632S TWIN DIVIDER
632S TWIN DIVIDER
    LINEMASTER
    LINEMASTER - 632S TWIN DIVIDER - SWITCH, FOOT, SPDT, OFF-(ON), 20A, 250V
632S TWIN DIVIDER 数据手册
Home | About | Products | Catalog | Int'l Distributors | Glossary | Support | Representative | ISO-9001 | Literature | Press | Shows | Directions | Contact Environmental Ratings: CLIPPER FOOTSWITCH EN 60529 Degree of Protection IP20 Key Benefits The rugged, long life Clipper foot switch models have proved themselves in the field over many years of usage. All maintained models offer "Push On-Push Off" action that insures long trouble-free performance. The wide treadle models offer a large seven inch target for the operator's foot. Cast iron housing. Nonskid base pad. Complete with adjustable strain relief connector. Black finish. Size: 4-1/2" x 3-1/2" x 1-1/2" Weight: 2-1/4 lbs. The CLIPPER TWIN consists of two SPDT or two DPDT foot switches mounted on a heavy steel base plate with nonskid pad. Divider bar between pedals helps prevent accidental operation of both pedals at one time. A tube between the two foot switches conceals all internal wiring between them. A conduit opening with strain relief connector is provided in the right foot switch. Clipper Footswitch Size:8-3/8" x 4-1/2" x 1-1/2" Weight: 5 lbs. Model 638-S features a cast aluminum housing painted Alert Orange with a splash resistant interior switch. Clipper Wide Treadle Footswitch Request A Quote SPECIFICATIONS (Special variations are available to the O.E.M. on special order on the models listed below) CATALOG NUMBER REGULAR TREADLE 632-S WIDE TREADLE 642-S 632-SC3* DESCRIPTION CIRCUIT FORM ELECTRICAL RATINGS Momentary SPDT C 20 A 125-250 VAC 1 H.P. 125-250 VAC Momentary SPST Wired N.O. A 15 A 125 VAC 3/4 H.P. 125 VAC 633-S 643-S Momentary SPDT DB± Z 20 A 125-250 VAC 3/4 H.P. 125 VAC 1 H.P. 250 VAC 635-S 645-S Momentary DPDT C 15 A 125 VAC 10 A 250 VAC 1/2 H.P. 125-250 VAC 636-S 646-S Two Stage Momentary Each Stage SPDT C 15 A 125 VAC 10 A 250 VAC 1/2 H.P. 125-250 VAC 632-DA 642-DA Maintained SPDT C 20 A 125-250 VAC 1 H.P. 125-250 VAC 634-DA Maintained DPDT C 10 A 125-250 VAC 1/8 H.P. 125 VAC 1/4 H.P. 250 VAC TWIN 632-S Momentary Each Side SPDT C 20 A 125-250 VAC 1 H.P. 125-250 VAC TWIN 635-S Momentary Each Side DPDT C 15 A 125 VAC 10 A 250 VAC 1/2 H.P. 125-250 VAC 638-S Momentary SPDT C 10 A 125-250 VAC 1/2 H.P. 125-250 VAC 638-SC38** (IP21) Momentary SPST Wired N.O. A 10 A 125-250 VAC 1/2 H.P. 125-250 VAC Model 638-S features a cast aluminum housing painted Alert Orange with a splash resistant interior switch. *Supplied with 8 ft. 14/3 cord and 3 prong series plug. Green lead grounded. **Supplied with 8 ft. 16/3 cord, wired N.O. with green lead grounded. ±DB Double Break models must be wired to equal voltage sources and the same polarity. The loads should be on the same sides of the line. BOLD COPY INDICATES STOCK ITEM Home | About | Products | Catalog | Int'l Distributors | Glossary | Support | Representative | ISO-9001 | Literature | Press | Shows | Directions | Contact LINEMASTER Switch Corporation · 29 Plaine Hill Road · POB 238 · Woodstock, CT 06281-0238 · USA Tel: 860.974.1000 Fax: 860.974.0691 or Toll-Free Fax 800.974.3668 (USA Only) © Copyright Linemaster Switch Corporation 2005
632S TWIN DIVIDER 价格&库存
很抱歉,暂时无法提供与“632S TWIN DIVIDER”相匹配的价格&库存,您可以联系我们找货
