8918 0011000
8918 0011000
    BELDEN
    HOOK-UP 18AWG STR BRN
8918 0011000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8918 Hook-up/Lead - UL AWM Style 1015 For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (16x30) tinned copper conductor, PVC insulation. Rated 105ºC, 600V. Rated 2500V peak for electronic circuits, and internal wiring of electronic and electrical equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 18 16x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Min. Avg. Wall (in.) PVC - Polyvinyl Chloride 0.030 Overall Insulation Overall Cable Overall Nominal Diameter: 0.110 in. Mechanical Characteristics (Overall) Bulk Cable Weight: 10 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 600 V, 105°C UL Type: MTW, AWM 1015 or 1230 CSA Rating: 600 V, 105°C CSA Type: AWM I A/B or TEW EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 CSA Flame Test: FT1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.900 Max. Recommended Current: Description Current Single conductor in free air @ 30C ambient 20 amps Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8918 Hook-up/Lead - UL AWM Style 1015 Put Ups and Colors: Item # Putup Ship Weight Color 8918 001100 100 FT 1.300 LB BROWN Notes Item Desc 8918 0011000 1,000 FT 11.000 LB BROWN 8918 002100 100 FT 1.300 LB RED 8918 0021000 1,000 FT 11.000 LB RED P 18 STR PVC RED 8918 0025000 5,000 FT 55.000 LB RED C #18 STR PVC RED 8918 003100 100 FT 1.300 LB ORANGE 8918 0031000 1,000 FT 11.000 LB ORANGE 8918 004100 100 FT 1.300 LB YELLOW 8918 0041000 1,000 FT 11.000 LB YELLOW P 18 STR PVC YEL 8918 0045000 5,000 FT 55.000 LB YELLOW C #18 STR PVC YEL 8918 005100 100 FT 1.300 LB GREEN, DARK 8918 0051000 1,000 FT 11.000 LB GREEN, DARK P 18 STR PVC GRN 8918 0055000 5,000 FT 50.000 LB GREEN, DARK P #18 STR PVC DGRN 8918 0071000 1,000 FT 11.000 LB VIOLET P #18 STR PVC VIO 8918 0081000 1,000 FT 11.000 LB GRAY P #18 STR PVC GRY 8918 0085000 5,000 FT 55.000 LB GRAY P #18 STR PVC GRY 8918 009100 100 FT 1.300 LB WHITE 8918 0091000 1,000 FT 11.000 LB WHITE P 18 STR PVC WHT 8918 0095000 5,000 FT 55.000 LB WHITE C #18 STR PVC WHT 8918 010100 100 FT 1.300 LB BLACK 8918 0101000 1,000 FT 11.000 LB BLACK P 18 STR PVC BLK 8918 0105000 5,000 FT 55.000 LB BLACK C #18 STR PVC BLK 8918 013100 100 FT 1.300 LB BLUE, DARK 8918 0131000 1,000 FT 11.000 LB BLUE, DARK P 18 STR PVC D BLU 8918 0135000 5,000 FT 55.000 LB BLUE, DARK C #18 STR PVC DBLU 8918 189100 100 FT 1.300 LB GREEN/YELLOW A 18 STR PVC GRN/YEL 8918 1891000 1,000 FT 11.000 LB GREEN/YELLOW A 18 STR PVC GRN/YEL 18 STR PVC BRN P 18 STR PVC BRN 18 STR PVC RED 18 STR PVC ORG P 18 STR PVC ORG 18 STR PVC YEL 18 STR PVC GRN 18 STR PVC WHT 18 STR PVC BLK 18 STR PVC D BLU Notes: A = STOCKED STRIPE COLORS. C = CRATE REEL PUT-UP. P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 2 Revision Date: 03-20-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
8918 0011000 价格&库存
很抱歉,暂时无法提供与“8918 0011000”相匹配的价格&库存,您可以联系我们找货
    • 1000+12.061521000+1.56498
