8412 0041000
8412 0041000
    BELDEN
    2 #20 EPDM BRD EPDM 1=1000'
8412 0041000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8412 Multi-Conductor - Two-Conductor, Low-Impedance Cable For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (26x34) high-conductivity TC conductors, EPDM rubber insulation, rayon braid, TC braid shield (85% coverage), cotton wrap, EPDM jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 2 20 26x34 Dia. (in.) High Conductivity TC - Tinned Copper .037 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) EPDM - Ethylene Propylene Diene Monomer Rubber 0.023 Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Braid Cotton 2 Braid TC - Tinned Copper 85 Outer Shield Separator Material: Cotton Wrap Outer Jacket Outer Jacket Material: Outer Jacket Material EPDM - Ethylene Propylene Diene Monomer Rubber Overall Cable Overall Cabling Color Code Chart: Number Color 1 White 2 Black Overall Cabling Separator Material: Rayon Braid Overall Nominal Diameter: 0.262 in. Mechanical Characteristics (Overall) Operating Temperature Range: -50°C To +90°C Non-UL Temperature Rating: 90°C Bulk Cable Weight: 44 lbs/1000 ft. Max. Recommended Pulling Tension: 100 lbs. Min. Bend Radius/Minor Axis: 2.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8412 Multi-Conductor - Two-Conductor, Low-Impedance Cable MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 67.000 Nom. Inductance: Inductance (µH/ft) .18 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 33.000 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 58.000 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 10.600 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.500 Max. Operating Voltage - Non-UL: Voltage 600 V RMS Max. Recommended Current: Current 4 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 8412 0021000 1,000 FT 47.000 LB RED C 2 #20 EPDM BRD EPDM 8412 0041000 1,000 FT 47.000 LB YELLOW C 2 #20 EPDM BRD EPDM 8412 0061000 1,000 FT 47.000 LB BLUE, LIGHT C 2 #20 EPDM BRD EPDM 8412 010U1000 1,000 FT 46.000 LB BLACK 2 #20 EPDM SHLD EPDM 8412 010U500 500 FT 23.500 LB BLACK 2 #20 EPDM SHLD EPDM 8412 010100 100 FT 5.200 LB BLACK 8412 0101000 1,000 FT 47.000 LB BLACK 8412 010250 250 FT 12.000 LB BLACK 8412 010500 500 FT 24.000 LB BLACK 2 #20 EPDM BRD EPDM C 2 #20 EPDM BRD EPDM 2 #20 EPDM BRD EPDM C 2 #20 EPDM BRD EPDM Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 07-29-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
8412 0041000 价格&库存
很抱歉,暂时无法提供与“8412 0041000”相匹配的价格&库存,您可以联系我们找货
