8649 0601000
    BELDEN
    2#20 FRPVC PARALLEL
8649 0601000 数据手册
Part Number: 8649 Speaker Cable, 2 Conductor 20 AWG BC, Unshielded, CM Product Description 2 Conductor 20 AWG stranded (7x28) ETP high-conductivity copper conductors, PVC insulation, parallel: (1) tinned, (1) bare, CM rated. Technical Specifications Product Overview Environmental Space: Indoor (Not Riser or Plenum) Suitable Applications: Speaker Cable Physical Characteristics (Overall) Conductor AWG Stranding Material No. of Conductors 20 7x28 High Conductivity TC - Tinned Copper 20 7x28 High Conductivity BC - Bare Copper Conductor Count: 2 AWG Size: 20 Insulation Material Nominal Wall Thickness PVC - Polyvinyl Chloride 0.018 in Outer Shield Material Material Unshielded Outer Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.073 x 0.146 in Electrical Characteristics Conductor DCR Nominal Conductor DCR 10.5 Ohm/1000ft Inductance Nominal Inductance 0.2 µH/ft Current Max. Recommended Current [A] 3.8 Amps per conductor @ 25°C Voltage Non-UL Voltage Rating 300V RMS Temperature Range 1 1 Non-UL Temp Rating: 75°C Operating Temp Range: -20°C To +75°C Mechanical Characteristics Bulk Cable Weight: 11 lbs/1000ft Max Recommended Pulling Tension: 31 lbs Min Bend Radius/Minor Axis: 1.5 in Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Part Number Plenum (Y/N): No Variants Item # Color 8649 0601000 CHROME 8649 3681000 CLEAR, TRANSPARENT © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
8649 0601000 价格&库存
很抱歉,暂时无法提供与“8649 0601000”相匹配的价格&库存,您可以联系我们找货
