2101G-125
2101G-125
    BAHCO(实耐宝)
    BAHCO - 2101G-125 - Cutter, Side, 133 mm, Straight, 2 mm, Bahco - 2101G Series Cutters
2101G-125 数据手册
Pliers Bahco -1. Pliers -1.1. SIDE CUTTERS • • • • • • • • • • • Side cutting pliers developed according to the scientific ERGOTM process ISO 5749 Finish: Black finish, anti-corrosion treated 2101G Material: High performance alloy steel, ERGO™ handles with 2-component combination, thermoplastic surface on tough polypropylene which gives superior grip Induction hardened cutting edges Progressive edges: The cutting radius progresses along the edge in order to cut hard material like piano wire close to the joint and soft materials like copper and plastic insulated wire at the tip Screw joint that provides excellent running and accurate alignment of the cutting edges The distance from the joint to the centre of the cutting edges is reduced: giving greater leverage and increased cutting capacity Round shaped jaws give improved accessibility in confined spaces Equipped with a patented return spring featuring an on/off function IP: Industrial packed Side cutting pliers A mm B mm C mm D mm E mm 2101G-125 7314150106462 5 125 14.2 17.0 8.0 1.0 3.5 1.8 1.6 90 2101G-140 7314150106479 5 140 15.9 19.0 8.0 1.5 3.7 2.0 1.8 120 2101G-160 7314150106486 5 160 17.5 21.0 9.0 2.0 3.8 2.5 2.0 170 2101G-180 7314150106493 5 180 19.4 23.0 10.0 2.0 4.0 2.7 2.3 230 2101G125IP 7314150106516 5 125 14.2 17.0 8.0 1.0 3.5 1.8 1.6 90 2101G140IP 7314150106288 5 140 15.9 19.0 8.0 1.5 3.7 2.0 1.8 120 2101G160IP 7314150106295 5 160 17.5 21.0 9.0 2.0 3.8 2.5 2.0 170 2101G180IP 7314150106523 5 180 19.4 23.0 10.0 2.0 4.0 2.7 2.3 230
2101G-125
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电晶体管开关,具有高输入阻抗和低输出阻抗,适用于高速光耦应用。
3. 引脚分配:EL817有3个引脚,分别为阳极、阴极和发射极。
4. 参数特性:主要参数包括工作温度范围-40~85℃,输入电流1mA,输出电流50mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用6引脚DIP封装。
2101G-125 价格&库存
很抱歉,暂时无法提供与“2101G-125”相匹配的价格&库存,您可以联系我们找货
2101G-125
    • 1+324.07861
    库存:429
