3834-ARBR-930
3834-ARBR-930
    BAHCO(实耐宝)
    BAHCO - 3834-ARBR-930 - Bit, Arbor, Chuck, 8.5 mm Bit Size
3834-ARBR-930 数据手册
BA-10565_Holesaw_UK_HI 01-11-01 13.59 Sidan 6 Sandflex® means world-class know-how and quality. M-2320-UK NOV 2001 newton Sandflex program of holesaws is the result of more than 25 years of purposeful research and development – an effort that has given us superior know-how in the field of metal cutting techniques. It is this unique know-how that gives Sandflex saws and sawblades an unchallenged leadership in the world marketplace. Quality, performance and availability are the key words in our entire operation. This is why we design our products in close cooperation with customers and users all over the world, continuously taking note of their views and expressed needs and using them in our development work. To us, quality is a concept that goes far beyond just product development. This reflects in our extensive effort to give our customers the best support there is. Making the end users everyday work a bit easier by providing practical advice and information is an important part of that effort. The new Sandflex packaging system is the most recent example of that. BA-10565_Holesaw_UK_HI 01-11-01 13.59 Sidan 3 The right saw and arbor combination in a flash. The new Sandflex packaging system makes finding and combining the right saw and the right arbor an easy task. Dimensions and information on suitable arbors for various types of jobs are also given on each individual package. Each package is also marked with its EAN-code, to facilitate handling of your stock. 630 730 930 1130 9100 Arbors 11152 Product code EAN-code 731151+ Dim. mm / inch 3834-ARBR-630-C 3834-ARBR-730-C 3834-ARBR-930-C 3834-ARBR-1130-C 8228576 8225674 8225681 8228583 6,4 7,0 8,5 11,1 1/4 9/32 11/32 7/16 3834-ARBR-9100-C 3834-ARBR-11152-C 3834-ARBR-9100QC-C 3834-ARBR-11152QC-C 8228590 8225698 8225704 8225711 8,5 11,1 8,5 11,1 11/32 7/16 11/32 7/16 9100QC 11152QC For accessories and complete assortment, please refer to our main catalog. BA-10565_Holesaw_UK_HI 01-11-01 13.59 Sidan 4 The new Sandflex® – a complete family of high-performance holesaws. Holesaws 9/16 – 1 3/16 ” Dim. mm / inch Ø 14 – 30 mm For many years now, Sandflex holesaws have been the standard of comparison for precision, quality and flexibility of use. The new, orange version will carry this tradition further, in a complete family of saws and arbors that will each meet your most demanding requirements for performance and durability. The Sandflex family name is your guarantee for that. Ø 32 – 76 mm 1 1/4 – 3 ” Ø 14 – 30 mm 9/16 – 1 3/16 inch Ø 79 – 152 mm 3 1/8 – 6 ” Ø 32 – 76 mm 1 1/4 – 3 inch Ø 79 – 152 mm 3 1/8 – 6 inch Productcode EAN-code 731151+ 9/16 5/8 11/16 3/4 25/32 13/16 7/8 15/16 1 1 1/16 1 1/8 1 3/16 3830-14-C 3830-16-C 3830-17-C 3830-19-C 3830-20-C 3830-21-C 3830-22-C 3830-24-C 3830-25-C 3830-27-C 3830-29-C 3830-30-C 8228347 8225353 8228354 8225360 8225377 8228361 8225384 8228378 8225391 8225407 8225414 8225421 32 1 1/4 33 1 5/16 35 1 3/8 37 1 7/16 38 1 1/2 40 1 9/16 41 1 5/8 43 1 11/16 44 1 3/4 46 1 13/16 48 1 7/8 51 2 52 2 1/16 54 2 1/8 56 2 3/16 57 2 1/4 59 2 5/16 60 2 3/8 64 2 1/2 65 2 9/16 67 2 5/8 68 2 11/16 70 2 3/4 73 2 7/8 76 3 3830-32-C 3838-33-C 3830-35-C 3830-37-C 3830-38-C 3830-40-C 3830-41-C 3830-43-C 3830-44-C 3830-46-C 3830-48-C 3830-51-C 3830-52-C 3830-54-C 3830-56-C 3830-57-C 3830-59-C 3830-60-C 3830-64-C 3830-65-C 3830-67-C 3830-68-C 3830-70-C 3830-73-C 3830-76-C 8225438 8228385 8225445 8228392 8225452 8228408 8225469 8228415 8225476 8228422 8225483 8225490 8228439 8225506 8228446 8225513 8228453 8225520 8225537 8228460 8225544 8228477 8225551 8228484 8225568 3830-79-C 3830-83-C 3830-86-C 3830-89-C 3830-92-C 3830-95-C 3830-98-C 3830-102-C 3830-105-C 3830-108-C 3830-111-C 3830-114-C 3830-121-C 3830-127-C 3830-133-C 3830-140-C 3830-146-C 3830-152-C 8228491 8225575 8228507 8225582 8225599 8225605 8228514 8225612 8225629 8228521 