2820VTEE
2820VTEE
    BAHCO(实耐宝)
    BAHCO - 2820VTEE - Tweezer, Insulated, 150 mm
2820VTEE 数据手册
INSULATED TOOLS Your Safety is our TOP PRIORITY! Insulated tools from Bahco Your safety is our TOP PRIORITY! Our history goes back more than 120 years. Bahco has been developing and marketing professional tools for use in a wide range the world over. Our core values of performance products are well designed and available globally, backed up with local expertise. The full guarantee Bahco offers reach new scope and depth of commitment with its safety tools, with a range of more than 200 insulated tools, one of the widest and most comprehensive range on the market. Our tools are safe All Bahco insulated tools are manufactured according to International IEC60900 standards for working with live systems up to 1000 V AC & 1500 V DC. They follow strict quality controls and are subjected to the most stringent tests. Bahco insulated tools comply with the VDE0820 Standards and 63% of the assortment is certified by the German VDE laboratory. The new Bahco 1000 V assortment is adapted to both distributors and end users needs. • Durability • Effectiveness Excellent Performance • User-centered product development • The best ergonomics on the market • Accessibility Outstanding Ergonomics The Bahco Design Safety Guarantee Broad Comprehensive Range • 216 references • One of the largest assortment on the market 2 • IEC 60900 • VDE Certificate • Multi-layer coating with different colours indicating safety, danger or high danger Safety Bahco tools all have a high level of technical performance. The materials used are of high quality and they have been carefully chosen and tested in order to guarantee safety and durability. We are one of the few hand-tool manufacturers who make the tools and the insulation in-house, both the PVC dipped insulated version (most of the tools) and the handle version (pliers, screwdrivers). Each tool is tested to 10000 V for a period of 10 seconds, thus guaranteeing safety during live work. High performance and quality materials. The flame does not spread. Can perform between -20° C and +70° C. Black tip protects against impact. Laser marked totally indelible. Yellow layer indicating high danger. Orange layer indicating danger. Red layer indicating safety. Routine tests in accordance to IEC60900 specification Dielectric test Retaining force test The tools are immersed in water for 24 hours. A voltage of 10kV is then continuously applied for 3 mins. The test is considered successful if no electrical puncture, spark over or flashover occurs during the test period and if the limits of leakage current are not exceeded. This test is applied only to tools which can be assembled. The test consists of applying a force of 50 N to try to separate both parts. After a minute, both parts should stay assembled. Impact test Permanent marking durability The tool is cooled at -25° C for two hours. Afterwards, a special hammer applies force on the insulating layer. The test is considered successful if the insulating material shows no breaks. The markings are rubbed for 15 s with a rag soaked in water, and then for 15 s with a rag soaked in isopropanol. After this process, the marking should be legible. Insulation adhesion test Penetration test The tools are conditioned at a temperature of 70° C for 168 h. A force of 50 N is applied in the direction of the line dividing the insulating material coating from the conductive part for 3 min. During this test the insulation material must stay firmly attached to the basic tool. The insulating surface is pressed with a special device. A voltage of 5000 V is then applied to the tool for 3 minutes. The test is considered successful. Flame test Visual and dimensional The test is considered as passed if the flame height on the tool does not exceed 120 mm and there is no leakage of insulated material in fusion. The tool (in particular the insulation) is visually checked and should be free from external defects. The marking should be perfectly legible and the dimensions should be in accordance with the standard. * IEC60900 * 63% of Bahco insulated tools are Certified by the German VDE laboratory 3 Insulated tools from Bahco GUARANTEE 1000 V PLIERS 4 Side cutting pliers dipped insulation • 1 component insulated handles up to 1000 