价格 香港价格
- 1+226.189741+29.19920
- 50+179.0085250+23.10850
- 100+160.27609100+20.69030
- 152+142.33147152+18.37380