8228538 8225636 8225643 8225650 8228545 8228552 8228569 8225667 14 16 17 19 20 21 22 24 25 27 29 30 79 83 86 89 92 95 98 102 105 108 111 114 121 127 133 140 146 152 3 3 3 3 3 3 3 4 4 4 4 4 5 5 5 1/8 1/4 3/8 1/2 5/8 3/4 7/8 4 1/8 1/4 3/8 1/2 3/4 5 1/4 1/2 3/4 6 HOLESAWS BAHCO Industrial holesaws Power Driver PD Arbors stabilises the sawing operation and distributes efficiently the cutting forces on the saw. Slots for removal of cores SANDFLEX® bi-metal body for increased safety Holesaws can be easily fitted or removed with the Arbor fixed in the power drill. HSS pilot drill Hardened body for maximum strength SANDFLEX® holesaws designed for metalcutting Bahco`s Sandflex® holesaws have a 4/6 tooth shape. By varying the distance between the teeth ( vari- pitch ) a smoother cut is achieved with less vibration, even in difficult-to-cut materials. The aggressive tooth shape cuts fast, whilst the large tooth gullets and large tooth set make swarf removal more efficient. All VIP holesaws are manufactured from SANDFLEX® bi-metal steel with hardened teeth of high alloyed high -speed steel ( HSS ). Bi-metal gives increased safety as it will not shatter if overloaded. It enables the highest cutting performance in all machinable materials from wood to stainless steel, and it gives increased resistance to wear. All Bahco’s holesaws • 38 mm ( 1 1/2” ) cutting depth. • Solid, flat cap design to withstand heavy workload. • All sizes are in millimetres. The following are general points regarding the use of Bahco hole saws. • Clamp the workpiece firmly. • Selection of arbor - Select the proper arbor for the hole saw size and your power drill. If the arbor has drive pins, make sure they are engaged. For arbors with drive pins, slide pin ring back, screw hole saw onto arbor to shoulder, and push ring with pins into hole saw while backing off hole saw if necessary. • Maintain positive feed rate, but exercise care not to abruptly feed saw into work. Always start operation perpendicular to the workpiece. • Removal of chips - is extremely important. Intermittent withdrawal of holesaw is recommended to prevent clogging in the gullet area. • Operation speeds ( RPM ) - The cutting speeds recommended in the table are intended as a general guide. Your experience may show that the variations from these general recommendations ensure better performance. Ejector spring to facilitate core removal Hardened HSS toothing • Always use a lubricant when sawing in metal. It gives better performance and prolongs the life of the holesaw. • A water coolant may be helpful when cutting ceramic tile. Plenty of water may be required. • Use an arbor with a carbide tipped pilot drill when cutting ceramic tile, firebrick and other abrasive materials. • When cutting fibreglass, glass reinforced plastics, bakelite and similar materials, reduce speed so that materials do not soften or clog the gullets of the saw. Carbide tipped holesaws for cutting in hard, abrasive materials On our new carbide tipped holesaws the tooth tips consist of a carbide ”round rod” which is fusion welded to the back material. The tip is then ground to its final shape with 5 degrees positive cutting angle. CT holesaws open new possibilities to cut holes in materials such as light concrete, brick, tile, reinforced plastics and other abrasive non-ferrous materials. Carbide tipped hole saws are not recommended for cutting ferrous materials ( steel ). HOLESAWS BAHCO When sawing in thick and difficult-to-cut materials, it may help to drill a few holes in the periphery of the circle, which greatly facilitates swarf removal. When sawing in wood finish off the sawing operation from the reverse side to avoid splinters. Place an oil-imbibed sponge in the holesaw if you • cannot lubricate normally. • are sawing in stainless steel. • are sawing in a difficult-to-reach position ( e.g. from underneath the material ) You may use your holesaw to manufacture your own sponge. Saw into a normal car sponge