621KH14J
621KH14J
    BRIGHTKING(君耀)
    插件
    宽工作电压范围从18V到1800V。快速响应瞬态过电压。大吸收瞬态能量能力。低箝位比且无后续电流。符合MSL等级1,依据J-STD-020标准。工作温度:-40℃至+140℃。存储温度:-40℃至+1...
621KH14J 数据手册
14H SERIES Metal Oxide Varistor (MOV) Data Sheet Features ■ ■ ■ ■ ■ Wide operating voltage (V1mA) range from 18V to 1800V Fast responding to transient over-voltage Large absorbing transient energy capability Low clamping ratio and no follow-on current Meets MSL level 1, per J-STD-020 ■ Operating Temperature:-40℃ ~ +140℃ ■ Storage Temperature:-40℃ ~ +140℃ ■ Safety certification: UL: E327997 TUV:B170296048003 CQC:17001172544 Applications ■ Transistor, diode, IC, thyristor or triac semiconductor protection ■ ■ ■ ■ Surge protection in consumer electronics Surge protection in industrial electronics Surge protection in electronic home appliances, gas and petroleum appliances Relay and electromagnetic valve surge absorption Part Number Code Packaging No suffix: Bulk TB: Tape & Box TR: Tape & Reel Lead Shape No suffix: Straight leads O: Outside crimped leads F: Y kink leads Tolerance K: ±10% Varistor Voltage 180: 18V 101: 100V 102: 1000V Revision: MOV-14H SERIES-001(A2) Surge Series No suffix: Standard type J: High Surge type Element Diameter 05~20 Type H: High temperture 2 / 13 http://brightking.pulseelectronics.com 14H SERIES Dimensions D D T H1 K≤3.0 F e d L1 d1 L1 L K≤3.0 d T H1 H D d F O Type F Type Table 1 Table 2 Unit: mm Unit: mm Symbol Dimension Model T e Model T e H 14.5~20.0 180K 2.55~5.30 1.5 361K 3.38~6.70 2.7 H1 17.0~23.0 220K 2.65~5.44 1.6 391K 3.48~6.88 2.8 L(min.) 20.0 270K 2.76~5.64 1.8 431K 3.61~7.13 3.0 L1(min.) 15.0 330K 2.89~5.83 1.7 471K 3.74~7.37 3.2 D 14.0~17.5 390K 2.84~5.61 1.8 511K 3.87~7.62 3.4 F(±0.8) 7.5 470K 2.96~5.83 1.9 561K 4.03~7.92 3.6 T Table 2 560K 3.11~6.08 2.0 621K 4.23~8.29 3.9 e(±0.8) Table 2 680K 3.31~6.37 2.2 681K 4.43~8.66 4.2 d(±0.05) 0.8 820K 2.64~5.31 1.8 751K 4.65~8.73 4.3 d1(±0.4) 1.4 101K 2.74~5.48 2.0 781K 4.75~8.79 4.4 121K 2.84~5.68 2.2 821K 4.88~9.01 4.6 151K 2.69~5.47 1.8 911K 5.18~9.05 4.8 181K 2.79~5.66 1.9 102K 5.47~9.50 5.1 201K 2.87~5.82 2.0 112K 5.80~10.0 5.4 221K 2.92~5.84 2.1 122K 6.13~10.5 5.6 241K 2.99~5.97 2.2 142K 6.78~11.5 5.9 271K 3.08~6.15 2.4 162K 7.44~12.5 6.5 301K 3.18~6.33 2.5 182K 8.09~13.5 6.9 331K 3.28~6.52 2.5 Revision: MOV-14H SERIES-001(A2) 3 / 13 http://brightking.pulseelectronics.com 14H SERIES Electrical Characteristics Part Number Maximum Allowable Voltage Varistor Voltage Maximum Clamping Voltage Withstanding Surge Current Maximum Energy (10/1000μs) Rated Power Typical Capacitance (Reference) Standard High Surge VAC (V) VDC (V) V1mA (V) IP (A) VC (V) I (A) Standard I (A) High Surge (J) Standard (J) High Surge (W) @1KHz (pf) 180KH14 180KH14J 11 14 18(15~21.6) 10 36 1000 2000 4.0 7.0 0.1 11100 220KH14 220KH14J 14 18 22(19.5~26) 10 43 1000 2000 5.0 8.0 0.1 9100 270KH14 270KH14J 17 22 27(24~31) 10 53 1000 2000 6.0 10.0 0.1 7400 330KH14 330KH14J 20 26 33(29.5~36.5) 10 65 1000 2000 7.5 12.0 0.1 6100 390KH14 390KH14J 25 31 39(35~43) 10 77 1000 2000 8.6 