volts • Designed to cut hard material such as piano wire close to the joint and to cut softer material such as copper wire and plastic insulated wire at the tip • Shaped jaws give improved accessibility in confined spaces • Finish: Black oxidised, anti-corrosion treated ISO: 5749, DIN: 5749 • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Cuts from 0.5 mm soft wire to 1.6 mm hard wire • Chrome plated finish ISO: 5749, DIN: 5749 Product code L mm A mm B mm C mm 2101S-140 2101S-160 2101S-180 2101S-200 140 160 180 200 19.5 21.5 23.5 25.5 16 18 20 22 9 10 11 11 Weight g 1.6 1.8 2.0 2.25 Product code L mm A mm B mm C mm 2171V-160 2171V-180 160 180 22 24 20 22 12 12 Weight g 1.6 2.0 221 267 156 202 300 388 Wire types for cutting capacity WIRE TYPE W Soft wire M Medium hard wire Spring wire TENSIBLE STRENGTH Ø mm Cu - 230 N/mm2 0.5 1 1.25 1.5 Bronze - 780 N/mm2 1600 N/mm2 1.6 Heavy duty side cutting pliers dipped insulation 1.4 1.6 Hard wire H 2100 - 2250 N/mm2 Piano wire 1.8 2 The variety between soft and piano depends on the tensile strength of the wire which of course is related to the material properties (copper, brass, iron, steel, etc). Then in each wire type we can find a large variety of thicknesses (diameters). More than the ones shown in this small chart. • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Cuts piano wire • Chrome plated finish ISO: 5749, DIN: 5749 Product code 2191V-180 2191V-200 L mm A mm B mm C mm 180 200 25 26 20 21 12 12 Weight g 2.0 2.5 262 290 Bahco cutting pliers enjoy better cutting capacity to other pliers End cutting pliers • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Cuts from 1.0 mm soft wire to 1.6 mm hard wire • Chrome plated finish ISO: 5748 DIN: 5748 L mm A mm B mm C mm 160 200 27 32 7 8 24 27 CUTTING EFFORT (N) Product code 527V-160 527V-200 CUTTING EFFORT COMPARATIVE TEST Weight g 1.6 2.0 270 440 CUTS 5 BAHCO OTHERS 1000 V Pliers Side cutting pliers 1000 V Pliers Combination pliers Combination pliers dipped insulation • 1 component insulated handles up to 1000 volts • Edges specially designed to cut hard material such as piano wire and spring steel wire • Gripping surfaces particularly suited for gripping round and flat material • Finish: Black oxidised, anti-corrosion treated ISO: 5746 DIN: 5746 • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Cuts from 1.0 mm soft wire to 1.6 mm hard wire • Chrome plated finish ISO: 5746 DIN: 5746 Product code L mm A mm B mm C mm 2628 S-180 2628 S-200 180 200 25 27 36 39 11 12 Weight g 2.0 2.5 265 310 Product code L mm A mm B mm C mm 2678V-160 2678V-180 2678V-200 160 180 200 23 26 29 33 37 41 11 12 12 Weight g 1.8 2.0 2.5 250 390 500 Snipe nose pliers Snipe nose pliers dipped insulation • 1 component insulated handles up to 1000 volts • Slim, semi-circular shaped and serrated jaws • Cutting capacity: 1.6 mm hard steel wire • Accurately machined jaws providing a sure grip on the workpiece • Sharp edges for cutting softer material such as copper wire and plastic insulated wire • Finish: Black oxidised, anti-corrosion treated ISO: 5745 DIN: 5745 Product code L mm A mm B mm C mm E mm 2430 S-200 200 17 72 9 2.5 • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Cutting capacity from 1.0 mm soft wire to 1.6 mm hard wire • Chrome plated finish ISO: 5745 DIN: 5745 Weight g 1.6 200 Product code L mm A mm B mm C mm E mm 2430V-160 2430V-200 160 200 16 17 49 72 8 9 2.5 2.5 Weight g 1.6 1.6 200 205 Snipe nose pliers bent tip 60° Snipe nose pliers bent tip 60° dipped insulation • 1 component insulated handles up to 1000 volts • Tips angled at 60° • Cutting capacity: 1.6 mm hard steel wire • Slim, semi-circular shaped and serrated jaws • Accurately machined jaws providing a sure grip on the workpiece • Sharp edges for cutting softer material such as copper wire and plastic insulated wire • Finish: Black oxidised, anti-corrosion treated ISO: 5745 DIN: 5745 Product code L mm A mm B mm C mm E mm 2427 S-200 200 17 70 9 2 • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Tips angled at 60° • Cutting capacity from 1.0 mm soft wire to 1.6 mm hard wire • Chrome plated finish ISO: 5745 DIN: 5745 Weight g 1.6 200 6 Product code L mm A mm B mm C mm E mm 2427V-200 200 17 70 9 2 Weight g 1.6 205 Round nose pliers dipped insulation • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Good