2R-8*6(S) SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs
Stable breakdown voltage
High insulation resistance
Low capacitance (≤1.5pF)
High holdover voltage
Large absorbing transient current capability
Micro-Gap Design
Storage and operating temperature: -40℃ ~ +85℃
Meets MSL level 1, per J-STD-020
Safety certification: E244458 & E327997
Applications
Repeaters, Modems
Telephone Interface, Line cards
Data communication equipment
Line test equipment
Part Number Code
2
M
R
Electrical
Characteristics
M: 10KA
P: 20KA
Electrode Numbers
2R: 2 Electrodes
Lead Type
M: SMD
DC
Spark-over
Voltage
8
S
S:Square electrode
Dimensions
8: 8.3mm×6.0mm
Marking
: BrightKing Logo
2RM090-8 : Device Marking Code
YXXX
: Date Code
Revision: GDT-2R-8*6(S) SERIES-001(A2)
2/5
http://brightking.pulseelectronics.com
2R-8*6(S) SERIES
Dimensions
B
A
D
9.0
5.6
1.2
S
T
Dimension (mm)
Symbol
Recommended Pad Size
Spec.
Tolerance
A
8.0
±0.20
B
0.5
±0.10
D
8.3
±0.20
T
6.0
±0.25
S
9.0
±0.40
Electrical Characteristics
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Single
Impulse
Discharge
Current
Alternating
Discharge
Current
100V/s
1000V/μs
8/20μs
10times
10/350μs
50Hz,1sec
(V)
(V)
(KA)
(KA)
2RM075M-8-S
75±20%
600
10
2RM090M-8-S
90±20%
600
2RM150M-8-S
150±20%
2RM230M-8-S
Part
Number
Impulse
Life
Minimum
Insulation
Resistance
Maximum
Capacitance
Device
Marking
Code
Test
Voltag
e
DC(V)
(GΩ)
(A)
10/1000
μs
100A
(times)
2.5
10
500
25
1.0
1.5
2RM075-8
10
2.5
10
500
50
1.0
1.5
2RM090-8
600
10
2.5
10
500
100
1.0
1.5
2RM150-8
230±20%
700
10
2.5
10
500
100
1.0
1.5
2RM230-8
2RM250M-8-S
250±20%
700
10
2.5
10
500
100
1.0
1.5
2RM250-8
2RM300M-8-S
300±20%
900
10
2.5
10
500
100
1.0
1.5
2RM300-8
2RM350M-8-S
350±20%
900
10
2.5
10
500
100
1.0
1.5
2RM350-8
2RM420M-8-S
420±20%
1000
10
2.5
10
500
100
1.0
1.5
2RM420-8
2RM470M-8-S
470±20%
1000
10
2.5
10
500
250
1.0
1.5
2RM470-8
2RM600M-8-S
600±20%
1200
10
2.5
10
500
250
1.0
1.5
2RM600-8
2RM800M-8-S
800±20%
1400
10
2.5
10
500
250
1.0
1.5
2RM800-8
2RM1000M-8-
1000±20%
1700
10
2.5
10
500
250
1.0
1.5
2RM1000-8
S
2RP075M-8-S
75±20%
600
25
1.0
1.5
2RP075-8
2RP090M-8-S
90±20%
600
50
1.0
1.5
2RP090-8
2RP150M-8-S
150±20%
600
100
1.0
1.5
2RP150-8
2RP230M-8-S
230±20%
700
100
1.0
1.5
2RP230-8
2RP250M-8-S
250±20%
700
100
1.0
1.5
2RP250-8
2RP300M-8-S
300±20%
900
100
1.0
1.5
2RP300-8
2RP350M-8-S
350±20%
900
100
1.0
1.5
2RP350-8
2RP420M-8-S
420±20%
1000
100
1.0
1.5
2RP420-8
2RP470M-8-S
470±20%
1000
250
1.0
1.5
2RP470-8
2RP600M-8-S
600±20%
1200
250
1.0
1.5
2RP600-8
2RP800M-8-S
800±20%
1400
250
1.0
1.5
2RP800-8
2RP1000M-8-S
1000±20%
1700
250
1.0
1.5
2RP1000-8
3/5
1MHz
(pF)
2R-8*6(S) SERIES
Electrical Ratings
Items
Test Condition/Description
DC Spark-over
Voltage
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
Maximum Impulse
Spark-over Voltage
The maximum impulse spark-over voltage is measured with voltage ramp
dv/dt=1000V/μs.
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval time,
without causing the DC spark-over voltage to change more than 25% from
its initial value.
Crest value
100
90
Current (%)
Impulse
Discharge Current
To meet
50
the specified
20µs
10
value
8µs
Time
Impulse Width
Alternating
Discharge Current
Insulation
Resistance
Capacitance
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval
time 3 min. DC spark-over voltage shall not change more than ±25% from
8
its initial value.IR>10 ohms (-20%, +30% for 70~90V).
The resistance of gas tube shall be measured between two electrodes.
The capacitance of gas tube shall be measured between two electrodes.
Test frequency: 1MHz
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
4/5
2R-8*6(S) SERIES
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
20-40 seconds
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
Packaging
Tape
Symbol
Reel
t
D
Dimension (mm)
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.20
P2
2.00
±0.10
D0
1.55
±0.05
E
1.75
±0.10
F
7.50
±0.10
A0
6.35
±0.10
K0
6.55
±0.10
B0
8.65
±0.10
t0
0.50
±0.10
D
330.00
±2.00
d
13.00
±0.50
L
20.00
±2.00
t
2.00
±0.20
d
L
Quantity: 600pcs
5/5
很抱歉,暂时无法提供与“2RM090M-8-SN”相匹配的价格&库存,您可以联系我们找货
