30KPA SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
Glass passivated junction
Low inductance
Excellent clamping capability
30000W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.05%
Fast response time
Typical IR less than 2μA above 40V.
High Temperature soldering guaranteed: 265℃/10 seconds/.375″,
(9.5mm) lead length, 5lbs (2.3kg) tension
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
Mechanical Data
Case: Moulded plastic over glass passivated junction
Terminal: Plated Axial leads, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Mounting Position: Any
Weight: 2.46g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Fig.1)
PPPM
Minimum
30000
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
8.0
Watts
IFSM
400
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
8
℃/W
Typical thermal resistance junction to ambient
RθJA
40
℃/W
Steady state power dissipation at TL=75℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note2, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:TVS-30KPA SERIES-001(A1)
1/6
http://brightking.pulseelectronics.com
30KPA SERIES
Dimensions (P600)
Millimeters
Cathode Band
d
DIA.
T
Min.
Max.
Min.
Max.
L
25.40
1.000
T
8.60
9.10
0.340
0.360
d
8.60
9.10
0.340
0.360
s
1.19
1.32
0.047
0.052
s
DIA.
L
Inches
Symbol
L
Electrical Characteristics (TA=25℃)
Part Number
Reverse
Breakdown
Stand-Off
Voltage
Voltage
@IT
Test
Current
Maximum
Peak
Reverse
Clamping
Pulse
Leakage
Voltage @IPP
Current
@VRWM
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
30KPA28A
30KPA28CA
28.0
31.28~34.57
50
50.0
606.0
5000
30KPA30A
30KPA30CA
30.0
33.51~37.04
50
55.2
548.9
5000
30KPA33A
30KPA33CA
33.0
36.90~40.78
50
58.5
517.9
5000
30KPA36A
30KPA36CA
36.0
40.20~44.43
50
61.8
490.3
5000
30KPA39A
30KPA39CA
39.0
43.60~48.19
450.9
2000
30KPA42A
30KPA42CA
42.0
46.90~51.84
10
72.0
420.8
1000
30KPA43A
30KPA43CA
43.0
48.00~53.05
10
73.0
415.1
1000
30KPA45A
30KPA45CA
45.0
50.30~55.59
5
77.4
391.5
250
30KPA48A
30KPA48CA
48.0
53.60~59.24
5
81.6
371.3
150
30KPA51A
30KPA51CA
51.0
57.00~63.00
5
86.4
350.7
50
30KPA54A
30KPA54CA
54.0
60.30~66.65
5
91.4
331.5
30KPA58A
30KPA58CA
58.0
64.80~71.62
5
92.4
327.9
30KPA60A
30KPA60CA
60.0
67.00~74.05
5
102.0
297.1
15
30KPA64A
30KPA64CA
64.0
71.50~79.03
5
104.0
291.3
10
30KPA66A
30KPA66CA
66.0
73.70~81.46
5
107.0
283.2
2
30KPA70A
30KPA70CA
70.0
78.20~86.43
5
109.0
278.0
2
30KPA71A
30KPA71CA
71.0
79.30~87.65
5
111.5
271.7
2
30KPA72A
30KPA72CA
72.0
80.40~88.86
5
114.0
265.8
2
30KPA75A
30KPA75CA
75.0
83.80~92.62
5
119.4
253.8
2
30KPA78A
30KPA78CA
78.0
87.10~96.27
5
129.0
234.9
2
30KPA84A
30KPA84CA
84.0
93.80~103.67
5
139.2
217.7
2
30KPA90A
30KPA90CA
90.0
100.50~111.08
5
146.4
207.0
2
30KPA96A
30KPA96CA
96.0
107.20~118.48
5
156.0
194.2
2
2/6
30KPA SERIES
Part Number
Reverse
Breakdown
Stand-Off
Voltage
Voltage
@IT
Test
Current
Maximum
Peak
Reverse
Clamping
Pulse
Leakage
Voltage @IPP
Current
@VRWM
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
30KPA102A
30KPA102CA
102.0
113.90~125.89
5
165.6
183.0
2
30KPA108A
30KPA108CA
108.0
