3B-30A2-S
3B-30A2-S
    LINEMASTER
3B-30A2-S 数据手册
COMPACT AIRVAL by Linemaster Switch Corporation - America's Foot Switch Leader Home | About | Products | Catalog | Int'l Distributors | Glossary | Support | Representative | ISO-9001 | Literature | Press | Shows | Directions | Contact COMPACT AIRVAL Environmental Ratings: FOOTSWITCH Key Benefits ● ● ● ● ● Low Cost Air Valve Strong Steel Housing Nonskid Base Pad Easy To Connect Air Lines All LINEMASTER foot switches can be CE marked Size & Weight: Single Size: 2-7/8" x 2-1/2" x 1-1/8" Compact Airval Footswitch Weight: 1/2 lbs. Twin Size: 2-7/8" x 5-3/4" x 1-1/8" Weight: 1-1/2 lbs. Twin Compact Airval Footswitch Request A Quote http://www.linemaster.com/compactav.shtml (1 of 2)04/01/2007 10:14:14 • COMPACT AIRVAL by Linemaster Switch Corporation - America's Foot Switch Leader SPECIFICATIONS (Special variations are available to the O.E.M. on special order on the models listed below) CATALOG NUMBER TYPE AIR FLOW at 100 PSI EXHAUST at 100 PSI OPERATING FORCE PORTS 1/8-27 N.P.T. 2B-30A2-S* 2-Way 30 CFM None 7 lbs. Exposed 3B-30A2-S* 3-Way 30 CFM 25 CFM 7 lbs. Exposed TWIN 3B-30A2-S** Each Side 3-Way 30 CFM 25 CFM 7 lbs. Exposed Filtered and lubricated air supply is required for best results. *Use single guard #522-B14 **Use twin guard #522-B12 COMPRESSED AIR IS POWERFUL - ALWAYS USE CARE. MAXIMUM LINE PRESSURE UP TO 150 PSI Home | About | Products | Catalog | Int'l Distributors | Glossary | Support | Representative | ISO-9001 | Literature | Press | Shows | Directions | Contact LINEMASTER Switch Corporation · 29 Plaine Hill Road · POB 238 · Woodstock, CT 06281-0238 · USA Tel: 860.974.1000 Fax: 860.974.0691 or Toll-Free Fax 800.974.3668 (USA Only) Copyright © 1997 Linemaster Switch Corporation Trademark/Legal Notice http://www.linemaster.com/compactav.shtml (2 of 2)04/01/2007 10:14:14 •
3B-30A2-S 价格&库存
很抱歉,暂时无法提供与“3B-30A2-S”相匹配的价格&库存,您可以联系我们找货