grip and improved accessibility in confined spaces • Chrome plated finish ISO: 5745 DIN: 5745 • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Suited for wire-bending work • Chrome plated finish ISO: 5745 DIN: 5745 Product code 2421V-160 L mm 160 A mm B mm 16.5 C mm 49 8.5 D mm E mm 3 5 Weight g 205 Product code L mm A mm B mm C mm E mm Weight g 2521V-160 160 16 42 7 1.5 205 Wire stripping pliers Wire stripping pliers dipped insulation • 1 component insulated handles up to 1000 volts • Maximum cable diameter 5 mm; Maximum cable section 10 mm2 • Finish: Black oxidised, anti-corrosion treated • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Maximum cable diameter 5 mm; Maximum cable section 10 mm2 • Chrome plated finish Product code L mm A mm B mm C mm Cable Ø Area Weight g 2223 S-150 167 15 46 8 0.5-5 0.05-10 170 Product code L mm A mm B mm C mm Cable Ø Area Weight g 2223V-160 160 15 46 8 0.5-5 0.05-10 205 Slip joint pliers “box joint” dipped insulation Slip joint pliers “groove joint” dipped insulation • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Both flat and pipe grip jaws; Self locking jaws grip tightly at 3 points • Finish: Black oxidised, anti-corrosion treated ISO 8976 • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Both flat and pipe grip jaws; Self locking jaws grip tightly at 3 points • Chrome plated finish ISO 8976 Product code L mm A mm B mm C mm Weight g 2619V-250 2619V-300 250 300 35 43 33 44 8 8 450 770 7 Product code L mm A mm B mm C mm Weight g 6224V 250 32 35 11 450 1000 V Pliers Flat nose pliers dipped insulation Cable cutter for copper & aluminium 1000 V Pliers Ratchet action cable cutter dipped insulation • 1 component insulated handles up to 1000 volts • Cable cutter to cut Aluminium/Copper cables with or without messenger wire Recommended maximum capacity: Al-Cu diameter of 30 mm with a messenger wire (1800 N/mm2) of 6 mm WARNING: FOR A MAXIMUM SERVICE LIFE, THE SHARPENED PARTS OF THE BLADES MUST NEVER BE USED ON FERROUS MATERIAL. FOR THIS PURPOSE, USE THE NOTCHES ON THE BLADES • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • One hand operation; effortless cutting. Easy release movable jaw • For cutting copper and aluminium cables • Not suitable for hard copper, steel cables, or internal steel wire cables • Clean and smooth cut without distortion Cutting capacity table Multiple copper wire cables 2806-35v Ø35 Max. area 240 mm2 2806-52v Ø52 Max. area 400 mm2 Sectioned copper wire cables Max. area 240 mm2 Max. area 400 mm2 Copper cables with flexible material Max. outside Ø35 Max. outside Ø52 Multiple Aluminium wire cables Max. outside Ø35 Max. outside Ø52 Sectioned Aluminium wire Max. outside Ø35 Max. outside Ø52 Product code L mm A mm Weight g 2806-35V 2806-52V 255 340 35 52 800 900 Product code L mm 2520 S 552 mm Weight g 30 2200 Cable cutter dipped insulation • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Not suitable for hard copper or steel cables, or internal steel wire cables Size mm Maximum opening mm Ext. Ø Al - Cu 170 15 14 14 230 22 20 20 Product code L mm A mm B mm C mm Weight g 2250V-170 2250V-230 170 230 29 38 16 21 10 12 320 560 Cable cutter for copper & aluminium dipped insulation • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Not suitable for hard copper or steel cables, or internal steel wire cables • Finish: Black oxidised, anti-corrosion treated Size mm Maximum opening mm 210 25 Bolt cutter dipped insulation • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Forged head; Induction hardened cutting edges • Long arms with lever-action head, which allows to cut hard wires with very low efforts Ext. Ø Al - Cu 18 18 Product code L mm A mm B mm C mm Weight g 2260V-210 210 30 34 11 375 8 Wire types Ø mm Product code L mm 80kg/mm2 120kg/mm2 160kg/mm2 Weight g 2820VBC 630 9 8 7 3100 1000 V SCREWDRIVERS 9 1000 V Ergo™ Screwdrivers The design of ergonomic tools within Bahco is based on a scientifically recognised 11-point programme. This programme covers facts and experiences gathered from users, ergonomists, industrial designers, research and development departments as well as extensive testing and trials together with end-users of our tools. This method is unique within the tool industry and to ensure that you can always see which tools have been developed