2RM1000L-8
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs.
■ Stable breakdown voltage.
■ High insulation resistance.
■ Low capacitance (≤1.5pF)
■ High holdover voltage
■ Large absorbing transient current capability.
■ Micro-Gap Design
■ Size: 8.0mm*8.0mm
■ Storage and operating temperature: -40℃ ~ +85℃
■ Meets MSL level 1, per J-STD-020
■ Safety certification: UL: E327997
Applications
Repeaters, Modems.
Telephone Interface, Line cards.
Data communication equipment.
Line test equipment
Part Number Code
2
M
R
1
Electrical
Characteristics
M: 10KA
Electrode Numbers
2R: 2 Electrodes
L
Lead Type
L: Lead
DC
Spark-over
Voltage
8
L5
Internal Control Code
Dimensions
8: 8.0mm×8.0mm
Marking
Revision:20-Sep-17
www.brightking.com
2RM1000L-8
Dimensions
Dimension (mm)
Symbol
Spec.
Tolerance
D
8.0
+0.3, -0.5
T
8.0
+0.6, -0.1
d
0.8
±0.1
L
30.0
Max.
Electrical Characteristics
Model Number:2RM1000L-8
Part Number:2RM1000L-8 –L5
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
1 time
50Hz,1sec
10/1000μs
100A
Test
Voltage
(V)
(V)
(KA)
(A)
(times)
DC(V)
1000~1400
2000
10
5
100
250
Minimum
Insulation
Resistance
(GΩ)
Maximum
Capacitance
1MHz
Device
Marking
Code
(pF)
1.0
1.5
2RM1000-8
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs.
Maximum 8/20μs surge current that can be applied between two
electrodes, without causing the DC spark-over voltage to change more
than 25% from its initial value.
To meet
the specified
value
Impulse
Discharge Current
Revision:20-Sep-17
www.brightking.com
2RM1000L-8
Alternating
Discharge Current
Insulation
Resistance
Capacitance
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval
time 3 min. DC spark-over voltage shall not change more than ±25%
IR>108 ohms
The resistance of gas tube shall be measured between two electrodes.
The capacitance of gas tube shall be measured between two electrodes.
Test frequency: 1MHz
Recommended Soldering Conditions
Wave Soldering
Revision:20-Sep-17
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
www.brightking.com
2RM1000L-8
Packaging
Axial Packing (Bulk)
Skin packing
Dimension (mm)
Symbol
Spec.
Tolerance
A
264.0
±1.0
B
145.0
±1.0
H
6.5
±0.5
Quantity: 100pcs
Inner box
A0
270.0
±2.0
B0
150.0
±1.0
H0
50.0
±1.0
Quantity: 500pcs
Revision:20-Sep-17
www.brightking.com
很抱歉,暂时无法提供与“2RM1000L-8-L5/B”相匹配的价格&库存,您可以联系我们找货