13.0 0.1 5100 470KH14 470KH14J 30 38 47(42~52) 10 93 1000 2000 10.0 17.0 0.1 4300 560KH14 560KH14J 35 45 56(50~62) 10 110 1000 2000 11.0 20.0 0.1 3600 680KH14 680KH14J 40 56 68(61~75) 10 135 1000 2000 14.0 24.0 0.1 2900 820KH14 820KH14J 50 65 82(74~90) 50 135 4500 6000 22.0 27.0 0.6 2400 101KH14 101KH14J 60 85 100(90~110) 50 165 4500 6000 28.0 33.0 0.6 2000 121KH14 121KH14J 75 100 120(108~132) 50 200 4500 6000 32.0 40.0 0.6 1700 151KH14 151KH14J 95 125 150(135~165) 50 250 4500 6000 40.0 53.0 0.6 1300 181KH14 181KH14J 115 150 180(162~198) 50 300 4500 6000 50.0 60.0 0.6 1100 201KH14 201KH14J 130 170 200(180~220) 50 340 4500 6000 57.0 70.0 0.6 1000 221KH14 221KH14J 140 180 220(198~242) 50 360 4500 6000 60.0 78.0 0.6 900 241KH14 241KH14J 150 200 240(216~264) 50 395 4500 6000 63.0 84.0 0.6 830 271KH14 271KH14J 175 225 270(243~297) 50 455 4500 6000 70.0 99.0 0.6 740 301KH14 301KH14J 190 250 300(270~330) 50 500 4500 6000 77.0 108 0.6 670 331KH14 331KH14J 210 275 330(297~363) 50 550 4500 6000 85.0 115 0.6 610 361KH14 361KH14J 230 300 360(324~396) 50 595 4500 6000 93.0 130 0.6 560 391KH14 391KH14J 250 320 390(351~429) 50 650 4500 6000 100 140 0.6 510 431KH14 431KH14J 275 350 430(387~473) 50 710 4500 6000 115 155 0.6 460 471KH14 471KH14J 300 385 470(423~517) 50 775 4500 6000 118 175 0.6 430 511KH14 511KH14J 320 415 510(459~561) 50 845 4500 6000 121 180 0.6 390 561KH14 561KH14J 350 460 560(504~616) 50 925 4500 6000 125 185 0.6 360 621KH14 621KH14J 385 505 620(558~682) 50 1025 4500 6000 128 190 0.6 320 681KH14 681KH14J 420 560 680(612~748) 50 1120 4500 6000 130 200 0.6 290 751KH14 751KH14J 460 615 750(675~825) 50 1240 4500 6000 143 210 0.6 270 781KH14 781KH14J 485 640 780(702~858) 50 1290 4500 6000 148 220 0.6 260 821KH14 821KH14J 510 670 820(738~902) 50 1355 4500 6000 157 235 0.6 240 911KH14 911KH14J 550 745 910(819~1001) 50 1500 4500 6000 175 255 0.6 220 102KH14 102KH14J 625 825 1000(900~1100) 50 1650 4500 6000 190 280 0.6 200 112KH14 112KH14J 680 895 1100(990~1210) 50 1815 4500 6000 213 310 0.6 180 122KH14 122KH14J 750 990 1200(1080~1320) 50 1980 4500 6000 232 324 0.6 160 Revision: MOV-14H SERIES-001(A2) 4 / 13 http://brightking.pulseelectronics.com 14H SERIES Maximum Allowable Voltage Part Number Maximum Clamping Voltage Varistor Voltage Withstanding Surge Current Maximum Energy (10/1000μs) Rated Power Typical Capacitance (Reference) Standard High Surge VAC (V) VDC (V) V1mA (V) IP (A) VC (V) I (A) Standard I (A) High Surge (J) Standard (J) High Surge (W) @1KHz (pf) 142KH14 142KH14J 880 1140 1400(1260~1540) 50 2310 4500 6000 238 327 0.6 150 162KH14 162KH14J 1000 1280 1600(1440~1760) 50 2640 4500 6000 243 331 0.6 140 182KH14 182KH14J 1100 1465 1800(1620~1980) 50 2970 4500 5000 250 335 0.6 130 Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%. 