632-SC3
632-SC3
    LINEMASTER
632-SC3 数据手册
C L I LIT-037 Rev. B F O O T The Clipper foot switch was designed with an ergonomic shape and cast iron housing that will stand the test of time. One of Linemaster’s most popular foot switches, the Clipper, is offered in single, wide treadle and multi-pedal versions. The wide treadle Clipper switch offers the end user a 7 inch wide target to feel for when trying to depress the pedal. The Clipper has been the foot switch of choice in many different applications ranging from material handling to operating communication equipment. Available in custom switch variations with momentary or maintained actuation to suit the changing needs of our customers. Only from LINEMASTER® - American made innovation at work. w w w. l i n e m a s t e r. co m P P E R S W I T C H LINEMASTER Switch Corporation Tel (860) 974-1000 29 Plaine Hill Road, P.O. Box 238 Woodstock, Connecticut 06281-0238 USA Fax (800) 974-FOOT(3668) FEATURES: • • • • • • • • • • • • • Constructed of cast iron for long life Adjustable strain relief connector Durable black finish Non-skid base pad Model 632-DA can be used to control lighting Model 638-S features a cast aluminum housing painted alert orange with a splash resistant interior Wide treadle models have 2 holes for rigid mounting to floor or equipment Twin models have 4 holes for rigid mounting to floor or equipment Divider Bar on twin models aids in reducing accidental operation of multiple pedals at once Wide treadle models offer a large 7 inch target for the operator’s foot Airval models available Heavy gauge steel guard available Orange or black vinyl boots available for single models to provide protection against dirt, liquids, and bad weather Clipper - Single Size (HxWxD): 1.50 x 3.50 x 4.50 in. Weight: 2.25 lbs. Clipper - Wide Treadle Size (HxWxD): 1.78 x 7.00 x 5.50 in. Weight: 3.25 lbs. Clipper - Twin Size (HxWxD): 1.78 x 8.38 x 4.25 in. Weight: 5.00 lbs. Agency Approvals 1 t EN 60529 Degree of Protection Single Cat. No. Circuit Wide Treadle Cat. No. Circuit Twin Cat. No. Circuit Description Form Electrical Ratings IP20 632-S SPDT 642-S SPDT TWIN 632-S SPDT Each Side Momentary C 20A 125-250 VAC 1 H.P. 125-250 VAC IP20 632-SC31 SPST Wired N.O. ----------------- ------------- ----------------- ------------ Momentary A 15A 125 VAC 3/4 H.P. 125 VAC IP20 632-SC363 SPST Wired N.O. ----------------- ------------- ----------------- ------------ Momentary A 10A 125-250 VAC 1/2 H.P. 125-250 VAC IP20 633-S SPDT DBt 643-S SPDT DBt ----------------- ------------ Momentary Z 20A 125-250 VAC 3/4 H.P. 125 VAC 1 H.P. 250 VAC IP20 635-S DPDT 645-S DPDT TWIN 635-S DPDT Each Side Momentary C IP20 636-S SPDT Each Stage 646-S SPDT Each Stage ----------------- ------------- Two Stage Momentary C IP20 632-DA SPDT 642-DA SPDT ----------------- ------------- Maintained C 20A 125-250 VAC 1 H.P. 125-250 VAC IP20 632-DC3A1 SPST Wired N.O. ----------------- ------------- ----------------- ------------ Maintained C 15A 125 VAC 3/4 H.P. 125 VAC IP20 634-DA DPDT ----------------- ------------- ----------------- ------------- Maintained C 10A 125-250 VAC 1/8 H.P. 125 VAC 1/4 H.P. 250 VAC IP20 638-S SPDT ----------------- ------------- ----------------- ------------- Momentary C IP20 638-SC38 SPST Wired N.O. ----------------- ------------- ----------------- ------------- Momentary A 2 15A 125 VAC 10A 250 VAC 1/2 H.P. 125-250 VAC 10A 125-250 VAC 1/2 H.P. 125-250 VAC Supplied with 8 ft. 14/3 cord and 3 prong series plug; green lead grounded. 2 Supplied with 8 ft. 16/3 cord, wired N.O. with green lead grounded. 3 Supplied with 6 ft. 18/3 cord. DB Double Break models must be wired to equal voltage sources and the same polarity. The loads should be on the same sides of the line. w w w. l i n e m a s t e r. co m
632-SC3 价格&库存
很抱歉,暂时无法提供与“632-SC3”相匹配的价格&库存,您可以联系我们找货