120.60~133.29
5
175.2
172.9
2
30KPA120A
30KPA120CA
120.0
134.00~148.11
5
194.4
155.9
2
30KPA132A
30KPA132CA
132.0
147.40~162.92
5
213.0
142.3
2
30KPA144A
30KPA144CA
144.0
160.80~177.73
5
223.2
135.8
2
30KPA150A
30KPA150CA
150.0
167.60~185.24
5
233.4
129.8
2
30KPA156A
30KPA156CA
156.0
174.30~192.65
5
245.0
123.7
2
30KPA160A
30KPA160CA
160.0
178.70~197.51
5
252.6
120.0
2
30KPA168A
30KPA168CA
168.0
187.70~207.46
5
272.4
111.2
2
30KPA170A
30KPA170CA
170.0
189.90~209.89
5
275.0
110.2
2
30KPA180A
30KPA180CA
180.0
201.10~222.27
5
290.4
104.3
2
30KPA198A
30KPA198CA
198.0
221.20~244.48
5
319.8
94.7
2
30KPA216A
30KPA216CA
216.0
241.30~266.70
5
348.6
86.9
2
30KPA240A
30KPA240CA
240.0
268.10~296.32
5
387.0
78.3
2
30KPA258A
30KPA258CA
258.0
288.20~318.54
5
416.4
72.8
2
30KPA260A
30KPA260CA
260.0
290.40~320.97
5
416.0
72.8
2
30KPA270A
30KPA270CA
270.0
301.60~333.35
5
436.2
69.5
2
30KPA280A
30KPA280CA
280.0
312.80~345.73
5
464.0
65.3
2
30KPA288A
30KPA288CA
288.0
321.70~355.56
5
469.9
64.5
2
Notes: For bidirectional type having VRWM of 60V and less, the IR limit is double.
3/6
30KPA SERIES
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
Figure 1. Peak Pulse Power Rating Curve
PPPM - Peak Pulse Power (kW)
1000
100
10
1
1
10
100
100
75
50
25
25
td-Pulse Width (µs)
Half Value IPPM (IPPM/2)
200
Uni-directional V=0V
1000
Uni-directional @VR
100
50
Bi-directional @VR
10/1000µs Waveform
as defined by R.E.A
10
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
td
2.0
3.0
1
4.0
t-Time (ms)
IFSM - Peak Forward Surve Current (A)
8
7
6
5
4
L= 0.375″(9.5mm)
Lead Lengths
2
1
50
75 100 125 150
TL-Lead Temperature (℃)
100
150
200
250
300
350
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
9
3
50
VBR-Reverse Breakdown Voltage (V)
Figure 5. Steady State Power Dissipation Derating
Curve
PM(AV), Steady State Power Dissipation (W)
150 175
Bi-directional V=0V
10000
Peak Value IPPM
100
100 125
100000
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
75
Figure 4. AC Line Protection Application
Figure 3. Pulse Waveform
150
50
TA-Ambient Temperature (℃)
175
200
450
400
350
300
250
200
150
100
50
10
100
Number of Cycles at 60Hz
4/6
30KPA SERIES
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Recommended Conditions
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
Marking Code
Cathode Band
Logo
YXXX
30KPA28A
Date Code
Logo
Marking Code
YXXX
30KPA28CA
Date Code
Marking Code
5/6
30KPA SERIES
Part Number Code
30KPA XXX C A
5% V BR Voltage Tolerance
Bidirectional
V R WM Voltage
S eries C ode
Ordering Code for Different Package
Box package: Add suffix “/B” at the end of the part number, such as 30KPA75A/B
Reel package: Add suffix “/TR13” at the end of the part number, such as 30KPA160CA/TR13
Packaging
Tape
Z
±5°
A
E
L1
B
L2
T
E
Box
H
Symbol
Dimension (mm)
A
10.0±0.5
B
53.0±1.0
Z
1.2Max.
T
6.0±0.4
E
0.8Max.
L1-L2
1.0Max.
L
250.0±5.0
W
75.0±5.0
H
114.0±5.0
L
W
Quantity: 300PCS
Reel
D0
D
D1
D
330.0±3.0
D0
16.4±2.0
D1
86.0±2.0
W1
76.0±3.0
W1
Quantity: 800PCS
6/6
很抱歉,暂时无法提供与“30KPA150CA”相匹配的价格&库存,您可以联系我们找货
