1696A B59250
1696A B59250
    BELDEN
    2 #22 FHDPE SHLD PVC
1696A B59250 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1696A Multi-Conductor - Single-Pair Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductors, Datalene® insulation, twisted pair with fillers, overall Beldfoil® + TC braid shield (90% coverage), 24 AWG drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 22 7x30 TC - Tinned Copper .030 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® Dia. (in.) FHDPE - Foam High Density Polyethylene .082 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® (Z-fold®) 2 Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Braid TC - Tinned Copper 90 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.235 in. Pair Pair Color Code Chart: Number Color 1 Light Blue & White Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +60°C Non-UL Temperature Rating: 60°C Bulk Cable Weight: 30 lbs/1000 ft. Max. Recommended Pulling Tension: 56 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1696A Multi-Conductor - Single-Pair Cable CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: AES/EBU Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 110 Nom. Inductance: Inductance (µH/ft) .18 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 13.0 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 26 Nominal Velocity of Propagation: VP (%) 76 Nominal Delay: Delay (ns/ft) 1.3 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 17.8 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.89 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) .384 .58 .7056 .69 .768 .7 1.024 .76 1.4112 .82 1.536 .84 2.048 .88 2.8224 .93 3.072 .95 4.096 1.09 5.6448 1.32 6.144 1.37 8.192 1.48 11.2896 1.74 12.288 1.77 24.576 2.41 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Max. Recommended Current: Current 3.8 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color 1696A B59U1000 1,000 FT 32.000 LB BLACK, MATTE 1696A B591000 1,000 FT 34.000 LB BLACK, MATTE 1696A B59250 250 FT 8.500 LB BLACK, MATTE 2 #22 FHDPE SHLD PVC 1696A B59500 500 FT 17.000 LB BLACK, MATTE 2 #22 FHDPE SHLD PVC Page 2 of 3 Notes Item Desc 2 #22 FHDPE SHLD PVC C 2 #22 FHDPE SHLD PVC 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1696A Multi-Conductor - Single-Pair Cable Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 10-18-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
1696A B59250 价格&库存
很抱歉,暂时无法提供与“1696A B59250”相匹配的价格&库存,您可以联系我们找货
