Part Number: 7809R
RF 300 Wireless Coax, #13, CMR/CMG
Product Description
Intermediate type, 13 AWG solid .072" bare copper conductor, gas-injected foam HDPE insulation, Duobond® II, tinned copper braid shield (95% coverage),
PVC jacket.
Technical Specifications
Product Overview
Environmental Space:
Indoor - Riser
Physical Characteristics (Overall)
Conductor
AWG Stranding
13
Solid
Material
Nominal Diameter No. of Coax
BC - Bare Copper 0.072 in
1
Conductor Count:
1
AWG Size:
13
Insulation
Material
Nominal Diameter
Gas-injected FHDPE - Foam High Density Polyethylene 0.19 in
Outer Shield Material
Type Layer
Material
Material Trade Name Coverage [%]
Tape 1
Bonded Aluminum Foil-Polyester Tape-Aluminum Foil Bonded Duofoil®
100 %
Braid 2
TC - Tinned Copper
95 %
Outer Jacket Material
Material
Nominal Diameter
PVC - Polyvinyl Chloride 0.3 in
Electrical Characteristics
Conductor DCR
Nominal Conductor
DCR
2.1 Ohm/1000ft
Nominal Conductor DCR Conductor Resistance Nominal Outer Shield DCR Outer Conductor DCR
2.1 Ohm/1000ft
Capacitance
Nom. Capacitance Conductor to Shield
23 pF/ft
Inductance
Nominal Inductance
0.06 µH/ft
Impedance
Nominal Characteristic Impedance
50 Ohm
High Frequency (Nominal/Typical)
2.4 Ohm/1000ft
2.4 Ohm/1000ft
Frequency [MHz] Nom. Insertion Loss
5 MHz
0.45 dB/100ft
10 MHz
0.6 dB/100ft
30 MHz
1 dB/100ft
50 MHz
1.3 dB/100ft
150 MHz
2.2 dB/100ft
220 MHz
2.7 dB/100ft
450 MHz
3.9 dB/100ft
900 MHz
5.6 dB/100ft
1500 MHz
7.3 dB/100ft
1800 MHz
8.1 dB/100ft
2000 MHz
8.6 dB/100ft
2500 MHz
9.7 dB/100ft
3000 MHz
10.8 dB/100ft
3500 MHz
11.8 dB/100ft
4500 MHz
13.5 dB/100ft
5800 MHz
15.8 dB/100ft
6000 MHz
16 dB/100ft
Delay
Nominal Delay Nominal Velocity of Propagation (VP) [%]
1.17 ns/ft
86 %
Power Rating
Frequency [MHz] Max. Power Rating [W] Nominal Power Rating [W]
30 MHz
2,161 W
2,161 W
50 MHz
1,658 W
1,658 W
150 MHz
928 W
928 W
220 MHz
758 W
758 W
450 MHz
522 W
522 W
900 MHz
367 W
367 W
1,500 MHz
278 W
522 W
2,000 MHz
239 W
253 W
2,500 MHz
212 W
239 W
3,500 MHz
179 W
212 W
4,500 MHz
157 W
194 W
6,000 MHz
135 W
179 W
4,500 MHz
157 W
157 W
5,800 MHz
137 W
137 W
6,000 MHz
135 W
135 W
Voltage
UL Voltage Rating
300 V RMS
VSWR
Frequency [MHz] Max. VSWR
5-6000 MHz
1.25:1
Temperature Range
UL Temp Rating:
60°C
Operating Temp Range:
-40°C To +75°C
Mechanical Characteristics
Bulk Cable Weight:
61 lbs/1000ft
Max Recommended Pulling Tension:
135 lbs
Min Bend Radius/Minor Axis:
3 in
Standards
NEC/(UL) Specification:
CMR
CEC/C(UL) Specification:
CMG
CPR Euroclass:
Eca
RG Type:
N/A
Applicable Environmental and Other Programs
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2003/11/EC (BFR):
Yes
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2012/19/EU (WEEE):
Yes
EU Directive 2015/863/EU:
Yes
EU Directive Compliance:
EU CE Mark:
Yes
EU RoHS Compliance Date (yyyy-mm-dd):
2004-01-01
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Suitability
Suitability - Indoor:
Yes
Flammability, LS0H, Toxicity Testing
UL Flammability:
UL1666 Vertical Shaft
CSA Flammability:
FT4
Part Number
Plenum (Y/N):
No
Suggested Connectors:
Mates with Land Mobile Radio type connectors.
Footnote:
C - CRATE REEL PUT-UP.
© 2018 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's
inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product
itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