without using the pilot drill. Engage this afterwards. Operating speeds VIP holesaws Size MM 14 16 17 19 20 21 22 24 25 27 29 30 32 33 35 37 38 40 41 43 44 46 48 51 52 54 56 57 59 60 64 65 67 68 70 73 76 79 83 86 89 92 95 98 102 105 108 111 114 121 127 133 140 146 152 168 177 210 Size INCH 9/16 5/8 11/16 3/4 25/32 13/16 7/8 15/16 1 1 1/16 1 1/8 1 316 1 1/4 1 5/16 1 3/8 1 7/16 1 1/2 1 9/16 1 5/8 1 11/16 1 1 13/16 1 7/8 2 2 1/16 2 1/8 2 7/32 2 2 5/16 2 3/8 2 1/2 2 9/16 2 5/8 2 11/16 2 2 7/8 3 3 1/8 3 3 3/8 3 1/2 3 5/8 3 3 7/8 4 4 1/8 4 4 3/8 4 1/2 4 5 5 5 1/2 5 6 6 5/8 7 8 1/4 Mild steel 580 550 500 460 440 425 390 370 350 325 300 285 275 260 250 240 230 220 210 205 195 190 180 170 165 160 150 150 145 140 135 130 130 130 125 120 115 110 105 100 95 95 90 90 85 80 80 80 75 75 65 60 60 55 55 50 45 40 Cast iron 400 365 330 300 290 280 260 245 235 215 200 190 180 175 165 160 150 145 140 135 130 125 120 115 110 105 100 100 100 95 90 85 85 85 80 80 75 70 70 65 65 60 60 60 55 55 55 50 50 50 45 40 40 35 35 35 35 25 Tool and stainless steel 300 275 250 230 220 210 195 185 175 160 150 145 140 135 125 120 115 110 105 100 95 95 90 85 80 80 75 75 75 70 65 65 65 65 60 60 55 55 50 50 45 45 45 45 40 40 40 40 35 35 30 25 25 25 25 25 25 20 Operating speeds CT holesaws AlumBrass inium Wood 790 900 3000 730 825 3000 665 750 3000 600 690 3000 580 660 3000 560 635 3000 520 585 3000 495 555 3000 470 525 2700 435 480 2700 400 450 2700 380 425 2400 380 410 2400 345 390 2400 330 375 2400 315 360 2400 300 345 2400 290 330 2100 280 315 2100 270 305 2100 260 295 2100 259 285 2100 240 270 2100 230 255 2000 220 245 2000 210 240 2000 200 225 2000 200 225 2000 195 225 2000 190 220 2000 180 205 1800 175 200 1800 170 195 1800 170 195 1800 160 185 1800 160 180 1800 150 170 1800 140 165 1500 140 155 1500 130 150 1500 130 145 1200 120 140 1200 120 135 1200 120 135 1200 110 130 1000 110 120 1000 110 120 900 100 120 900 100 105 900 95 95 900 90 90 800 85 85 800 85 85 800 75 75 800 75 75 800 65 75 700 65 75 700 55 60 500 Size MM 14 16 17 19 20 21 22 24 25 27 29 30 32 33 35 37 38 40 41 43 44 46 48 51 52 54 56 57 59 60 64 65 67 68 70 73 73 79 83 86 89 92 95 98 102 105 108 111 114 121 127 133 140 146 152 Size INCH 9/16 5/8 11/16 3/4 25/32 13/16 7/8 15/16 1 1 1/16 1 1/8 1 316 1 1/4 1 5/16 1 3/8 1 7/16 1 1/2 1 9/16 1 5/8 1 11/16 1 1 13/16 1 7/8 2 2 1/16 2 1/8 2 7/32 2 2 5/16 2 3/8 2 1/2 2 9/16 2 5/8 2 11/16 2 2 7/8 3 3 1/8 3 3 3/8 3 1/2 3 5/8 3 3 7/8 4 4 1/8 4 4 3/8 4 1/2 4 5 5 5 1/2 5 6 Fire brick Ceramic tile 680 610 560 510 480 470 430 410 380 360 340 320 310 290 280 270 260 240 235 230 220 210 205 190 185 180 175 170 165 160 150 148 145 142 140 135 130 125 120 115 110 105 100 98 95 92 90 87 85 80 75 72 70 67 65 Soft brick Slate 1705 1535 1395 1280 1210 1180 1095 1020 960 900 850 810 770 730 700 670 640 615 590 570 550 530 510 480 465 450 435 430 415 405 380 370 365 360 350 330 320 310 295 285 270 260 255 250 240 235 230 220 210 200 190 180 170 165 160 Plywood 3400 3060 2785 2550 2430 2355 2180 2040 1920 1800 1700 1610 1530 1460 1390 1330 1280 1220 1180 1130 1100 1060 1020 960 930 900 870 850 830 810 760 750 730 720 700 670 640 610 590 570 550 530 510 490 480 460 450 440 420 400 380 365 350 335 320 Fibre glass 2380 2140 1950 1790 1700 1650 1530 1430 1340 1260 1190 1130 1070 1020 980 930 890 860 820 790 770 740 710 670 650 630 610 600 580 560 540 530 510 500 490 470 450 430 410 400 380 370 360 350 330 320 310 300 290 280 270 255 240 230 220 Bakelite 1030 930 850 770 730 710 660 620 580 550 510 490 460 440 420 400 390 370 360 340 330 320 310 290 280 270 265 260 250 240 230 225 220 215 210 200 190 185 180 170 165 160 155 150 145 140 135 130 128 120 110 105 100 95 90 Hard Wood 1360 1220 1110 1020 970 940 870 810 760 720 680 640 610 580 550 530 510 490 470 450 430 420 410 380 370 360 345 340 330 320 310 300 290 285 280 270 260 250 240 230 220 210 200 195 190 185 180 175 170 160 150 145 140 135 130
3834-ARBR-930 价格&库存
很抱歉,暂时无法提供与“3834-ARBR-930”相匹配的价格&库存,您可以联系我们找货
