491SC3
491SC3
    LINEMASTER
    LINEMASTER - 491SC3 - SWITCH, FOOT, SPDT, (ON), 10A, 250V
491SC3 数据手册
Home | About | Products | Catalog | Int'l Distributors | Glossary | Support | Representative | ISO-9001 | Literature | Press | Shows | Directions | Contact COMPACT Environmental Ratings: FOOTSWITCH EN 60529 Degree of Protection IP20 Key Benefits This foot switch is compact in size and light in weight. Built for long life, the strong steel housing is painted black with nonskid base pad. Size: 2-7/8" x 2-1/2" x 1-1/8" Weight: 7 oz. The TWIN 491-S foot switch consists of two single models mounted on a single cast aluminum base with a divider bar between pedals which helps prevent accidental operation of both pedals at one time. Compact Footswitch Request A Quote Size: 6" x 2-7/8" x 1-7/16" Weight: 1-1/4 lbs. SPECIFICATIONS (Special variations are available to the O.E.M. on special order on the models listed below) CATALOG NUMBER DESCRIPTION CIRCUIT ELECTRICAL RATINGS FORM 491-S Momentary SPDT C 10 A 125-250 VAC 1/2 H.P. 125-250 VAC 491-DA Maintained SPST A 10 A 125 VAC 491-DC3A* Maintained SPST A 7 A 125 VAC 491-SC3** Momentary SPDT Wired N.O. A 10 A 125 VAC 1/2 H.P. 125 VAC 491-SC36*** 491-SC36MP*** Momentary SPDT Wired N.O. A 10 A 125-250 VAC 1/2 H.P. 125-250 VAC TWIN 491-S Momentary Each Side SPDT C 10 A 125-250 VAC 1/2 H.P. 125-250 VAC 491-DC36A**** Maintained SPST A 10 A 125-250 VAC 1/2 H.P. 125-250 VAC 492-S Momentary SPDT C 20 A 125-250 VAC 1 H.P. 125-250 VAC *Supplied with 6 ft. 18/3 cord and 3 prong series plug. Green lead grounded. **Supplied with 8 ft. 16/3 cord with 3 prong series plug. Green lead grounded. ***Supplied with 6 ft. 16/3 cord without plug. Green lead grounded. ****Supplied with 6 ft. 18/3 cord without plug(Green Lead Grounded) BOLD COPY INDICATES STOCK ITEM Home | About | Products | Catalog | Int'l Distributors | Glossary | Support | Representative | ISO-9001 | Literature | Press | Shows | Directions | Contact LINEMASTER Switch Corporation · 29 Plaine Hill Road · POB 238 · Woodstock, CT 06281-0238 · USA Tel: 860.974.1000 Fax: 860.974.0691 or Toll-Free Fax 800.974.3668 (USA Only) © Copyright Linemaster Switch Corporation 2005
491SC3 价格&库存
很抱歉,暂时无法提供与“491SC3”相匹配的价格&库存,您可以联系我们找货
