7Φ SERIES
Metal Oxide Varistors (MOV) Data Sheet
Features
Wide operating voltage (V1mA) range from 18V to 820V
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
Operating Temperature:-40℃ ~ +85℃
Storage Temperature:-40℃ ~ +125℃
Safety certification: UL: E327997
CSA: 246579
VDE: 40027827
Applications
Transistor, diode, IC, thyristor or triac semiconductor protection
Surge protection in consumer electronics
Surge protection in industrial electronics
Surge protection in electronic home appliances, gas and petroleum appliances
Relay and electromagnetic valve surge absorption
Part Number Code
Revision:27-Dec-15
1 / 11
www.brightking.com
7Φ SERIES
Dimensions
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H(±2.0)
10.0
180K
2.4
1.3
241K
3.2
2.0
H1(±2.0)
11.5
220K
2.5
1.4
271K
3.4
2.2
L(min.)
20.0
270K
2.7
1.6
301K
3.5
2.3
L1(min.)
15.0
330K
2.6
1.5
331K
3.5
2.3
D
7.0~9.0
390K
2.7
1.6
361K
3.7
2.5
F(±0.8)
5.0
470K
2.9
1.7
391K
3.8
2.6
T(±0.8)
Table 2
560K
3.1
1.9
431K
4.0
2.8
e(±0.8)
Table 2
680K
3.4
2.2
471K
4.2
3.0
d(±0.05)
0.6
820K
2.8
1.6
511K
4.4
3.2
d1(±0.4)
1.2
101K
3.0
1.8
561K
4.6
3.4
121K
3.2
2.0
621K
4.9
3.7
151K
2.8
1.6
681K
5.2
4.0
181K
2.9
1.7
751K
5.3
4.1
201K
3.0
1.8
781K
5.4
4.2
221K
3.1
1.9
821K
5.6
4.4
Revision:27-Dec-15
2 / 11
www.brightking.com
7Φ SERIES
Electrical Characteristics
Maximum
Part
Allowable
Number
Standard
Voltage
High
Surge
VAC(V)
VDC(V)
Varistor
Voltage
V1mA(V)
Maximum
Withstanding
Maximum
Clamping
Surge
Energy
Voltage
Current
(10/1000μs)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
Rated
Power
Typical
Capacitance
(Reference)
(J)
High
(W)
@1KHz (pf)
Surge
180KD07
180KD07J
11
14
18(15~21.6)
2.5
36
250
500
0.9
2.0
0.02
2800
220KD07
220KD07J
14
18
22(19.5~26)
2.5
43
250
500
1.1
2.4
0.02
2300
270KD07
270KD07J
17
22
27(24~31)
2.5
53
250
500
1.4
3.0
0.02
1800
330KD07
330KD07J
33(29.5~36.5)
2.5
65
250
500
1.7
3.5
0.02
1500
390KD07
390KD07J
25
31
39(35~43)
2.5
77
250
500
2.1
4.0
0.02
1300
470KD07
470KD07J
30
38
47(42~52)
2.5
93
250
500
2.5
5.0
0.02
1100
560KD07
560KD07J
35
45
56(50~62)
2.5
110
250
500
3.1
6.0
0.02
890
680KD07
680KD07J
40
56
68(61~75)
2.5
135
250
500
3.6
7.0
0.02
740
820KD07
820KD07J
50
65
82(74~90)
10
135
1200
1750
5.0
10.0
0.25
600
101KD07
101KD07J
60
85
100(90~110)
10
165
1200
1750
6.5
12.0
0.25
500
121KD07
121KD07J
75
100
120(108~132)
10
200
1200
1750
7.8
13.0
0.25
420
151KD07
151KD07J
95
125
150(135~165)
10
250
1200
1750
9.7
13.0
0.25
330
181KD07
181KD07J
115
150
180(162~198)
10
300
1200
1750
11.7
16.0
0.25
280
201KD07
201KD07J
130
170
200(180~220)
10
340
1200
1750
13.0
17.0
0.25
250
221KD07
221KD07J
140
180
220(198~242)
10
360
1200
1750
14.0
19.0
0.25
230
241KD07
241KD07J
150
200
240(216~264)
10
395
1200
1750
15.0
21.0
0.25
210
271KD07
271KD07J
175
225
270(243~297)
10
455
1200
1750
18.0
24.0
0.25
185
301KD07
301KD07J
190
250
300(270~330)
10
500
1200
1750
20.0
26.0
0.25
165
331KD07
331KD07J
210
275
330(297~363)
10
550
1200
1750
23.0
28.0
0.25
150
361KD07
361KD07J
230
300
360(324~396)
10
595
1200
1750
25.0
32.0
0.25
140
391KD07
391KD07J
250
320
390(351~429)
10
650
1200
1750
25.0
35.0
0.25
130
431KD07
431KD07J
275
350
430(387~473)
10
710
1200
1750
28.0
40.0
0.25
115
471KD07
471KD07J
300
385
470(423~517)
10
775
1200
1750
30.0
42.0
0.25
105
511KD07
511KD07J
320
415
510(459~561)
10
845
1200
1750
30.0
45.0
0.25
100
561KD07
561KD07J
350
460
560(504~616)
10
925
1200
1750
30.0
49.0
0.25
90
621KD07
621KD07J
385
505
620(558~682)
10
1025
1200
1750
33.0
55.0
0.25
80
681KD07
681KD07J
420
560
680(612~748)
10
1120
1200
1750
33.0
60.0
0.25
75
751KD07
751KD07J
460
615
750(675~825)
10
1240
1200
1750
67.2
65.0
0.25
70
781KD07
781KD07J
485
640
780(702~858)
10
1290
1200
1750
67.2
65.0
0.25
70
821KD07
821KD07J
510
670
820(738~902)
10
1355
1200
1750
67.2
70.0
0.25
60
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K)
IR≤25μA (820K~821K)
Revision:27-Dec-15
3 / 11
www.brightking.com
7Φ SERIES
Electrical Ratings
Items
Varistor Voltage
Maximum Allowable
Voltage
Test Condition/Description
Requirement
The voltage between two terminals with the specified measuring
current 1mA.DC applied is called Vb.