according to this programme, each one is marked with the Ergo™ symbol. Colour coded handles showing tip type for quick application identification. Insulated screwdrivers ErgoTM Phillips® Slotted tips Insulated screwdriver for Phillips® PH-head screws, for work on live equipment up to 1000 volts DIN 7438. Tip DIN ISO 8764-1, ISO 8764-1 BE-8640S with two handed grip Phillips® tips Product code Pozidriv® tips BE-8600S BE-8610S BE-8620S BE-8630S BE-8640S Hexagonal Socket tips mm 0 1 2 3 4 75 80 100 150 200 mm mm Weight g 16x102 20x122 27x122 36x122 36x161 162 202 222 272 361 20 60 100 175 240 Torx® tips Insulated screwdrivers ErgoTM Pozidriv® Screwdriver for Pozidriv® PZ head screws, for work on live equipment up to 1000 volts DIN 7438. Tip DIN ISO 8764-1, ISO 8764-1 BE-8840S with two handed grip Insulated screwdrivers Ergo TM IEC 60900, EN 60900, DIN-EN 60900, VDE 0682 part 201. • Ergonomically developed 3-component handle of polypropylene and thermoplastic elastomere. • Colour coded handles showing tip type for quick application identification. • Black oxide tips, entirely hardened made of Molybdenum-Vanadium steel Product code BE-8800S BE-8810S BE-8820S BE-8830S BE-8840S mm 0 1 2 3 4 60 80 100 150 200 mm 16x102 20x122 27x122 36x122 36x161 mm Weight g 162 202 222 272 361 19 60 100 175 222 Insulated screwdrivers ErgoTM slotted Insulated screwdriver for slotted head screws, for work on live equipment up to 1000 volts DIN 7437. Tip DIN 5264-A, ISO 2380-1-A Product code mm mm mm BE-8010S BE-8220S BE-8230S BE-8040S BE-8050S BE-8255S BE-8065S 0.4 0.5 0.6 0.8 1.0 1.2 1.2 2.5 3.0 3.5 4.0 5.5 6.5 8.0 75 100 100 100 125 150 175 mm 16x102 16x102 20x122 20x122 27x122 36x122 36x122 mm Weight g 177 202 222 222 247 272 297 18 25 30 40 70 124 195 Insulated screwdrivers ErgoTM hexagon socket-head screws Insulated screwdriver for hexagon socket-head screws, for work on live equipment up to 1000 volts DIN 7439. Tip DIN ISO 2936 Product code BE-8725S BE-8703S BE-8704S BE-8705S BE-8706S BE-8708S 10 mm 2.5 3 4 5 6 8 75 75 75 75 100 100 mm 16x102 20x122 20x122 27x122 27x122 36x122 mm Weight g 177 197 197 197 222 222 22 25 41 65 97 178 Insulated screwdriver for Torx® head screws, for work on live equipment up to 1000 volts Product code BE-8910S BE-8915S BE-8920S BE-8925S BE-8930S D T10 T15 T20 T25 T30 2.74 3.27 3.86 4.43 5.52 mm 65 70 80 80 100 mm 20x122 20x122 27x122 27x122 36x122 mm Weight g 187 192 202 202 222 34 35 55 61 96 Insulated screwdrivers sets ErgoTM Sets of insulated screwdrivers for work on live equipment up to 1000 volts Standards slotted: DIN 7437. Tip DIN 5264-A, ISO 2380-1-A Standards Phillips® / Pozidriv®: DIN 7438. Tip DIN ISO 8764-1, ISO 8764-1 Product code BE-9881S BE-9882S BE-9888S Insulated screwdrivers ErgoTM combi tips PH 0.5x3x100 0.8x4x100 1x5.5x125 0.5x3x100 0.8x4x100 1x5.5x125 0.4x2.5x75 0.5x3.0x100 0.8x4.0x100 1.0x5.5x125 PZ PH1x80 PH2x100 Weight g 450 PZ1x80 PZ2x100 450 PZ0x60 PZ2x100 PZ3x150 530 IEC 60900, EN 60900, DIN-EN 60900, VDE 0682 part 201 • Combi (mixed) tips: slotted and PH / slotted and PZ • For use on electric racks and terminals • More powerful tightening and minimizes come-out effect • New insulated blade for live use in live systems up to 1000 V AC and 1500 V DC (low voltage) • Handle: 3-injection handle with tip colour coding Insulated screwdrivers set ErgoTM combi tips Insulated screwdrivers ErgoTM combi tips Phillips® / slotted Product code BE-8510S BE-8520S 5 / PH1 6 / PH2 mm mm mm Weight g 80 100 20x122 27x122 202 222 60 100 • Combi (mixed) tips: slotted and PH / slotted and PZ • For use in electric racks and terminals • More powerful tightening and minimizes come-out effect • New Insulated blade for live use in live systems up to 1000 V AC and 1500 V DC (low voltage) • Handle: 3-injection handle with tip colour coding • Includes a voltage tester 806-1-1 Product code BE-9885S Includes 5 / PH1 6 / PH2 5 / PZ1 6 / PZ2 370 Voltage tester 806-1-1 V Insulated screwdrivers ErgoTM combi tips Pozidriv® / slotted Product code BE-8710S BE-8720S 5 / PZ1 6 / PZ2 mm mm mm Weight g 80 100 20x122 27x122 202 222 60 100 11 Weight g 1000 V Ergo™ Screwdrivers Insulated screwdrivers ErgoTM Torx® head screws 1000 V 800 Series Screwdrivers Insulated screwdrivers 800 Series Insulated screwdrivers 800 Series Phillips® • 2-Component handle made of