15KPA SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
Glass passivated junction
Low incremental surge resistance
Excellent clamping capability
15000W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.05%
Fast response time
Typical IR less than 2μA above 30V.
High Temperature soldering guaranteed: 265℃/10 seconds/.375″,
(9.5mm) lead length, 5lbs (2.3kg) tension
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020.
Safety certification: UL: E244458
Mechanical Data
Case: Moulded plastic over glass passivated junction
Terminal: Plated Axial leads, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Mounting Position: Any
Weight: 2.30g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Fig.1)
PPPM
Minimum 15000
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
8.0
Watts
IFSM
400
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
8
℃/W
Typical thermal resistance junction to ambient
RθJA
40
℃/W
Steady state power dissipation at TL=75℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note2, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:TVS-15KPA SERIES-001(A1)
1/6
http://brightking.pulseelectronics.com
15KPA SERIES
Dimensions (P600)
Millimeters
Inches
Symbol
Cathode Band
d
DIA.
s
DIA.
T
L
L
Min.
Max.
Min.
Max.
L
25.40
1.000
T
8.60
9.10
0.340
0.360
d
8.60
9.10
0.340
0.360
s
1.19
1.32
0.047
0.052
Maximum
Peak
Reverse
Clamping
Pulse
Leakage
Voltage @IPP
Current
@VRWM
Electrical Characteristics (TA=25℃)
Part Number
Reverse
Breakdown
Stand-Off
Voltage
Voltage
@IT
Test
Current
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
15KPA17A
15KPA17CA
17.0
18.99~21.22
50
29.3
515.4
5000
15KPA18A
15KPA18CA
18.0
20.11~22.65
50
30.9
488.7
5000
15KPA20A
15KPA20CA
20.0
22.34~24.96
440.2
1500
15KPA22A
15KPA22CA
22.0
24.57~27.46
10
37.1
407.0
500
15KPA24A
15KPA24CA
24.0
26.81~29.95
5
40.7
371.0
150
15KPA26A
15KPA26CA
26.0
29.04~32.45
5
44.0
343.2
50
15KPA28A
15KPA28CA
28.0
31.28~34.95
5
47.5
317.9
25
15KPA30A
15KPA30CA
30.0
33.51~37.44
5
50.7
297.8
15
15KPA33A
15KPA33CA
33.0
36.90~41.19
5
54.7
276.1
2
15KPA36A
15KPA36CA
36.0
40.20~44.93
5
59.8
252.5
2
15KPA40A
15KPA40CA
40.0
44.70~49.92
5
65.8
229.5
2
15KPA43A
15KPA43CA
43.0
48.00~53.67
5
69.8
216.3
2
15KPA45A
15KPA45CA
45.0
50.30~56.16
5
72.8
207.4
2
15KPA48A
15KPA48CA
48.0
53.60~59.91
5
77.7
194.3
2
15KPA51A
15KPA51CA
51.0
57.00~63.65
5
82.9
182.1
2
15KPA54A
15KPA54CA
54.0
60.30~67.39
5
87.7
172.2
2
15KPA58A
15KPA58CA
58.0
64.80~72.39
5
93.8
161.0
2
2/6
15KPA SERIES
Part Number
Reverse
Breakdown
Stand-Off
Voltage
Voltage
@IT
Test
Current
Maximum
Peak
Reverse
Clamping
Pulse
Leakage
Voltage @IPP
Current
@VRWM
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
15KPA60A
15KPA60CA
60.0
67.00~74.88
5
97.4
155.0
2
15KPA64A
15KPA64CA
64.0
71.50~79.87
5
104.2
144.9
2
15KPA70A
15KPA70CA
70.0
78.20~87.36
5
113.6
132.9
2
15KPA75A
15KPA75CA
75.0
83.80~93.60
5
122.0
123.8
2
15KPA78A
15KPA78CA
78.0
87.10~97.35
5
126.1
119.7
