3RM090M-5
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs.
■ Stable breakdown voltage.
■ High insulation resistance.
■ Low capacitance (≤2pF)
■ High holdover voltage
■ Large absorbing transient current capability.
■ Micro-Gap Design
■ Size: 5.0mm*7.6mm
■ Storage and operating temperature: -40℃ ~ +90℃
■ Meets MSL level 1, per J-STD-020
■ Safety certification: UL E244458
Applications
Repeaters, Modems.
Telephone Interface, Line cards.
Data communication equipment.
Line test equipment
Part Number Code
3
M
R
Electrical
Characteristics
M: 10KA
Electrode Numbers
3R: 3 Electrodes
M
5
Lead Type
M: SMD
UT7.6:
Internal Control Code
DC
Spark-over
Voltage
Dimensions
5: 5.0mm×7.6mm
Dimensions
B
Symbol
3.3
5.6
D
B1
6.6
D
T
2.0
1.5
Recommended Pad Size
Revision: GDT-3RM090M-5-UT7.6-001(A1)
1/4
Dimension (mm)
Spec.
Tolerance
D
5.0
±0.2
T
7.6
±0.3
B
0.4
±0.1
B1
1.5
±0.2
http://brightking.pulseelectronics.com
3RM090M-5
Electrical Characteristics
Model Number:3RM090M-5
Part Number:3RM090M-5-UT7.6
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,0.2sec
10/1000μs
100A
Test
Voltage
Minimum
Insulation
Resistance
(V)
(V)
(KA)
(A)
(times)
DC(V)
90±20%
600
10
10
300
50
Maximum
Capacitance
1MHz
Device
Marking
Code
(GΩ)
(pF)
1.0
2.0
None
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s. Test is
between each side electrode and center electrode.
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs. Test is between each side electrode and
center electrode.
Maximum surge current that can be applied through center
electrode with 8/20μs waveform, for 10 times with 3min interval
time, which will be equally divided between each side electrode to
center electrode.
Crest value
100
90
Current (%)
Impulse
Discharge Current
To meet
the specified
value
50
20µs
10
8µs
Time
Impulse Width
Alternating
Discharge Current
Insulation
Resistance
Capacitance
Rated RMS value of AC current at 50Hz, 0.2sec. for 10 times with
interval time 3 min. Test is between each side electrode and center
electrode.
The resistance of gas tube shall be measured between each side
electrodes and center electrode.
The capacitance of gas tube shall be measured between each side
electrodes and center electrode. Test frequency: 1MHz
2/4
3RM090M-5
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature
20-40 seconds
(tP)
6℃/second max.
Ramp-down Rate
Time 25℃ to Peak Temperature
8 minutes max.
3/4
3RM090M-5
Packaging
Tape
Dimension (mm)
Symbol
P2
D0
t0
E
P1
B0
W
F
P0
K0
A0
Reel
t
D
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.10
P2
2.00
±0.10
D0
1.50
±0.10
E
1.75
±0.10
F
7.50
±0.10
A0
5.40
±0.10
B0
8.00
±0.10
K0
5.40
±0.10
t0
0.50
±0.10
D
330.00
±1.00
d
13.00
±0.50
L
20.00
±0.50
t
2.00
±0.20
d
L
Quantity: 1000pcs
4/4
很抱歉,暂时无法提供与“3RM090M-5-UT7.6”相匹配的价格&库存,您可以联系我们找货