polypropylene and thermoplastic elastomere • Blade of Molybdenum-Vanadium steel, entirely hardened IEC 60900, DIN-EN 60900, EN 60900, VDE 0682 part 201 Insulated screwdriver for Phillips® PH-head screws, for work on live equipment up to 1000 volts Tip DIN ISO 8764-1, ISO 8764-1 Product code Insulated screwdrivers 800 Series slotted 815VDE-0-100 815VDE-1-150 815VDE-2-175 815VDE-3-200 815VDE-4-200 Insulated screwdriver for slotted head screws for work on live equipment up to 1000 volts DIN 7437. Tip DIN 5264-A, ISO 2380-1-A Product code mm mm mm mm mm Weight g 813VDE-3-100 813VDE-3,5-100 813VDE-4-100 813VDE-5,5-125 813VDE-6,5-150 813VDE-8-175 813VDE-10-200 813VDE-12-200 0.5 0.6 0.8 1.0 1.2 1.2 1.6 2.0 3.0 3.5 4.0 5.5 6.5 8.0 10.0 12.0 100 100 100 125 150 175 200 200 27x90 27x90 27x90 30x100 33x110 36x120 36x120 36x120 190 190 190 225 260 295 320 320 40 40 40 60 90 110 175 205 mm 0 1 2 3 4 mm 100 150 175 200 200 27x90 33x110 33x110 36x120 36x120 mm Weight g 190 260 285 320 320 40 75 110 175 200 Insulated nut drivers 800 Series Insulated nutdriver for work on live equipment up to 1000 volts Hexagon opening tolerance DIN ISO 691, ISO 691 Product code 817V-6 817V-7 817V-8 817V-10 817V-13 6 7 8 10 13 mm mm mm Weight g 120 120 120 120 120 30x100 33x110 33x110 36x120 36x120 220 230 230 240 240 85 120 120 145 170 Insulated screwdrivers 800 Series Pozidriv® Insulated screwdriver for Pozidriv® PZ head screws for work on live equipment up to 1000 volts Tip DIN ISO 8764-1, ISO 8764-1 Product code 816VDE-0-100 816VDE-1-150 816VDE-2-175 816VDE-3-200 0 1 2 3 mm mm mm Weight g 100 150 175 200 27x90 33x110 33x110 36x120 190 260 285 320 40 75 105 175 Insulated screwdrivers sets 800 Series Insulated screwdrivers for work on live equipment up to 1000 volts IEC 60900, DIN-EN 60900, EN 60900, VDE 0682 part 201 PH Product code 820VDE-5 822VDE-5 12 0.6x3.5x100 0.8x4x100 1.2x6.5x150 0.5x3.0x100 0.8x4x100 1.0x5.5x125 PZ PZ1x150 PZ2x175 PH1x150 PH2x175 Weight g 360 360 IEC Insulated screwdrivers 600 Series Phillips® 625 • Insulated blade for live use in live systems up to 1000 V AC and 1500 V DC (low voltage) • Professional quality at a highly competitve price • Voluminous 2 component handle giving an effective transmission of the allied tightening torque • Molybdenum-Vanadium steel Insulated screwdriver for Phillips® PH-head screws, for work on live equipment up to 1000 volts Tip DIN ISO 8764-1, ISO 8764-1 Product code 625-0-100 625-1-150 625-2-175 IEC Insulated screwdrivers 600 Series slotted 623 0 1 2 mm mm mm Weight g 100 150 175 80 97 110 180 247 285 32 68 116 Insulated screwdriver for slotted head screws for work on live equipment up to 1000 volts DIN 7437. Tip DIN 5264-A, ISO 2380-1-A Product code mm mm mm 623-3-100 623-3.5-100 623-4-100 623-5.5-125 623-6.5-150 0.5 0.6 0.8 1.0 1.2 3.0 3.5 4.0 5.5 6.5 100 100 100 125 150 mm 80 80 80 97 100 mm Weight g 180 180 180 223 250 32 32 33 61 94 IEC insulated screwdriver 600 Series 6 pcs set • Insulated screwdrivers for slotted and Phillips® head screws, for work on live equipment up to 1000 volts • Blister pack Product code 620-6 13 PH 0.5x3.0x100 0.8x4.0x100 1.0x5.5x125 1.2x6.5x150 PH1x150 PH2x175 Weight g 472 1000 V 600 Series Screwdrivers Insulated screwdrivers 600 Series 1000 V SPANNERS, SOCKETS & WRENCHES 14 Offset ring spanner dipped insulation • 2 layers of insulation coating with different colours plus a 3rd one in black to further protect handle edges on spanners from 6 mm to 16 mm. Red: safety. Yellow: danger • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges on spanners from 17 mm to 32 mm. Red: safety Orange: danger. Yellow: high danger • Material: Chrome-Vanadium steel Opening tolerance according to ISO 691 • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: Safety. Orange: Danger. Yellow: High Danger • Material: Chrome-Vanadium steel • 12 point Dynamic-Drive Profile Opening tolerance according to ISO 691 Product code 6MV-6 6MV-7 6MV-8 6MV-9 6MV-10 6MV-11 6MV-12 6MV-13 6MV-14 6MV-15 6MV-16 6MV-17 6MV-18 6MV-19 6MV-20 6MV-21 6MV-22 6MV-23 6MV-24 6MV-27 6MV-30 6MV-32 mm L mm A mm B mm Layers coating 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 27 30 32 92 92 92 98 108 116 125 135 140 150 157 162 170 175 180 184 193 203 210 225 240 250 15.0 17.5 18.0 21.0 24.0 26.0 28.0 31.0 31.0 33.0 34.0 37.0 39.0 42.0 