The recommended maximum sine wave voltage (RMS) or the
Maximum DC voltage can be applied continuously.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
Maximum Clamping
Voltage
To meet the
Specified value
Rated Wattage
The maximum average power that can be applied within the
specified ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10%
when one impulse of 10/1000μs or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10%
with the standard impulse current (8/20μs) applied one time.
Varistor Voltage
Temp. Coefficient
Vb at 20℃ − Vb at 70℃ 1
× 100(%/℃)
50
Vb at 20℃
0.05%/℃ max
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
Surge Life
7Φ series
Revision:27-Dec-15
180K to 680K
25A (8/20μs)
820K to 821K
50A (8/20μs)
4 / 11
∆Vb
≤ ±10%
Vb
www.brightking.com
7Φ SERIES
Soldering Recommendation
Wave Lead Free Soldering Recommendation
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Revision:27-Dec-15
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
5 / 11
www.brightking.com
7Φ SERIES
Maximum Surge Current Derating Curve
820KD07 to 471KD07
180KD07 to 680KD07
10000
10000
1000
1000
1
100
10
1
2
10
102
2
10
102
1034
105
106
10
100
103
1045
106
10
10
1
1
0.1
10
100
1000
0.1
10
10000
Td (μs)
100
1000
10000
Td (μs)
820KD07J to 821KD07J
10000
1000
1
2
10
102
100
103
104
105
106
10
1
0.1
10
100
1000
10000
Td (μs)
Revision:27-Dec-15
6 / 11
www.brightking.com
7Φ SERIES
Maximum Leakage Current and Maximum Clamping Voltage Curve
180KD07 to 680KD07
1000
680KD07
560KD07
470KD07
390KD07
330KD07
270KD07
220KD07
180KD07
Voltage (V)
100
10
1
10-6
-5
10
-4
10
-3
10
-2
10
-1
10
1
10
2
10
3
10
4
10
Current (A)
820KD07 to 471KD07
10000
471KD07
431KD07
391KD07
361KD07
331KD07
301KD07
271KD07
241KD07
221KD07
201KD07
181KD07
151KD07
121KD07
101KD07
820KD07
Voltage (V)
1000
100
10
10-6
10-5
10-4
10-3
10-2
10-1
1
10
102
103
104
Current (A)
Revision:27-Dec-15
7 / 11
www.brightking.com
7Φ SERIES
511KD07 to 821KD07
10000
821KD07
781KD07
751KD07
681KD07
621KD07
561KD07
511KD07
Voltage (V)
1000
100
10
10-6
-5
10
-4
10
-3
10
-2
10
-1
10
1
10
2
10
3
10
4
10
Current (A)
180KD07J to 680KD07J
1000
680KD07J
560KD07J
470KD07J
390KD07J
330KD07J
270KD07J
220KD07J
180KD07J
Voltage (V)
100
10
1
10-6
-5
10
-4
10
-3
10
-2
10
-1
10
1
10
2
10
3
10
4
10
Current (A)
Revision:27-Dec-15
8 / 11
www.brightking.com
7Φ SERIES
820KD07J to 471KD07J
10000
471KD07J
431KD07J
391KD07J
361KD07J
331KD07J
301KD07J
271KD07J
241KD07J
221KD07J
201KD07J
181KD07J
151KD07J
121KD07J
101KD07J
820KD07J
Voltage (V)
1000
100
10
10-6
-5
10
-4
10
-3
10
-2
10
-1
10
1
10
2
3
10
4
10
5
10
10
Current (A)
511KD07J to 821KD07J
10000
821KD07J
781KD07J
751KD07J
681KD07J
621KD07J
561KD07J
511KD07J
Voltage (V)
1000
100
10-6
-5
10
-4
10
-3
10
-2
10
-1
10
1
10
2
10
3
10
4
10
5
10
Current (A)
Revision:27-Dec-15
9 / 11
www.brightking.com
7Φ SERIES
Marking Code
① Brightking Logo
② Varistor Voltage
③ UL Accreditation Logo
①
XXXKDXXX
②
③
④
⑤
XXX H
Y
VDE
X
④ CSA Accreditation Logo
⑥
⑦
⑧
⑨
⑩
⑤ VDE Accreditation Logo
⑥“J”is High Surge Code, no“J”is Standard Surge
⑦ Disk Size
⑧“H”is Halogen Free Code, no“H”is Halogen
⑨ Date Code
⑩ Product Line Code (“Y”may be A thru Z or blank)
Taping Dimensions
Revision:27-Dec-15
10 / 11
Symbol
Dimensions (mm)
P
12.7±1.0
P0
12.7±0.3
P1
3.85±0.7
P2
6.35±1.3
F
5.0±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H
20.0±2.0
I
1.0max
D0
4.0±0.2
t
0.6±0.3
B
32max
www.brightking.com
7Φ SERIES
Quantity
Packaging Dimensions (Unit: mm)
Quantity
Bulk
1000pcs/bag
2bags/box
Tape & Box
1500pcs/box
(180K~391K)
1000pcs/box
(431K~821K)
Tape & Reel
2000pcs/reel
(180K~331K)
1500pcs/reel
(361K~821K)
Revision:27-Dec-15
11 / 11
www.brightking.com
很抱歉,暂时无法提供与“331KD07”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.25520
- 50+0.12760
- 1000+0.09669
