7876S 000500
7876S 000500
    BELDEN
    2 RG6 DB PLUS + 2 CAT 5E
7876S 000500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7876S Composite - Composite Data, Audio, Video, Security and Control Cabel For more Information please call 1-800-Belden1 General Description: Banana Peel® Composite - (2) Cat 5e 4-bonded-pairs. 24 AWG unshielded plus (2) Series 6 Coax with Duobond Plus® Bonded Tri-shield. Polyolefin Insulation on the pairs; Gas-injected FPE Insulation on the coax, F-R PVC jacket. No overall jacket. Usage (Overall) Suitable Applications: HDTV, DBS, CATV, CCTV, Multimedia, Voice, Video, Data, High Speed Internet, Networked Computing, Distributed Video, Distributed Audio, Security Monitoring, Energy Monitoring Coax Physical Characteristics Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (mm) 2 18 Solid BC - Bare Copper 1.016 Insulation Insulation Material: Insulation Material Dia. (mm) Gas-injected FPE - Foam Polyethylene 4.572 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material Coverage (%) 1 Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100.000 2 Braid AL - Aluminum 75.000 3 Tape Bonded Aluminum Foil-Polyester Tape w/Shorting Fold 100.000 Duobond Plus® Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (mm) 6.985 Applicable Specifications and Agency Compliance Applicable Standards & Environmental Programs Series Type: Series 6 Electrical Characteristics Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/m) 0.318 Nom. Capacitance Conductor to Shield: Page 1 of 5 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7876S Composite - Composite Data, Audio, Video, Security and Control Cabel Capacitance (pF/m) 53.152 Nominal Velocity of Propagation: VP (%) 83.000 Nominal Delay: Delay (ns/m) 4.265 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 20.998 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/km) 15.093 Minimum Structural Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5.000 1000.000 20.000 1000.000 2250.000 15.000 2250.000 3000.000 10.000 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 5.000 1.641 55.000 4.593 211.000 8.531 500.000 13.452 750.000 16.733 862.000 18.046 1000.000 19.686 1450.000 25.592 1800.000 28.217 2250.000 32.154 3000.000 37.075 Max. Attenuation: Freq. (MHz) Attenuation (dB/100m) 5.000 2.198 55.000 5.250 211.000 9.416 500.000 14.699 750.000 18.341 862.000 19.620 1000.000 21.458 1450.000 26.248 1800.000 28.873 2250.000 32.810 3000.000 39.044 Max. Operating Voltage - UL: 350 V RMS Shield Effectiveness: Start Frequency (MHz) Stop Frequency (MHz) Shield Effectiveness (dB) 5.000 50.000 105.000 50.000 1000.000 125.000 Twisted Pair Physical Characteristics Conductor AWG: Page 2 of 5 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7876S Composite - Composite Data, Audio, Video, Security and Control Cabel # Pairs AWG Stranding Conductor Material Dia. (mm) 8 24 Solid BC - Bare Copper 0.508 Insulation Insulation Material: Insulation Material Dia. (mm) PO - Polyolefin 0.889 Twisted Pair Color Code Chart: Number Color 1 White/Blue Stripe and Blue 2 White/Orange Stripe and Orange 3 White/Green Stripe and Green 4 White/Brown Stripe and Brown Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (mm) 5.182 Outer Jacket Ripcord: Yes Electrical Characteristics Nom. Mutual Capacitance: Capacitance (pF/m) 49.215 Nominal Velocity of Propagation: VP (%) 70.000 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.380 Max. Operating Voltage - UL: Voltage 300 V RMS Other Electrical Characteristic 1: Third party verified to TIa/EIA-568-B.2, Category 5e. Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. PSNEXT (dB) Min. PSACR (dB) Min RL (dB) 1.0 2.000 62.3 60 20.000 4.0 4.100 53.3 49 23.000 8.0 5.800 48.8 43 24.500 10.0 6.500 47.3 41 25.000 16.0 8.200 44.3 36 25.000 20.0 9.300 42.8 34 25.000 25.0 10.400 41.3 31 24.300 31.25 11.700 39.9 28 23.600 62.5 17.000 35.4 19 21.500 100 22.000 32.3 11 20.100 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Min. PSELFEXT (dB) 1.0 100 ± 15% 60.8 4.0 100 ± 15% 48.7 8.0 100 ± 15% 42.7 10.0 100 ± 15% 40.8 16.0 100 ± 15% 36.7 20.0 100 ± 15% 34.7 Page 3 of 5 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7876S Composite - Composite Data, Audio, Video, Security and Control Cabel 25.0 100 ± 15% 32.8 31.25 100 ± 15% 30.9 62.5 100 ± 15% 24.8 100 100 ± 15% 20.8 Physical Characteristics (Overall) Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Unjacketed Overall Cable Overall Nominal Diameter: 13.970 mm Mechanical Characteristics (Overall) Operating Temperature Range: -10°C To +75°C Separation Temperature Range: 0°C To +75°C Bulk Cable Weight: 160.726 Kg/Km Max. Recommended Pulling Tension: 1165.428 N Min. Bend Radius/Minor Axis: 139.700 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes Other Standards: ISO/IEC 11801, Category 5e EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: ANSI/TIA/EIA-568-B.2, Category 5e Other Specification: NEMA WC-63.1, Category 5e Flame Test UL Flame Test: UL1666 Riser C(UL) Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Notes (Overall) Notes: Shielding effectiveness determined from screening attenuation measurement when tested in accordance with IEC 61196-1. Banana Peel® US PATENT 7049523. Page 4 of 5 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7876S Composite - Composite Data, Audio, Video, Security and Control Cabel Put Ups and Colors: Item # Revision Number: 0 Putup Ship Weight Color Notes Item Desc Revision Date: 09-24-2012 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 5 of 5 10-30-2013
7876S 000500
PDF文档中包含以下内容:
- 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
- 器件简介:STM32F103C8T6提供了多种外设功能,适用于多种嵌入式应用。
- 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
- 参数特性:主频72MHz,内置64KB FLASH和20KB RAM。
- 功能详解:包括GPIO、ADC、定时器、通信接口等多种功能。
- 应用信息:适用于工业控制、消费电子、医疗设备等领域。
- 封装信息:LQFP48封装。
7876S 000500 价格&库存
很抱歉,暂时无法提供与“7876S 000500”相匹配的价格&库存,您可以联系我们找货
