C6S4106001M
C6S4106001M
    BELDEN
    BELDEN - C6S4106001M - Ethernet Cable, Cat5e, Cat6, RJ45 Plug to RJ45 Plug, SFTP (Screened Foiled Tw...
C6S4106001M 数据手册
Part Number: CAT6+ S/FTP LSZH PATCH CORDS Copper RJ45 Patch Cord, CAT6+ , S/FTP, LSZH Product Description Copper RJ45 Patch Cord, CAT6+ , S/FTP, 26AWG, LSZH/FRNC Technical Specifications Product Overview Environmental Space: Indoor Rated (Not Riser or Plenum) Suitable Applications: Horizontal and building cabling. Support current and future Category 6 and 5e applications, such as: 1000Base-T (Gigabit Ethernet), 100 Base-T, 10 Base-T, FDDI, ATM Physical Characteristics (Overall) Conductor AWG Stranding Nominal Diameter No. of Pairs 26 Stranded 6.1 mm 4 Total Number of Pairs: 4 Conductor Size: 26 AWG Insulation Material Polyethylene Inner Shield Material Element Type Material Individual shielded pair Tape Laminated aluminum-polyester Inner Jacket Material Material No inner Jacket Outer Shield Material Type Material Coverage [%] Braid TC - Tinned Copper 30 % Outer Jacket Material Material Nominal Diameter LSZH - Low Smoke Zero Halogen 6.1 mm Wiring Scheme: T568A/B-T568A/B Packaging: Individually packaged in a clear plastic bag. Connectors Materials Description Material Type Plug Polycarbonate RJ45 Boot LSZH Snagless Front Connection Phosphor Bronze with 50u inch Gold over Nickel Plating Blades Electrical Characteristics Dielectric Strength: 2.5 kV DC Current Rating: 1A Insulation Resistance: 5000 MOhm*km Max Contact Resistance: 20 mOhm Voltage Voltage Rating [V] 72 V DC Performance Footnote1: There is 1dB margin on NEXT and RL guaranteed compared to ISO/IEC 11801-1:2018 Performance Footnote2: The performance data below 4Mhz or above 500Mhz are for information only. Temperature Range Installation Temp Range: 0°C To +50°C Operating Temp Range: -20°C to +60°C Mechanical Characteristics Min Bend Radius (Overall Cable): 25 mm Plug /Jack Compatibility: RJ45 Termination Interface Termination RJ45 Connection Durabilities Mated Connection 750 Cycles Standards ISO/IEC Compliance: ISO/IEC 11801-1:2018 Data Category: Category 6+ Telecommunications Standards: ISO/IEC 11801-1:2017; EN 50173-1 Amd 1 Caregory 6; ANSI/TIA/EIA 568 C.2 Category 6 Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2013-01-25 Suitability Suitability - Indoor: Yes Part Number Related Parts: CAT 6+ Shielded Modular Jacks, CAT 6+ shielded Patch Panels Variants Item # Color Length C6S4100001M Black 1m C6S4100002M Black 2m C6S4100003M Black 3m C6S4100005M Black 5m C6S4100010M Black 10 m C6S4100015M Black 15 m C6S41000D5M Black 0.5 m C6S4106001M Blue 1m C6S4106002M Blue 2m C6S4106003M Blue 3m C6S4106005M Blue 5m C6S4106008M Blue 8m C6S4106010M Blue 10 m C6S4106015M Blue 15 m C6S41060D5M Blue 0.5 m C6S4106006M Blue 6m C6S4108001M Gray 1m C6S4108002M Gray 2m C6S4108003M Gray 3m C6S4108005M Gray 5m C6S4108010M Gray 10 m C6S4108015M Gray 15 m C6S41080D5M Gray 0.5 m C6S4105001M Green 1m C6S4105002M Green 2m C6S4105003M Green 3m C6S4105005M Green 5m C6S4105010M Green 10 m C6S4105015M Green 15 m C6S41050D5M Green 0.5 m C6S4103005M Orange 5 m C6S4102001M Red 1m C6S4102002M Red 2m C6S4102003M Red 3m C6S4102005M Red 5m C6S4102010M Red 10 m C6S4102015M Red 15 m C6S41020D5M Red 0.5 m C6S4107005M Violet 5m C6S41071D5M Violet 1.5 m C6S4109070M White 70 m C6S41090D5M White 0.5 m C6S4109050M White 50 m C6S4109001M White 1m C6S4109002M White 2m C6S4109003M White 3m C6S4109005M White 5m C6S4109010M White 10 m C6S4109015M White 15 m C6S4109030M White 30 m C6S4104001M Yellow 1m C6S4104002M Yellow 2m C6S4104003M Yellow 3m C6S4104005M Yellow 5m C6S4104010M Yellow 10 m C6S4104015M Yellow 15 m C6S41040D5M Yellow 0.5 m © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
C6S4106001M 价格&库存
很抱歉,暂时无法提供与“C6S4106001M”相匹配的价格&库存,您可以联系我们找货
C6S4106001M
  • 1+105.62755
  • 25+101.40995
  • 100+97.18193
库存:3
