2928-160
2928-160
    BAHCO(实耐宝)
    BAHCO - 2928-160 - Plier, Circlip, 26 mm Jaw, Straight, 160 mm
2928-160 数据手册
CIRCLIP PLIERS 2928 Resettable pliers for both internal and external circlips ■■ Adjustable pliers that complete the range of existing conventional circlip pliers ■■ Patented pliers are equipped with interchangeable tips (straight, 15° and 90°) which can easily be adapted for use with internal or external circlips as required 2928-160 ■■ 5 pairs of tips are supplied with the -160 & -200 and 6 pairs with the -250 ■■ For internal circlips from 8 to 100 mm diameter and for external circlips from 3 to 100 mm ■■ The 2928-160 covers a range of applications normally requiring up to ten pliers ■■ Stop mechanism (automatic on the 2928-250 model) for easier use and prevention of damage to circlips from excessive force 2928-250 731415 9938 A B C D mm mm mm mm mm mm mm 0° mm 15° mm 90° 2928-160 0056514 1 160 23.5 21.5 17 7-26 3-26 0.6 0.9 1.2 – 0.9 1.2 120 2928-200 0056521 1 200 32.0 23.5 20 10-51 7-51 0.9 1.2 1.8 – 0.9 1.2 230 2928-250 0056538 1 250 36.0 30.0 22 46-102 32-102 – 2.3 2.7 3.0 2.3 2.7 3.0 505 Circlip pliers, set ■■ Set of three adjustable pliers for both internal and external circlips from the 2928 series: 160 mm, 200 mm and 250 mm ■■ Patented pliers that are equipped with interchangeable tips (straight, 15° and 90°) which can easily be adapted for use with internal or external circlips as required ■■ 5 pairs of tips are supplied with the -160 & -200 and 6 pairs with the -250 ■■ The pliers can be used for internal circlips from 8 to 100 mm diameter and for external circlips from 3 to 100 mm ■■ This set covers a range of applications previously requiring up to ten conventional pliers ■■ Stop mechanism (automatic on the 2928-250 model) for easier use and prevention of damage to circlips from excessive force 731415 9938 2928-160 8-25, 3-25 0056491 1 1640 2928-200 10-48, 10-48 2928-250 31-100, 31-100 579
2928-160 价格&库存
很抱歉,暂时无法提供与“2928-160”相匹配的价格&库存,您可以联系我们找货
    • 1+1258.93918
    库存:5
