1.5KE75CA/B
1.5KE75CA/B
    BRIGHTKING(君耀)
    DO-201
    特性:玻璃钝化结。低齐纳阻抗。出色的钳位能力。10/1000μs波形下1500W的峰值脉冲功率能力,重复率(占空比):0.01%。快速响应时间。典型反向电流(IR)在12V以上小于1μA。应用:I/O...
1.5KE75CA/B 数据手册
1.5KE SERIES Transient Voltage Suppressors (TVS) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ Glass passivated junction Low zener impedance Excellent clamping capability 1500W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% Fast response time Typical IR less than 1μA above 12V. High Temperature soldering guaranteed: 265℃/10 seconds/.375″, (9.5mm) lead length, 5lbs (2.3kg) tension Plastic package has underwriters laboratory flammability 94V-0 Meets MSL level 1, per J-STD-020. Safety certification: UL: E244458 Mechanical Data ■ ■ ■ ■ ■ Case: JEDEC DO-201 Moulded plastic Terminal: Axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode except bi-directional models Mounting Position: Any Weight: 0.97g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units PPPM Minimum 1500 Watts IPPM PM(AV) See Table 6.5 Amps Watts IFSM 200 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Peak pulse power dissipation at 10/1000μs waveform (Note1, Fig.1) Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) Steady state power dissipation at TL=75℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note2, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Revision:TVS-1.5KE SERIES-001(A1) 1/6 http://brightking.pulseelectronics.com 1.5KE SERIES Dimensions (DO-201) Millimeters Cathode Band L d T Inches Symbol Min. Max. Min. Max. L 25.40 - 1.000 - T 7.20 9.50 0.285 0.375 d 4.80 5.30 0.190 0.210 s 0.96 1.07 0.038 0.042 Maximum Peak Reverse Clamping Pulse Leakage Voltage @IPP Current @VRWM s DIA. DIA. L Electrical Characteristics (TA=25℃) Part Number Reverse Breakdown Stand-Off Voltage Voltage @IT Test Current Unidirectional Bidirectional VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 1.5KE6.8A 1.5KE6.8CA 5.80 6.45~7.14 10 10.5 144.8 1000 1.5KE7.5A 1.5KE7.5CA 6.40 7.13~7.88 10 11.3 134.5 500 1.5KE8.2A 1.5KE8.2CA 7.02 7.79~8.61 10 12.1 125.6 200 1.5KE9.1A 1.5KE9.1CA 7.78 8.65~9.55 1 13.4 113.4 50 1.5KE10A 1.5KE10CA 8.55 9.50~10.50 1 14.5 104.8 10 1.5KE11A 1.5KE11CA 9.40 10.50~11.60 1 15.6 97.4 5 1.5KE12A 1.5KE12CA 10.20 11.40~12.60 1 16.7 91.0 5 1.5KE13A 1.5KE13CA 11.10 12.40~13.70 1 18.2 83.5 1 1.5KE15A 1.5KE15CA 12.80 14.30~15.80 1 21.2 71.7 1 1.5KE16A 1.5KE16CA 13.60 15.20~16.80 1 22.5 67.6 1 1.5KE18A 1.5KE18CA 15.30 17.10~18.90 1 25.2 60.3 1 1.5KE20A 1.5KE20CA 17.10 19.00~21.00 1 27.7 54.9 1 1.5KE22A 1.5KE22CA 18.80 20.90~23.10 1 30.6 49.7 1 1.5KE24A 1.5KE24CA 20.50 22.80~25.20 1 33.2 45.8 1 1.5KE27A 1.5KE27CA 23.10 25.70~28.40 1 37.5 40.5 1 1.5KE30A 1.5KE30CA 25.60 28.50~31.50 1 41.4 36.7 1 1.5KE33A 1.5KE33CA 28.20 31.40~34.70 1 45.7 33.3 1 1.5KE36A 1.5KE36CA 30.80 34.20~37.80 1 49.9 30.5 1 1.5KE39A 1.5KE39CA 33.30 37.10~41.00 1 53.9 28.2 1 Revision:TVS-1.5KE SERIES-001(A1) 2/6 http://brightking.pulseelectronics.com 1.5KE SERIES Electrical Characteristics (TA=25℃) Part Number Reverse Breakdown Stand-Off Voltage Voltage @IT Test Current Maximum Peak Reverse Clamping Pulse Leakage Voltage @IPP Current @VRWM Unidirectional Bidirectional VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 1.5KE43A 1.5KE43CA 36.80 40.90~45.20 1 59.3 25.6 1 1.5KE47A 1.5KE47CA 40.20 44.70~49.40 1 64.8 23.5 1 1.5KE51A 1.5KE51CA 43.60 48.50~53.60 1 70.1 21.7 1 1.5KE56A 1.5KE56CA 47.80 53.20~58.80 1 77.0 19.7 1 1.5KE62A 1.5KE62CA 53.00 58.90~65.10 1 85.0 17.9 1 1.5KE68A 1.5KE68CA 58.10 64.60~71.40 1 92.0 16.5 1 1.5KE75A 1.5KE75CA 64.10 71.30~78.80 1 103.0 14.8 1 1.5KE82A 1.5KE82CA 70.10 