2. Varistor voltage≥1200V, structure diagram is F type. 3. Leakage Current (@83% of V1mA):IR≤40μA (180K~680K) ; IR≤20μA (820K~182K) Electrical Ratings Items Varistor Voltage Maximum Allowable Voltage Test Condition/Description Requirement The voltage between the two terminals with the specified measuring current 1mA.DC applied is called Vb. The recommended maximum sine wave voltage (RMS) or the Maximum DC voltage can be applied continuously. The maximum voltage between the two terminals with the specification standard impulse current. Maximum Clamping Applied waveform: 8/20μs Crest value Voltage To meet the Current (%) 100 90 50 Specified value 20µ s 10 0 8µ s Time Impulse Width Rated Wattage Energy Withstanding Surge Current The maximum average power that can be applied within the specified ambient temperature. The maximum energy within the varistor voltage change of ±10% when one impulse of 10/1000μs or 2ms is applied. The maximum current within the varistor voltage change of ±10% with the standard impulse current (8/20μs) applied one time. V1mA@140℃-V1mA@25℃ V1mA@25℃ Varistor Voltage Temp. Coefficient V1mA@-40℃-V1mA@25℃ V1mA@25℃ × 1 × 100%(%/℃) 115 ≤0.05%/℃ 1 × × 100%(%/℃) 65 The change of Vb shall be measured after the impulse listed below which is applied 10,000 times continuously with the interval of ten Surge Life seconds at room temperature. 14Φ series Revision: MOV-14H SERIES-001(A2) 180K to 680K 75A (8/20μs) 820K to 182K 150A (8/20μs) 5 / 13 http://brightking.pulseelectronics.com 14H SERIES Soldering Recommendation Lead-free Wave Soldering Recommendation 300 Preheating Maximum Wave 265℃ Soldering Cooling Temperature (℃) 250 200 150 100 50 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Time (minutes) Item Conditions Peak Temperature 265℃ Dipping Time 10 seconds (max.) Soldering 1 time Recommendation Reworking Conditions with Soldering Iron Item Conditions Temperature of Soldering Iron-tip 360℃ (max.) Soldering Time 3 seconds (max.) Distance from Varistor 2mm (min.) Revision: MOV-14H SERIES-001(A2) 6 / 13 http://brightking.pulseelectronics.com 14H SERIES Mechanical Characteristics Items Test conditions / Methods Specifications Gradually applying the force specified and keeping the unit fixed for 10±1 sec. Tensile Strength of Terminals Bending Strength of Terminals Vibration Terminal diameter (mm) 0.5<d≤0.8 0.8<d≤1.25 1.25<d Force (kg) 1.0 2.0 4.0 Hold specimen and apply the force specified below to each lead. Bend the specimen to 90°, then return to the original position. Repeat the procedure in the opposite direction. Terminal diameter (mm) 0.5<d≤0.8 0.8<d≤1.25 1.25<d Force (kg) 0.5 1.0 2.0 Frequency range: 10~55 Hz 2 Amplitude: 0.75mm or 98m/s Direction: 3 mutually perpendicular directions, 2hrs each. No visible damage | V1mA/V1mA |≤5% No visible damage | V1mA/V1mA |≤5% No visible damage | V1mA/V1mA |≤5% Solder ability Solder Temp: 245±5℃ Dipping Time: 2±0.5 sec At least 95% of terminal electrode is covered by new solder Resistance to Soldering Heat Solder Temp: 260±5℃ Dipping Time: 10±1 sec No visible damage | V1mA/V1mA |≤10% Reliability Items High Temperature Storage Low Temperature Storage Humidity Test conditions / Methods Ambient Temp: 125±2℃ Duration: 1000hrs Ambient Temp: -40±2℃ Duration: 1000hrs Ambient Temp: 