2
15KPA85A
15KPA85CA
85.0
94.90~106.08
5
137.6
109.7
2
15KPA90A
15KPA90CA
90.0
100.50~112.32
5
145.6
103.7
2
15KPA100A
15KPA100CA
100.0
111.70~124.80
5
161.3
93.6
2
15KPA110A
15KPA110CA
110.0
122.90~137.28
5
178.6
84.5
2
15KPA120A
15KPA120CA
120.0
134.00~149.76
5
192.3
78.5
2
15KPA130A
15KPA130CA
130.0
145.20~162.25
5
208.3
72.5
2
15KPA150A
15KPA150CA
150.0
167.60~187.21
5
241.9
62.4
2
15KPA160A
15KPA160CA
160.0
178.70~199.69
5
258.6
58.4
2
15KPA170A
15KPA170CA
170.0
189.90~212.17
5
272.7
55.4
2
15KPA180A
15KPA180CA
180.0
201.10~224.65
5
288.5
52.3
2
15KPA200A
15KPA200CA
200.0
223.40~249.61
5
319.1
47.3
2
15KPA220A
15KPA220CA
220.0
245.70~274.57
5
352.5
42.8
2
15KPA240A
15KPA240CA
240.0
268.10~299.53
5
384.6
39.3
2
15KPA260A
15KPA260CA
260.0
290.40~324.49
5
416.7
36.2
2
15KPA280A
15KPA280CA
280.0
312.80~349.45
5
454.5
33.2
2
Notes: For bidirectional type having VRWM of 30V and less, the IR limit is double.
3/6
15KPA SERIES
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
1000
100
10
1
1
10
100
td-Pulse Width (µs)
25
75
100 125
150 175
200
Figure 4. Typical Junction Capacitance
100000
Bi-directional V=0V
10000
Uni-directional V=0V
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
1000
Uni-directional @VR
100
Bi-directional @VR
50
10/1000µs Waveform
as defined by R.E.A
10
td
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
1.0
2.0
3.0
Figure 5. Steady State Power Dissipation Derating
IFSM - Peak Forward Surve Current (A)
8
7
6
5
4
L= 0.375″(9.5mm)
Lead Lengths
1
150
200
250
300
350
Surge Current Uni-Directional Only
9
2
100
Figure 6. Maximum Non-Repetitive Forward
Curve
3
50
VBR-Reverse Breakdown Voltage (V)
t-Time (ms)
PM(AV), Steady State Power Dissipation (W)
25
TA-Ambient Temperature (℃)
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
50
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
75
1000
Figure 3. Pulse Waveform
150
100
50
75 100 125 150
TL-Lead Temperature (℃)
175
200
450
400
350
300
250
200
150
100
50
10
100
Number of Cycles at 60Hz
4/6
15KPA SERIES
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
Marking Code
Cathode Band
Logo
YXXX
15KPA17A
Date Code
Logo
Marking Code
YXXX
15KPA17CA
Date Code
Marking Code
5/6
15KPA SERIES
Part Number Code
15KPA XXX C A
5% VBR Voltage Tolerance
Bidirectional
VRWM Voltage
Series Code
Ordering Code for Different Package
Box package: Add suffix “/B” at the end of the part number, such as 15KPA60A/B
Reel package: Add suffix “/TR13” at the end of the part number, such as 15KPA120CA/TR13
Packaging
Tape
Z
±5°
A
E
L1
B
L2
T
E
Box
H
Symbol
Dimension (mm)
A
10.0±0.5
B
53.0±1.0
Z
1.2Max.
T
6.0±0.4
E
0.8Max.
L1-L2
1.0Max.
L
250.0±5.0
W
75.0±5.0
H
114.0±5.0
L
W
Quantity: 300PCS
Reel
D0
D
D1
D
330.0±3.0
D0
16.4±2.0
D1
86.0±2.0
W1
76.0±3.0
W1
Quantity: 800PCS
6/6
很抱歉,暂时无法提供与“15KPA17CA/B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.26204
- 10+2.14532
- 30+1.23725
- 300+1.15431
- 600+1.11629
- 900+1.10074
