2R-8*8 SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs
Stable breakdown voltage
High insulation resistance
Low capacitance (≤1.5pF)
High holdover voltage
Large absorbing transient current capability
Micro-Gap Design
Storage and operating temperature: -40℃ ~ +85℃
Meets MSL level 1, per J-STD-020
Safety certification: E327997
Applications
Repeaters, Modems
Telephone Interface, Line cards
Data communication equipment
Line test equipment
Part Number Code
2
8
R
Electrical
Characteristics
H: 2.5KA
K: 3KA
L: 5KA
Lead Type
L: Lead
M: SMD
DC
Spark-over
Voltage
Electrode Numbers
2R: 2 Electrodes
Packing Code
No suffix: Bulk
TR: Tape & Reel packing
Dimensions
8: 8.0mm×8.0mm
Marking
: BrightKing Logo
2RL1000-8 : Device Marking Code
YXXX
: Date Code
Revision: GDT-2R-8*8 SERIES-001(A3)
2/7
http://brightking.pulseelectronics.com
2R-8*8 SERIES
Dimensions
L Type
Dimension (mm)
Symbol
Spec.
Tolerance
D
8.0
+0.3, -0.5
T
8.0
+0.6, -0.1
d
0.8
±0.1
L
30.0
Max.
D
8.0
+0.3, -0.5
T
8.0
+0.6, -0.1
B
0.5
±0.4
D
d
L
D
T
M Type
8.0
8.0
B
D
T
1.5
Recommended Pad Size
Electrical Characteristics
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
(V)
(V)
(KA)
(A)
(times)
DC(V)
2RH1400X-8
1400±20%
2200
2.5
2.5
100
500
1.0
2RH1600X-8
1600±20%
2400
2.5
2.5
100
500
2RH2000X-8
2000±20%
3000
2.5
2.5
100
2RH2500X-8
2500±20%
3600
2.5
2.5
2RH2700X-8
2700±20%
4000
2.5
2RH3000X-8
3000±20%
4200
2RH3500X-8
3500±20%
2RH3600X-8
Part
Number
Minimum
Insulation
Resistance
Maximum
Capacitance
AC
Withstanding
Voltage
Device
Marking
Code
1.5
2RH1400-8
1.0
1.5
2RH1600-8
500
1.0
1.5
2RH2000-8
100
500
1.0
1.5
AC1250V,1min
2RH2500-8
2.5
300*
1000
1.0
1.5
AC1250V,1min
2RH2700-8
2.5
2.5
100
1000
1.0
1.5
AC1500V,1min
2RH3000-8
5000
2.5
2.5
100
1000
1.0
1.5
AC1800V,1min
2RH3500-8
3600±20%
5200
2.5
2.5
100
1000
1.0
1.5
AC1800V,1min
2RH3600-8
2RK2700X-8
2700±20%
4000
3.0
3.0
300*
1000
1.0
1.5
AC1250V,1min
2RK2700-8
2RK3000X-8
3000±20%
4200
3.0
3.0
300*
1000
1.0
1.5
AC1500V,1min
2RK3000-8
2RK3500X-8
3500±20%
5000
3.0
3.0
100
1000
1.0
1.5
AC1800V,1min
2RK3500-8
2RK3600X-8
3600±20%
5200
3.0
3.0
100
1000
1.0
1.5
AC1800V,1min
2RK3600-8
2RK4000X-8
4000±20%
5500
3.0
3.0
100
1000
1.0
1.5
AC2000V,1min
2RK4000-8
3/7
(GΩ)
1MHz
(pF)
2R-8*8 SERIES
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
(V)
(V)
(KA)
(A)
(times)
DC(V)
2RL1000X-8
1000±20%
1400
5.0
5.0
100
500
1.0
2RL1400X-8
1400±20%
2200
5.0
5.0
100
500
2RL1600X-8
1600±20%
2400
5.0
5.0
100
2RL2000X-8
2000±20%
3000
5.0
5.0
2RL2500X-8
2500±20%
3600
5.0
5.0
Part
Number
Minimum
Insulation
Resistance
Maximum
Capacitance
AC
Withstanding
Voltage
Device
Marking
Code
1.5
2RL1000-8
1.0
1.5
2RL1400-8
500
1.0
1.5
2RL1600-8
100
500
1.0
1.5
2RL2000-8
100
1000
1.0
1.5
AC1250V,1min
2RL2500-8
(GΩ)
1MHz
(pF)
* Measured with an 8/20μs waveform, 100A.
☆X may be L or M.
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage ramp
dv/dt=1000V/μs.
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval time,
without causing the DC spark-over voltage to change more than 25%
from its initial value.
Crest value
100
90
Current (%)
Impulse
Discharge Current
To meet
50
the specified
20µs
10
value
8µs
Time
Impulse Width
Alternating
Discharge Current
Insulation
Resistance
Capacitance
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval
time 3 min. DC spark-over voltage shall not change more than ±25%
8
from its initial value.IR>10 ohms
The resistance of gas tube shall be measured between two electrodes.
The capacitance of gas tube shall be measured between two electrodes.
Test frequency: 1MHz
4/7
2R-8*8 SERIES
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
Time (minutes)
3
3.5
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
4
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
Peak Temperature (TP)
150℃
200℃
60-180 seconds
3℃/second max.
217℃
60-150 seconds
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
5/7
2R-8*8 SERIES
Packaging
Axial Packing (Bulk)
Skin packing
Dimension (mm)
Symbol
Spec.
Tolerance
A
265.0
±5.0
B
146.0
±5.0
H
9.5
±0.5
Quantity: 100pcs
Inner box
A0
270.0
±2.0
B0
150.0
±2.0
H0
50.0
±2.0
Quantity: 500pcs
Axial Packing (Tape & Reel)
Tape
Dimension (mm)
Symbol
Reel
Spec.
Tolerance
P
10.0
±0.5
W
65.0
±1.0
E
6.0
±0.5
F
26.5
±0.5
d
0.8
±0.1
A1
330.0
±2.0
B1
70.0
±2.0
C1
82.0
±2.0
D
25.0
±0.5
t
2.0
±0.2
Quantity: 500pcs
6/7
2R-8*8 SERIES
Packaging
SMD Packing (Tape & Reel)
Tape
Dimension (mm)
Symbol
Reel
t
D
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.20
P2
4.00
±0.10
D0
1.55
±0.10
E
1.75
±0.10
F
7.50
±0.10
A0
8.80
±0.10
K0
8.30
±0.10
B0
8.30
±0.10
t0
0.50
±0.10
D
330.00
±2.00
d
13.00
±0.50
L
20.00
±2.00
t
2.00
±0.20
d
L
Spec.
Quantity: 500pcs
7/7
很抱歉,暂时无法提供与“2RK2700M-8”相匹配的价格&库存,您可以联系我们找货