40±2℃, 90~95% R.H. Duration: 1000hrs Specifications | V1mA/V1mA |≤5% | V1mA/V1mA |≤5% | V1mA/V1mA |≤5% The conditions shown below shall be repeated 5 cycles Temperature Cycle High Temperature Load Damp Heat Load Voltage Proof Step Temperature (℃) Period (minutes) 1 -40±3 30±3 2 Room temperature 15±3 3 125±3 30±3 4 Room temperature 15±3 Ambient Temp: 125±2℃ Duration: 1000hrs Load: Max. Allowable Voltage In AC eara. Ambient Temp: 40±2℃, 90~95% R.H. Duration: 1000hrs Load: Max. Allowable Voltage Metal balls method, 1000Vac 1 min.(180K~331K), 1500Vac 1 min.(361K~182K) Revision: MOV-14H SERIES-001(A2) 7 / 13 No visible damage | V1mA/V1mA |≤5% | V1mA/V1mA|≤10% No visible damage | V1mA/V1mA |≤10% No visible damage http://brightking.pulseelectronics.com 14H SERIES Max. Power Rating (%) Power Derating Curve 100 0 LCT=-40 UCT=125 150 Ambient Temperature (℃) Maximum Surge Current Derating Curve 180KH14 to 680KH14 820KH14 to 182KH14 10000 10000 1 2 100 1 1000 2 10 1023 104 10 105 106 Max. Surge Current (A) Max. Surge Current (A) 1000 10 100 10 102 103 104 105 106 10 1 1 0.1 10 100 1000 0.1 10 10000 100 Td (μs) 1000 10000 Td (μs) 180KH14J to 680KH14J 820KH14J to 182KH14J 10000 10000 1 2 1 100 2 1000 10 102 103 104 105 106 Max. Surge Current (A) Max. Surge Current (A) 1000 10 1 0.1 10 100 10 102 103 104 105 106 10 1 100 1000 10000 0.1 10 Td (μs) Revision: MOV-14H SERIES-001(A2) 100 1000 10000 Td (μs) 8 / 13 http://brightking.pulseelectronics.com 14H SERIES Maximum Leakage Current and Maximum Clamping Voltage Curve Revision: MOV-14H SERIES-001(A2) 9 / 13 http://brightking.pulseelectronics.com 14H SERIES Maximum Leakage Current and Maximum Clamping Voltage Curve Revision: MOV-14H SERIES-001(A2) 10 / 13 http://brightking.pulseelectronics.com 14H SERIES Maximum Leakage Current and Maximum Clamping Voltage Curve Revision: MOV-14H SERIES-001(A2) 11 / 13 http://brightking.pulseelectronics.com 14H SERIES Marking Code ① Brightking Logo ① XXXXXX ② Varistor Voltage ③ ④ ② ③ “J”is High Surge Code, no“J”is Standard Surge ④ Varistor Size Taping Dimensions P2 P h B W2 W0 W H D0 I P1 P0 F Dimensions (mm) P 25.4±1.0 P0 12.7±1.0 P1 8.95±0.7 P2 12.7±1.3 F 7.5±0.8 h 0±4 W 18.0±1.0 W0 12.0±1.0 W1 9.0±0.5 W2 3.0max H 20.0±2.0 I 1.0max D0 4.0±0.2 t 0.6±0.3 B 40max W1 t Revision: MOV-14H SERIES-001(A2) Symbol 12 / 13 http://brightking.pulseelectronics.com 14H SERIES Quantity Packaging Dimensions (Unit: mm) Quantity Bulk 400pcs/bag 2bags/box (180K~331K) ax . 300pcs/bag 2bags/box (361K~561K) 0M 250pcs/bag 16 66 Max. 2bags/box (621K~751K) 252 Max. 200pcs/bag 2bags/box (781K~112K) 150pcs/bag 2bags/box (122K~182K) Tape & Box 750pcs/box (180K~331K) 0M ax . 500pcs/box (361K~561K) 400pcs/box (621K~751K) 25 60 Max. 340 Max. 300pcs/box (781K~112K) Tape & Reel 5M ax . 800pcs/reel (180K~331K) 36 60 Max. 600pcs/reel (361K~561K) 365 Max. 500pcs/reel (621K~751K) 55 Max. 30±1 Φ365 Max. 400pcs/reel (781K~112K) Revision: MOV-14H SERIES-001(A2) 13 / 13 http://brightking.pulseelectronics.com
621KH14J 价格&库存
很抱歉,暂时无法提供与“621KH14J”相匹配的价格&库存,您可以联系我们找货