43.0 46.0 47.0 49.0 51.0 59.0 63.0 68.0 3.7 3.7 4.0 4.0 5.0 5.0 5.5 5.5 6.0 6.0 6.5 6.5 7.0 7.0 7.5 7.5 7.5 8.0 8.5 9.5 10.0 10.0 2 2 2 2 2 2 2 2 2 2 2 3 3 3 3 3 3 3 3 3 3 3 Product code 2MV-6 2MV-7 2MV-8 2MV-9 2MV-10 2MV-11 2MV-12 2MV-13 2MV-14 2MV-15 2MV-16 2MV-17 2MV-18 2MV-19 2MV-21 2MV-22 2MV-23 2MV-24 Weight g 25 30 40 45 55 60 70 75 85 90 105 120 145 150 170 190 190 220 275 370 470 530 mm 6 7 8 9 10 11 12 13 14 15 16 17 18 19 21 22 23 24 L mm A mm B mm C mm Weight g 140 145 150 155 160 170 180 180 190 195 200 205 215 225 235 245 255 265 5.0 6.0 6.0 6.5 7.0 7.5 8.0 8.5 8.5 9.5 9.5 10.0 10.5 11.0 12.0 12.0 13.0 13.0 10.5 12.0 13.0 14.5 16.0 18.0 18.5 20.5 22.0 24.0 24.5 26.5 27.0 29.0 32.0 33.0 35.0 35.0 18 18 19 19 21 21 23 23 24 24 26 26 28 28 30 30 30 32 50 55 70 75 80 90 100 105 130 140 150 160 210 230 280 300 320 350 Adjustable wrench fully dipped insulation Adjustable wrench dipped insulation • 3 layers of insulation coating on the complete wrench with different colours plus a 4th one in black to further protect handle edges. Red: Safety. Orange: Danger. Yellow: High Danger • Chrome-Vanadium steel • The moveable jaw slides easily by smoothly operating the side screw Exceed ISO and ANSI torque requirements • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: Safety. Orange: Danger. Yellow: High Danger • Material: Chrome-Vanadium steel • The moveable jaw slides easily by smoothly operating the thumb screw Complies with ISO and ANSI torque requirements, Head dimensions comply with ISO 6787 standards Product code L mm A mm B mm D mm E mm Weight g 8070V 8071V 8072V 8073V 8074V 165 210 260 310 390 20 24 29 36 43 21.0 26.0 29.5 36.0 45.0 5.5 7.5 9.0 11.0 14.0 12.0 13.5 16.0 19.0 21.0 175 370 540 820 1400 15 Product code L mm A mm C mm Weight g 8071VLT 8072VLT 8073VLT 205 255 305 29 34 39 22 25 29 360 690 1060 1000 V Spanners, sockets & wrenches Open-end spanner dipped insulation 1000 V Spanners, sockets & wrenches T-handle socket wrench dipped insulation 1/2” socket dipped insulation • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Material: Chrome-Vanadium steel • 6 point Dynamic-Drive Profile Opening tolerance according to ISO 691 • 2 layers of insulation coating with different colours. Red: safety. Yellow: danger • Material: Chrome-Vanadium steel • 12 point Dynamic-Drive Profile Both square and 12 point openings according to the tolerance and torque requirements given in ISO standards Product code 28MV-8 28MV-9 28MV-10 28MV-11 28MV-12 28MV-13 28MV-14 28MV-15 28MV-16 28MV-17 28MV-18 28MV-19 28MV-20 28MV-21 28MV-22 mm L mm A mm B mm C mm M mm Weight g 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 8 8 9 10 11 12 12 13 13 14 15 17 18 18 19 29 30 33 36 42 42 45 47 52 52 55 58 61 62 65 16.5 18.0 19.5 20.5 22.0 23.0 24.5 25.5 27.0 28.0 29.5 30.5 32.5 33.0 34.5 130 130 130 130 140 140 140 140 140 140 140 140 140 140 140 101 143 150 159 216 260 272 312 322 331 421 435 515 531 579 Product code mm A mm B mm C mm L mm Weight g 7800DMV-8 7800DMV-10 7800DMV-11 7800DMV-12 7800DMV-13 7800DMV-14 7800DMV-15 7800DMV-16 7800DMV-17 7800DMV-18 7800DMV-19 7800DMV-20 7800DMV-21 7800DMV-22 7800DMV-24 7800DMV-27 7800DMV-30 7800DMV-32 8 10 11 12 13 14 15 16 17 18 19 20 21 22 24 27 30 32 17.0 19.5 20.5 22.0 23.2 24.5 25.5 27.0 28.2 29.5 30.5 32.0 33.2 34.5 37.0 40.5 44.5 47.0 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 8 8 8 8 8 10 10 10 10 12 12 12 12 14 16 18 20 22 50 50 50 50 50 50 50 50 50 50 50 50 50 52 52 54 56 58 80 82 84 86 88 90 92 95 98 105 115 125 135 140 155 195 210 225 1/2” ratchet dipped insulation • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Material: Chrome-Vanadium steel • One of the buttons is a lever to change the ratcheting direction; the other is a push button to lock or release the socket to the male square drive • 28 teeth ratchet to operate at a 13° angle Complies with the ISO standards. Static and endurance tests with 50000 cycles Product code L mm A mm B mm C mm Weight g 8150-1/2V 270 77 50 12.5 735 1/2” T-handle dipped insulation • 2 layers of insulation coating with different colours plus a 3rd one in black to further protect handle edges. Red: safety. Yellow: danger • Material: Chrome-Vanadium steel • The male square drive has a slotted screw to move the ball outwards or inwards and block or unblock the socket