8524 0081000
8524 0081000
    BELDEN
    HOOK-UP 22AWG STR GRY
8524 0081000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8524 Hook-up/Lead - (Type MW) MIL-W-76C-PVC For more Information please call 1-800-Belden1 General Description: Tinned copper, PVC insulation, medium wall. The extruded PVC insulation is flame and ozone resistant. Inert to most chemicals, oils, and solvents. Covers single cond., PVC insulated hook-up wire for internal wiring of electrical and electronic equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 22 7x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .017 Overall Insulation Overall Cable Overall Nominal Diameter: 0.064 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C Bulk Cable Weight: 3.600 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-W-76C type MWP MIL Spec Rating: 1000 V, 80°C Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15.000 Max. Operating Voltage - Other: Voltage Description 1000 Vrms Mil-W-76C Max. Recommended Current: Description Current Single conductor in free air @ 30C ambient 9 amps Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8524 Hook-up/Lead - (Type MW) MIL-W-76C-PVC Put Ups and Colors: Item # Putup Ship Weight Color 8524 001100 100 FT 0.400 LB BROWN Notes Item Desc 8524 0011000 1,000 FT 4.000 LB BROWN 8524 002100 100 FT 0.400 LB RED 8524 0021000 1,000 FT 4.000 LB RED 8524 003100 100 FT 0.400 LB ORANGE 8524 0031000 1,000 FT 4.000 LB ORANGE 8524 004100 100 FT 0.400 LB YELLOW 8524 0041000 1,000 FT 4.000 LB YELLOW 8524 005100 100 FT 0.400 LB GREEN, DARK 8524 0051000 1,000 FT 4.000 LB GREEN, DARK 8524 006100 100 FT 0.400 LB BLUE, LIGHT 8524 0061000 1,000 FT 4.000 LB BLUE, LIGHT 8524 007100 100 FT 0.400 LB VIOLET 8524 0071000 1,000 FT 4.000 LB VIOLET 8524 008100 100 FT 0.400 LB GRAY 8524 0081000 1,000 FT 4.000 LB GRAY 8524 009100 100 FT 0.400 LB WHITE 8524 0091000 1,000 FT 4.000 LB WHITE 8524 010100 100 FT 0.400 LB BLACK 8524 0101000 1,000 FT 4.000 LB BLACK P 22 STR PVC BLK 8524 0131000 1,000 FT 4.000 LB BLUE, DARK P 22 STR PVC DBLU 22 STR PVC BRN P 22 STR PVC BRN 22 STR PVC RED P 22 STR PVC RED 22 STR PVC ORG P 22 STR PVC ORG 22 STR PVC YEL P 22 STR PVC YEL 22 STR PVC GRN P 22 STR PVC GRN 22 STR PVC LBLU P 22 STR PVC LBLU 22 STR PVC VIO P 22 STR PVC VIO 22 STR PVC GRY P 22 STR PVC GRY 22 STR PVC WHT P 22 STR PVC WHT 22 STR PVC BLK Notes: P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 1 Revision Date: 05-13-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
8524 0081000
物料型号:型号为LM324,是一款四运算放大器。
器件简介:LM324是一种低功耗、四运算放大器,广泛应用于模拟信号处理。
引脚分配:1脚为非反相输入端,2脚为反相输入端,3脚为输出端,4脚为负电源输入端,5脚为正电源输入端,6脚为反相输入端,7脚为非反相输入端,8脚为输出端,9脚为输出端,10脚为非反相输入端,11脚为反相输入端,12脚为负电源输入端,13脚为输出端,14脚为正电源输入端。
参数特性:包括电源电压范围、输入偏置电流、增益带宽积、压摆率等。
功能详解:LM324可以用于各种模拟信号处理应用,如信号放大、滤波器设计、振荡器设计等。
应用信息:广泛应用于消费电子、医疗仪器、工业控制系统等领域。
封装信息:有多种封装形式,如SOIC、DIP等。
8524 0081000 价格&库存
很抱歉,暂时无法提供与“8524 0081000”相匹配的价格&库存,您可以联系我们找货
