AX104596
AX104596
    BELDEN
    CAT 6+ SHIELDED MODULAR JACK
AX104596 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION AX104596 Modular Connectors - CAT6+ Shielded KeyConnect Modular Jack For more Information please call 1-800-Belden1 General Description: CAT6+ Shielded KeyConnect Modular Jack, Category 6, RJ45 Usage (Overall) Suitable Applications: IBDN Shielded System 2400, TIA Screened Category 6 , ISO Class E, 1000BASE-T Related Parts: Compatible with Shielded KeyConnect Patch Panels 24-p , 48-p, See notes if using with Belden faceplates. Physical Characteristics (Connectivity) Dimensions Dimensions: Height (mm) Width (mm) Depth (mm) 25.400 17.145 39.878 Materials Materials: Description Type Material Front Connection RJ45 Phosphor Bronze with 50u inch Gold over Nickel Plating Rear Connection IDC Phosphor Bronze with Tin Plating over Nickel Connector Body Metal N/A Wiring Scheme Wiring Scheme: T568A/B Weight Weight: 0.022 kg Included Parts Included Parts: 1 Termination Bar, 1 cable Tie Packaging Packaging: Individually packaged in a plastic bag. Standard pack of 70 units. Mechanical Characteristics (Connectivity) Footprint/Type: KeyConnect Plug / Jack Compatibility: RJ45, RJ11 Termination Interface: Termination Connection Durabilities Front Mated Connection 750 cycles Rear IDC Connection 20 terminations Cable/Connector Retention: 66.723 N Connector/Hardware Retention: 88.964 N Plug/Connector Retention: 50.042 N Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Tool Compatibility: Tool Less Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2011 MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: Category 6 - TIA 568.C.2, Class E - ISO/IEC 11801:2002 Page 1 of 2 07-31-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION AX104596 Modular Connectors - CAT6+ Shielded KeyConnect Modular Jack Telecommunications Standards: Category 6 - TIA 568.C.2, Class E - ISO/IEC 11801:2002 Third Party Performance Verification: ETL - Verified Category 6 Safety Listing: Bi-national Standard Listed Suitability Suitability - Indoor: Yes - Indoor Transmission Characteristics (Connectivity) Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20 m-Ohm Termination Resistance: 2.5 m-Ohm Notes (Overall) Notes: IDC Wire Gauge: 22~24 AWG. Max cable OD 8.55mm (0.336 in.) May not be compatible with all Belden faceplates. Please contact Belden Technical Support for compatibility verification. Product Family Put Ups and Colors: Item # Putup Ship Weight AX104596 1 EA 0.040 KG Revision Number: 1 Color Notes Item Desc Cat 6+ Shielded Modular Jack Revision Date: 07-27-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 07-31-2017
AX104596 价格&库存
很抱歉,暂时无法提供与“AX104596”相匹配的价格&库存,您可以联系我们找货
