4532-401-LF-VC650
4532-401-LF-VC650
    BRIGHTKING(君耀)
    400V 2KA 2端 1812GDT
4532-401-LF-VC650 数据手册
4532 SERIES Gas Discharge Tube (GDT) Data Sheet Features ■ High insulation resistance ■ Low capacitance (≤0.5pF) ■ 2KA 8/20μs maximum surge current capacity in accordance with IEC 61000-4-5& IEC 61643-311 ■ 4KV 10/700μs maximum surge rating in accordance with ITU-TK.21 ■ Surface mounted gas arrester ■ Micro-Gap Design ■ Size 4532(1812) ■ Storage and operating temperature: -40℃ ~ +90℃ ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL E244458 & TUV No. B 096048 0011 Applications ■ Repeaters, Modems ■ Telephone Interface, Line cards ■ Data communication equipment ■ Line test equipment Part Number Code and Marking 4532 XXX LF Lead Free 090: Device Marking Code DC Spark-over Voltage Size Dimensions 1.5mm 4.5±0.3mm 2.7±0.3mm 4.2mm 3.2±0.3mm 3.2±0.3mm 0.5±0.1mm 3.0mm Recommended Pad Size Revision: GDT-4532 SERIES-001(A3) 2 / 5 http://brightking.pulseelectronics.com 4532 SERIES Electrical Characteristics DC Spark-over Voltage Maximum Impulse Spark-over Voltage Nominal Impulse Discharge Current Impulse Withstanding Voltage Capacity 100V/s 1000V/μs 8/20μs 10times 10/700μs 10times Test Voltage Part Number Minimum Insulation Resistance Maximum Capacitance (1MHz 1V) Device Marking Code (GΩ) (V) (V) (KA) (KV) DC(V) (pF) 4532-075-LF 75±30% 600 2 4 50 1 0.5 075 4532-091-LF 90±30% 700 2 4 50 1 0.5 090 4532-121-LF 120±30% 700 2 4 50 1 0.5 120 4532-151-LF 150±30% 700 2 4 50 1 0.5 150 4532-201-LF 200±30% 750 2 4 100 1 0.5 200 4532-231-LF 230±30% 750 2 4 100 1 0.5 230 4532-301-LF 300±30% 900 2 4 100 1 0.5 300 4532-351-LF 350±30% 900 2 4 100 1 0.5 350 4532-401-LF 400±30% 1000 2 4 100 1 0.5 400 4532-421-LF 420±30% 1000 2 4 100 1 0.5 420 4532-471-LF 470±30% 1000 2 4 100 1 0.5 470 4532-501-LF 500±30% 1100 2 4 100 1 0.5 500 4532-601-LF 600±30% 1200 1 4 100 1 0.5 600 4532-801-LF 800±30% 1600 1 4 100 1 0.5 800 4532-1000-LF 1000±20% 2400 1 4 100 1 0.5 102 4532-1200-LF 1200±20% 2600 1 4 100 1 0.5 122 4532-1500-LF 1500±20% 2800 1 4 100 1 0.5 152 Electrical Ratings Items DC Spark-over Voltage Maximum Impulse Spark-over Voltage Insulation Resistance Capacitance Impulse Discharge Current Impulse Withstanding Voltage Test Condition/Description Requirement The voltage is measured with voltage ramp dv/dt=100V/s. The maximum impulse spark-over voltage is measured with voltage ramp dv/dt=1000V/μs. The resistance of gas tube shall be measured between two electrodes. The capacitance of gas tube shall be measured between two electrodes. Test frequency: 1MHz To meet the specified value Maximum 8/20μs surge current that can be applied between two electrodes, 5 positive and 5 negative surges, with 3 minutes interval time. The maximum 10/700μs surge that can be applied to the Gas Tube, 5 positive and 5 negative surges, with 1 minute interval time. Revision: GDT-4532 SERIES-001(A3) 3 / 5 http://brightking.pulseelectronics.com 4532 SERIES Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (ts) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate 6℃/second max. Time 25℃ to Peak Temperature Revision: GDT-4532 SERIES-001(A3) 20-40 seconds 8 minutes max. 4 / 5 http://brightking.pulseelectronics.com 4532 SERIES Packaging Tape Dimension (mm) Items P2 P1 B t0 E F D1 A A B0 P0 W D0 K0 B Spec. Tolerance W 12.00 ±0.20 P0 4.00 ±0.10 P1 8.00 ±0.20 P2 2.00 ±0.10 D0 1.55 ±0.10 D1 1.00 ±0.10 E 1.75 ±0.10 F 5.50 ±0.10 A0 3.80 ±0.10 K0 3.20 ±0.10 B0 4.90 ±0.10 t0 0.40 ±0.10 D 330.00 ±2.00 d 13.00 ±0.50 L 16.00 ±2.00 t 2.00 ±0.20 SECTION B-B A0 SECTION A-A Reel t D d L Revision: GDT-4532 SERIES-001(A3) Quantity: 2500pcs 5 / 5 http://brightking.pulseelectronics.com
