531-SWHOX
531-SWHOX
    LINEMASTER
531-SWHOX 数据手册
Linemaster Switch Corporation 29 Plaine Hill Road POB 238 Woodstock, CT 06281-0238 USA Toll Free: (800) 974-3668 (US Only) Telephone: (860) 974-1000 Fax: (860) 974-0691 E-Mail: service_266@linemaster.com Web site: www.linemaster.com Item # 531-SWHOX, Hercules Heavy duty Foot Switch - OX Shield Hercules Heavy duty Foot Switch - OX Shield  •  Rugged cast metal enclosure has sufficient weight to keep the switch from sliding when being operating  •  All models have a neoprene cover gasket plus O-rings on the activating shaft and a separate ground screw  •  In all maintained contact models the release is accomplished by simply pressing the latch with a light forward movement of the toe. The release is placed under the full shield so falling objects cannot easily release it  •  Oversize "O" and "OX" shield models accept oversized safety shoes and metatarsal foot guards. The "OX" shield has an additional 3/4inch (19.1 mm) opening height as compared to the "O" shield  •  Painted alert orange  •  single 3/4" -14 NPT threaded conduit entry is standard  •  3 holes provided for rigid mounting to the floor or equipment  SPECIFICATIONS Features  •  Driptight •  Dusttight •  Watertight •  Oiltight  Stages  Single Circuit  SPDT Form  C Electrical Rating Construction/Standards Size Weight Approx. Note  1 H.P. 125-250 VAC Heavy pilot duty 250 Vac max. 20A 125-250 VAC  NEMA Type 2, 4 &13 UL Enclosure 2, 4 &13 CSA Enclosure 2, 4 &13 EN 60529 Degree of Protection IP56  9 x 5 3/4 x 4 3/4 Inch  8 lbs  S-Denotes Momentary Contact-Press to start - release to stop, D-Denotes Maintained Contact-Press to start - Release Latch to stop, OX-Denotes extra oversize shield models. 11/21/2012 | Page 1 of 1
531-SWHOX 价格&库存
很抱歉,暂时无法提供与“531-SWHOX”相匹配的价格&库存,您可以联系我们找货