to it The male square tolerances and torque requirements comply with the respective ISO standard 16 Product code L mm A mm Weight g 8154-1/2V 200 190 520 Cross wrench dipped insulation • 2 layers of insulation coating with different colours. Red: safety. Yellow: danger • Material: Chrome-Vanadium steel • The male square drive has a slotted screw to move the ball outwards or inwards and block or unblock the socket to it The male square tolerances and torque requirements comply with the respective ISO standard • 2 layers of insulation coating with different colours Red: safety. Yellow: danger • Material: Chrome-Vanadium steel • 6 point openings with standard profile Opening tolerance according to ISO 691 Product code L mm Weight g 8160-1/2V 8162-1/2V 125 250 220 410 Hexagon key dipped insulation 1999MV-3 1999MV-4 1999MV-5 1999MV-6 1999MV-7 1999MV-8 1999MV-9 1999MV-10 1999MV-12 mm 3 4 5 6 7 8 9 10 12 L mm 210 210 mm 7x9x11x13 8x10x13x17 Weight g 420 420 Safety instructions for working with live system • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Material: Chrome-Vanadium steel Hex dimensions and torque requirements comply with those given in ISO standards Product code Product code 2820V13 2820V17 A mm L1 mm L2 mm Weight g 8 8 8 10 10 10 12 12 12 118 118 117 117 116 116 115 115 114 78 78 78 87 91 100 100 110 124 25 35 50 75 100 145 170 210 300 • Always transport your insulated tools carefully to avoid damage. • Examine each tool for damage before every use. If the insulation is damaged, the tools should not be used. • Keep all tools in good condition with regular maintenance. The insulated tools should be kept clean and dry. • Protective glasses should be worn when working with cutting pliers or working overhead. • Safety requires that work space is kept clean, dry and tidy to prevent accidents when working with live voltage. • Use the right tool correctly: Every tool was designed to do a certain job. Always use it for its intended purpose and use the right tool size. • Always wear the proper personal protective equipment required for the job. Protect your eyes, hands, ears and other body parts. • Make sure that loose and cut-off parts of cables do not fall onto live components. 17 1000 V Spanners, sockets & wrenches 1/2” extension dipped insulation 1000 V OTHER TOOLS & PROTECTIVE EQUIPMENT 18 Hacksaw frame with screen handguard dipped insulation • Insulated hacksaw with 3906-300-18 Sandflex® bi-metal blade • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Insulated hacksaw with 3906-300-18 Sandflex® bi-metal blade • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Handguard for ultimate protection • Supplied with the reliable and shatterproof Sandflex® bi-metal blade 18TPI with excellent cutting performance and wear resistance Product code 2820HSV1 A mm B mm L mm 300 70 450 • Supplied with the reliable and shatterproof Sandflex® bi-metal blade 18TPI with excellent cutting performance and wear resistance Weight g Product code 1100 2820HSV2 A mm B mm L mm Weight g 300 70 450 1360 The Sandflex® blade - The best just got better The virtually unbreakable and shatterproof bi-metal blade with precision ground teeth for all kinds of metal sawing. With a blade back of strong, flexible spring steel and a tooth line in high-alloyed super high speed steel, this blade is guaranteed to stay sharp for a long time. The Sandflex® blade combines, extreme cutting performance and wear resistance, with a high degree of flexibility and is vastly superior to allhard high speed blades or conventional, flexible blades. Stronger, thicker, steadier and cuts faster than any other hacksaw blades! Electrician knife dipped insulation • 3 layers of insulation coating with different colours plus a 4th one in black to further protect handle edges. Red: safety. Orange: danger. Yellow: high danger • Available in straight and curved blade versions Knife with guide • Insulated 1000 V knife with guide • Single layer, injection moulded, with protection cap, printed with 1000 V • Special blade with cable guard shoe for cable dismantling • Stainless steel blade; handle shock resistant plastic Product code A mm B mm L mm Weight g 2820VHELP 38 20 180 70 Product code 2820VP 2820VPC A mm B mm L mm Weight g 50 50 22 23 180 180 130 170 Electrician scissors 150 mm • 2 layer coating: