82907 8772500
82907 8772500
    BELDEN
    COAX 20AWG 50 OHM
82907 8772500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82907 Coax - 50 Ohm Ethernet Coax For more Information please call 1-800-Belden1 General Description: Thinnet 10Base2, 20 AWG stranded (19x32) .037" tinned copper conductor, plenum Ethernet, FPFA insulation, Duobond® II + overall TC braid shield (93% coverage), Flamarrest® jacket. Usage (Overall) Suitable Applications: Thin Ethernet Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 20 19x32 TC - Tinned Copper .037 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) FPFA - Foam Perflouoroalkoxy .095 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 2 Braid TC - Tinned Copper 93 Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® LS PVC - Low Smoke Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.160 in. Mechanical Characteristics (Overall) Operating Temperature Range: 0°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 22 lbs/1000 ft. Max. Recommended Pulling Tension: 45 lbs. Min. Bend Radius/Minor Axis: 1.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2P, CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes IEEE Specification: IEEE802.3 10Base2 EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2006 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82907 Coax - 50 Ohm Ethernet Coax CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 58A/U Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 9907 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) Tolerance (Ohms) 50 +/- 2 Nom. Inductance: Inductance (µH/ft) .0635 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 25.4 Nominal Velocity of Propagation: VP (%) 80 Nominal Delay: Delay (ns/ft) 1.27 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 8.8 Maximum Loop Resistance: Resistance (Ohm/1000 ft) 15.24 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.8 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .43 10 1.3 50 2.91 100 4.18 200 6.1 400 9.2 700 12.9 900 15.0 1000 16.0 Max. Operating Voltage - UL: Voltage 300 V RMS Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 82907 877U1000 1,000 FT 23.000 LB NATURAL O #20 FPFA BRD FLMRST 82907 8771000 1,000 FT 23.000 LB NATURAL CZ #20 FPFA BRD FLMRST 82907 8772500 2,500 FT 57.500 LB NATURAL CZ #20 FPFA BRD FLMRST 82907 877500 500 FT 12.500 LB NATURAL CZ #20 FPFA BRD FLMRST Notes: C = CRATE REEL PUT-UP. O = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR UNREEL CARTONS FROM LENGTH SHOWN. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82907 Coax - 50 Ohm Ethernet Coax Revision Number: 2 Revision Date: 09-25-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
82907 8772500 价格&库存
很抱歉,暂时无法提供与“82907 8772500”相匹配的价格&库存,您可以联系我们找货
