9116 0101000
9116 0101000
    BELDEN
    CABLE COAX 18 AWG 1000
9116 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9116 Coax - CATV Cable For more Information please call 1-800-Belden1 General Description: Series 6, 18 AWG solid .040" bare copper-covered steel conductor, gas-injected foam polyethylene insulation, Duobond® II + aluminum braid shield (60% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 18 Solid Dia. (in.) BCCS - Bare Copper Covered Steel .040 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FPE - Foam Polyethylene .180 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® 2 Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid AL - Aluminum 60 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.270 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C Bulk Cable Weight: 27 lbs/1000 ft. Max. Recommended Pulling Tension: 126 lbs. Min. Bend Radius/Minor Axis: 2.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CATV, CM CEC/C(UL) Specification: CM EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Series Type: Series 6 Flame Test UL Flame Test: UL1581 Vertical Flame and FT-1 Flame Test Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9116 Coax - CATV Cable Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 9116P Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) Tolerance (Ohms) 75 ±3 Nom. Inductance: Inductance (µH/ft) .097 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.2 Nominal Velocity of Propagation: VP (%) 83 Nominal Delay: Delay (ns/ft) 1.2 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 28 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9 Max. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 5 0.67 55 1.60 211 2.87 270 3.24 300 3.43 350 3.72 400 4.00 450 4.26 550 4.71 750 5.59 870 6.00 1000 6.54 Max. Operating Voltage - UL: Voltage 300 V RMS Minimum Structural Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 1000 20 Sweep Test Sweep Testing: 5 MHz - 1 GHz Put Ups and Colors: Item # Putup Ship Weight Color 9116 Q5HU1000 1,000 FT 29.000 LB WHITE, NEUTRAL Notes 9116 Q5H1000 1,000 FT 30.000 LB WHITE, NEUTRAL 9116 009N1000 1,000 FT 30.000 LB WHITE 9116 009U1000 1,000 FT 29.000 LB WHITE #18 GIFHDLDPE SH PVC 9116 0091000 1,000 FT 30.000 LB WHITE #18 GIFHDLDPE SH PVC 9116 009500 500 FT 15.500 LB WHITE 9116 010N1000 1,000 FT 30.000 LB BLACK 9116 010S700 700 FT 18.900 LB BLACK #18 GIFHDLDPE SH PVC 9116 010U1000 1,000 FT 29.000 LB BLACK #18 GIFHDLDPE SH PVC 9116 010U500 500 FT 15.000 LB BLACK 9116 0101000 1,000 FT 30.000 LB BLACK Page 2 of 3 Item Desc #18 GIFHDLDPE SH PVC #18 GIFHDLDPE SH PVC C #18 GIFHDLDPE SH PVC #18 GIFHDLDPE SH PVC C #18 GIFHDLDPE SH PVC #18 GIFHDLDPE SH PVC C #18 GIFHDLDPE SH PVC 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9116 Coax - CATV Cable 9116 010500 500 FT 15.500 LB BLACK #18 GIFHDLDPE SH PVC 9116 290U1000 1,000 FT 29.000 LB BEIGE, LIGHT #18 GIFHDLDPE SH PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 4 Revision Date: 03-03-2014 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
9116 0101000 价格&库存
很抱歉,暂时无法提供与“9116 0101000”相匹配的价格&库存,您可以联系我们找货
  • 1+350.501371+45.28205
  • 2+333.754442+43.11848
库存:2
9116 0101000
  • 1+14.257061+1.84190
  • 50+11.2831950+1.45770
  • 100+10.14613100+1.31080
  • 305+9.00906305+1.16390