Red: safety. Yellow: danger • Finger guard • The longer handle allows to apply less force to cut a certain wire • 35 mm cutting length Electrician scissors 130 mm • Single layer coating (only red coating) • Small groove in the blade for stripping cables • 50 mm cutting length • Finger guard Product code L mm A mm Weight g SC127V 130 50 100 19 Product code L mm A mm Weight g SC150NGV 150 38 170 1000 V Other tools & protective equipment Hacksaw frame dipped insulation 1000 V Other tools & protective equipment Tweezers dipped insulation Product code L mm Weight g 2820VTEE 150 50 Protective equipment Insulated gloves Cotton gloves • 2820VG05 for use up to 500 V AC and 750 V DC • 2820VG10 for use up to 1000 V AC and 1500 V DC • Made of special natural latex for better fit • Offers protection against electric arcs according to CENELEC ENV 50354 class 2 and IEC 61482-1 • Cold resistance -40° C; Hot resistance 90° C • Light, flexible and comfortable under glove • The high-quality cotton liner and the good fit offer a very good wearing comfort • Cotton Gloves to wear under any type of glove, for the absorption of sweat and for increased comfort Product code Power Supply Volt Size Material thickness Weight g 2820VG05 500 V 10 0.5 mm 235 2820VG10 1000 V 10 1.0 mm 240 THIS ITEM IS NOT INSULATED AND HAS TO BE USED WITH INSULATED GLOVES Product code Size Weight g 2820VGCOT One size 30 Ears where the puller holds the fuse Protection with locking and unlocking button in the inside NH FUSES Puller with locking mechanism Insulated 1000 V fuse puller Insulated 1000 V mat • A kind of glove to hold NH fuses. Sizes 00-3 • It is operated from the inside of the red protection by a locking and unlocking system • With antislide protection and unlocking button Product code 2820VFP • Valid for use up to 5000 V AC • To stand on it and avoid earth connection when operating live systems Complies with EN10204-3.1 Weight g 458 20 Product code L mm W mm Weight g 2820VM 1000 1000 5500 1000 V TOOL CASES AND SETS 21 1000 V Tool cases and sets Insulated tools set 11 pcs • For work on electrical installations • Shock resistant plastic case • Contains standard Bahco Insulated tools • L mm: 320x300x100 / Weight g: 2800 Product code 7811DMV Contents Description Lenght / size 7800DMV Insulated socket 1/2” 8150-1/2V Insulated ratchet 1/2”, 270 mm 270 mm 8154-1/2V Insulated T-handle 1/2” 200 mm 8160-1/2V Insulated extension 1/2” 125 mm 813VDE-5,5-125 Screwdriver VDE slotted 1.0x5.5x125 10, 11, 13, 17, 19, 20, 22 Insulated tools set 10 pcs • For work on electrical installations • A compact resistant case with a basic assortment of 1000 V tools • L mm: 330x240x60 / Weight g: 2000 Product code 3045V-1 Contents Description 2171V-160 Side cutting pliers dipped insulation 160 mm 2678V-180 Combination pliers dipped insulation 180 mm 2223V-150 Wire stripping pliers dipped insulation 160 mm BE-8220S BE-8040S BE-8050S BE-8610S BE-8620S 2820VP Screwdriver Ergo™ slotted Insulated knife straight blade SC127V Electrician scissors Screwdriver Ergo™ Phillips® 22 Lenght / size 0.5x3.0x100 0.8x4.0x100 1.0x5.5x125 PH1X80 PH2X100 180 mm 130 mm • For work on electrical installations • A resistant leather briefcase with metallic reinforcements • Contains standard Bahco Insulated tools • L mm: 430x260x160 / Weight g: 5500 Product code 3045V-2 Contents Description 2171V-160 Side cutting pliers dipped insulation Lenght / size 160 mm 2678V-180 Combination pliers dipped insulation 180 mm 2430V-160 Snipe nose pliers dipped insulation 160 mm 2223V-150 Wire stripping pliers dipped insulation 160 mm BE-8220S BE-8040S BE-8050S BE-8255S BE-8610S BE-8620S 6MV Screwdriver Ergo™ slotted 0.5x3.0x100 0.8x4.0x100 1.0x5.5x125 1.2x6.5x150 Screwdriver Ergo™ Phillips® PH1x80 PH2x100 Safety open end spanner dipped insulation 10, 11, 12, 13, 14, 17, 19 2820VP Insulated knife straight blade 180 mm SC150NGV Electrician scissors 150 mm Open end spanner set • For work on electrical installations • 8 pieces set in plastic rollup • Weight g: 880 Product code 6MV/8T Contents Description 6MV Safety open end spanner 23 Lenght / size 10, 11, 12, 13, 14, 17, 18, 19 1000 V Tool cases and sets Insulated tools set 19 pcs 24 IND-0490-INT
2820VTEE 价格&库存
很抱歉,暂时无法提供与“2820VTEE”相匹配的价格&库存,您可以联系我们找货
2820VTEE
    库存:1
    2820VTEE
      • 1+343.19842
      库存:1
