AX103260
AX103260
    BELDEN
    CAT5E HD-BIX PATCH PANEL 24-P
AX103260 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX103260 Faceplates and Panels - HD Patch Panel - HD-Style For more Information please call 1-800-Belden1 General Description: CAT5E HD-BIX Patch Panel, 24-port, 1U, Black Usage (Overall) Suitable Applications: IBDN System 1200, TIA Category 5e, ISO Class D, 1000BASE-T, 100BASE-T Related Parts: CAT5E Modular Cords Physical Characteristics (Connectivity) Capacity Max. Capacity: 24 connectors ( Patch Panel is already loaded ) Access Front Connection: Flush Termination Area: Rear Dimensions Dimensions: Height (in.) Width (in.) Depth (in.) 1.750 19.000 1.500 Materials Materials: Description Material Panel Steel Color Color: Black Weight Weight: 1.200 lbs. Included Parts Included Parts: 4 Screws (10x32); 4 Screws (12x24); 1 Printable LabelFlex Half-Sheet;, 1 Installation Guide. Packaging Packaging: Individually packaged in a cardboard box. Mechanical Characteristics (Connectivity) Footprint/Type: HDPP Plug / Jack Compatibility: RJ45 Termination Interface: Termination Connection Durabilities Front Mated Connection 750 Cycles Rear IDC Connection 10 Insertions Termination Characteristics: Termination Characteristic Universal T568A/B Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Tool Compatibility: BIX Connecting Tool (A0270165) Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes Page 1 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX103260 Faceplates and Panels - HD Patch Panel - HD-Style EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2006 MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: Category 5e - TIA 568.B.2, Category 5 - ISO/IEC 11801:2002 Ed.2 Safety Listing: ACA, Bi-national Standard Listed Suitability Suitability - Indoor: Yes Transmission Characteristics (Connectivity) Mated Connection Table 1: Max. Min. Min. Min. Min. Frequency Max. Insertion Loss Insertion Loss NEXT NEXT FEXT FEXT (MHz) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) 1.000 0.100 0.100 65.000 77.000 65.000 67.000 4.000 0.100 0.100 65.000 73.000 63.100 65.000 8.000 0.100 0.100 64.900 66.900 57.000 58.900 10.000 0.100 0.100 63.000 65.000 55.100 57.000 16.000 0.100 0.100 58.900 60.900 51.000 52.900 20.000 0.100 0.100 57.000 59.000 49.100 51.000 25.000 0.100 0.100 55.000 57.000 47.100 49.000 31.250 0.110 0.100 53.100 55.100 45.200 47.100 62.500 0.160 0.120 47.100 49.100 39.200 41.100 100.000 0.200 0.160 43.000 45.000 35.100 37.000 160.000 0.210 40.900 Mated Connection Table - Footnote: 32.900 * TIA-EIA-568-B.2 Category 5e Standard. ** Worst-case performance for a CAT5E mated connection using CAT5E modular plugs. Mated Connection Table 2: Min. Frequency Min. Return Loss Return Loss (MHz) TIA* (dB) Belden** (dB) 1.000 30.000 32.000 4.000 30.000 32.000 8.000 30.000 32.000 10.000 30.000 32.000 16.000 30.000 32.000 20.000 30.000 32.000 25.000 30.000 32.000 31.250 30.000 32.000 62.500 24.100 32.000 100.000 20.000 28.000 160.000 23.900 Dielectric Strength: 1,000 V RMS @ 60Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20m-Ohm Termination Resistance: 2.5 m-Ohm Notes (Overall) Notes: For proper installation refer to Installation Guide PX100796 included with the product or visit our web site at http://www.belden.com Product Family Part Numbers: Description Item Number HD-BIX PP CAT5E 1U24P, Black AX103260 HD-BIX PP CAT5E 2U48P, Black AX103261 Put Ups and Colors: Item # Putup Ship Weight AX103260 1 EA 1.719 LB Color Notes Item Desc CAT5E HD-BIX PATCH PANEL 24-P Page 2 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX103260 Faceplates and Panels - HD Patch Panel - HD-Style Revision Number: 0 Revision Date: 06-10-2009 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 02-27-2017
AX103260 价格&库存
很抱歉,暂时无法提供与“AX103260”相匹配的价格&库存,您可以联系我们找货