77.90~86.10 1 113.0 13.5 1 1.5KE91A 1.5KE91CA 77.80 86.50~95.50 1 125.0 12.2 1 1.5KE100A 1.5KE100CA 85.50 95.00~105.00 1 137.0 11.1 1 1.5KE110A 1.5KE110CA 94.00 105.00~116.00 1 152.0 10.0 1 1.5KE120A 1.5KE120CA 102.00 114.00~126.00 1 165.0 9.2 1 1.5KE130A 1.5KE130CA 111.00 124.00~137.00 1 179.0 8.5 1 1.5KE150A 1.5KE150CA 128.00 143.00~158.00 1 207.0 7.3 1 1.5KE160A 1.5KE160CA 136.00 152.00~168.00 1 219.0 6.9 1 1.5KE170A 1.5KE170CA 145.00 162.00~179.00 1 234.0 6.5 1 1.5KE180A 1.5KE180CA 154.00 171.00~189.00 1 246.0 6.2 1 1.5KE200A 1.5KE200CA 171.00 190.00~210.00 1 274.0 5.5 1 1.5KE220A 1.5KE220CA 185.00 209.00~231.00 1 328.0 4.6 1 1.5KE250A 1.5KE250CA 214.00 237.00~263.00 1 344.0 4.4 1 1.5KE300A 1.5KE300CA 256.00 285.00~315.00 1 414.0 3.7 1 1.5KE350A 1.5KE350CA 300.00 332.00~368.00 1 482.0 3.2 1 1.5KE400A 1.5KE400CA 342.00 380.00~420.00 1 548.0 2.8 1 1.5KE440A 1.5KE440CA 376.00 418.00~462.00 1 602.0 2.5 1 1.5KE480A 1.5KE480CA 408.00 456.00~504.00 1 658.0 2.3 1 1.5KE510A 1.5KE510CA 434.00 485.00~535.00 1 698.0 2.1 1 1.5KE530A 1.5KE530CA 450.00 503.50~556.50 1 725.0 2.1 1 1.5KE540A 1.5KE540CA 459.00 513.00~567.00 1 740.0 2.0 1 1.5KE550A 1.5KE550CA 467.00 522.50~577.50 1 760.0 2.0 1 Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double. Revision:TVS-1.5KE SERIES-001(A1) 3/6 http://brightking.pulseelectronics.com 1.5KE SERIES Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve 100 Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 1000 100 10 1 0.1 0.1 1 10 75 50 25 0 1000 0 td-Pulse Width (µs) 150 175 200 Bi-directional V=0V 10000 Uni-directional V=0V Cj (pF) IPPM - Peak Pulse Current, %IRSM 100 125 100000 Peak Value IPPM 100 Half Value IPPM (IPPM/2) 1000 Uni-directional @VR 100 50 10/1000µs Waveform as defined by R.E.A 0 1 1.0 2.0 3.0 Bi-directional @VR 10 td 0 4.0 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 10 100 1000 VBR-Reverse Breakdown Voltage (V) t-Time (ms) Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Figure 5. Steady State Power Dissipation Derating Curve 7 200 IFSM - Peak Forward Surve Current (A) PM(AV), Steady State Power Dissipation (W) 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 6 5 4 3 L= 0.375″(9.5mm) Lead Lengths 2 1 0 0 25 50 75 100 125 150 175 200 TL-Lead Temperature (℃) Revision:TVS-1.5KE SERIES-001(A1) 4/6 180 160 140 120 100 80 60 40 20 0 1 10 Number of Cycles at 60Hz 100 http://brightking.pulseelectronics.com 1.5KE SERIES Recommended Soldering Conditions Wave Soldering 300 Preheating Soldering Cooling Maximum Wave 265℃ Temperature (℃) 250 200 150 100 50 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Time (minutes) Item Conditions Peak Temperature 265℃ Dipping Time 10 seconds Soldering 1 time Marking Code Cathode Band Logo YXXX 1.5KE6.8A Logo Date Code YXXX 1.5KE6.8CA Date Code Marking Code Marking Code Part Number Code 1.5KE XXX C A 5% VBR Voltage Tolerance Bidirectional VBR Voltage Series Code Revision:TVS-1.5KE SERIES-001(A1) 5/6 http://brightking.pulseelectronics.com 1.5KE SERIES Ordering Code for Different Package Box package: Add suffix “/B” at the end of the part number, such as 1.5KE100CA/B Reel package: Add suffix “/TR13” at the end of the part number, such as 1.5KE75A/TR13 Packaging Tape Z ±5° A E L1 B L2 T E Box H Symbol Dimension (mm) A 10.0±0.5 B 53.0±1.0 Z 1.2Max. T 6.0±0.4 E 0.8Max. L1-L2 1.0Max. L 250.0±5.0 W 75.0±5.0 H 114.0±5.0 L W Quantity: 1000PCS Reel D0 D D1 D 330.0±3.0 D0 16.4±2.0 D1 86.0±2.0 W1 76.0±3.0 W1 Quantity: 1200PCS Revision:TVS-1.5KE SERIES-001(A1) 6/6 http://brightking.pulseelectronics.com
1.5KE75CA/B 价格&库存
很抱歉,暂时无法提供与“1.5KE75CA/B”相匹配的价格&库存,您可以联系我们找货
