9463 0036000
9463 0036000
    BELDEN
    TWINAX 20AWG SHLD 78 OHM
9463 0036000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9463 Twinax - Blue Hose® Cable For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (7x28) .038" tinned copper conductors, polyethylene insulation, Beldfoil® (100% coverage) plus a tinned copper braid shield (55% coverage), sunlight-resistant PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 20 7x28 TC - Tinned Copper 0.038 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Dia. (in.) PE - Polyethylene 0.078 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 2 Braid TC - Tinned Copper 55 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 20 7x28H TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.238 in. Pair Pair Color Code Chart: Number Color 1 Clear & Blue Pair Lay Length & Direction: Twists (twist/ft) 2.750 Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 2464) Bulk Cable Weight: 36 lbs/1000 ft. Max. Recommended Pulling Tension: 48 lbs. Min. Bend Radius/Minor Axis: 2.400 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2, CM CEC/C(UL) Specification: CM AWM Specification: UL Style 2464 (300 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9463 Twinax - Blue Hose® Cable EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes PMSHA Specification: P-7K-SC-182141 Customer Part Number Reference Specification: Allen Bradley P/N 1770-CD Flame Test UL Flame Test: UL1685 UL Loading Suitability Sunlight Resistance: Yes Plenum/Non-Plenum Plenum Number: 89463 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 78 Nom. Inductance: Inductance (µH/ft) 0.12 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 19.7 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 36 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.54 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9.5 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.6 10 2.1 50 5.0 100 7.5 200 11.0 400 16.0 Max. Operating Voltage - UL: Voltage 300 V RMS (UL AWM Style 2464) 300 V RMS (NEC Type CM) 300 V RMS (NEC Type CL2) Other Electrical Characteristic 1: DC Resistance Unbalanced: .77 Ohms/1000 ft Max Put Ups and Colors: Item # Putup Ship Weight Color Page 2 of 3 Notes Item Desc 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9463 Twinax - Blue Hose® Cable 9463 J22U1000 1,000 FT 38.000 LB BLUE, STRONG 78 OHM TWINAX 9463 J22U500 500 FT 19.500 LB BLUE, STRONG 78 OHM TWINAX 9463 J22100 100 FT 4.400 LB BLUE, STRONG 9463 J221000 1,000 FT 39.000 LB BLUE, STRONG C 78 OHM TWINAX 9463 J2212000 12,000 FT 492.000 LB BLUE, STRONG CY 78 OHM TWINAX 9463 J22500 500 FT 19.500 LB BLUE, STRONG 9463 J226000 6,000 FT 234.000 LB BLUE, STRONG 9463 0011000 1,000 FT 39.000 LB BROWN 9463 00110000 10,000 FT 380.000 LB BROWN CZ 78 OHM TWINAX 9463 00112000 12,000 FT 492.000 LB BROWN CY 78 OHM TWINAX 9463 0016000 6,000 FT 234.000 LB BROWN CZ 78 OHM TWINAX 9463 0031000 1,000 FT 39.000 LB ORANGE C 78 OHM TWINAX 9463 00310000 10,000 FT 380.000 LB ORANGE CZ 78 OHM TWINAX 9463 00312000 12,000 FT 492.000 LB ORANGE CY 78 OHM TWINAX 9463 0036000 6,000 FT 234.000 LB ORANGE CZ 78 OHM TWINAX 9463 0071000 1,000 FT 39.000 LB VIOLET C 00 OHM TWINAX 9463 0076000 6,000 FT 234.000 LB VIOLET CZ 78 OHM TWINAX 78 OHM TWINAX 78 OHM TWINAX CZ 78 OHM TWINAX 78 OHM TWINAX Notes: C = CRATE REEL PUT-UP. Y = FINAL PUT-UP LENGTH MAY VARY -10% TO +20% FROM LENGTH SHOWN.MAY CONTAIN 2 PIECES. MINIMUM LENGTH OF ANY ONE PIECE IS 1500'. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 3 Revision Date: 08-01-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9463 0036000 价格&库存
很抱歉,暂时无法提供与“9463 0036000”相匹配的价格&库存,您可以联系我们找货
  • 6000+29.285916000+3.80578
