319-3906
319-3906
    BAHCO(实耐宝)
    BAHCO - 319-3906 - Hack Saw, 55° / 90° Blade Angle
319-3906 数据手册
Hacksaws 325 Ergo Ergonomically designed with very high blade tension for straight, accurate and exact kerfs. Centred blade for correct balance. Spring tensioned blade loading mechanism for quick blade changes. Alternative 55° blade mounting for flush cutting. Supplied with a bi-metal blade. Price Each Order Code 326-2390 225-Plus Professional hacksaw frame, allows very high blade tension for accurate and exact kerfs. Spring tensioned blade loading mechanism, strong rectangular back section for blade storage. Can also be used as a compass saw. Alternative 55° blade mounting for flush cutting. Supplied with a 300mm/12in Sandflex 24TPI bi-metal blade Price Each Order Code 702-5385 319 Two component handle hacksaw frame. Dual position 55 degree and 90 degree blade angle. Easy blade change mechanism. 488063 Price Each Order Code 135-6166
319-3906 价格&库存
很抱歉,暂时无法提供与“319-3906”相匹配的价格&库存,您可以联系我们找货
