151KD10J-C10
Metal Oxide Varistor (MOV) Data Sheet
Features
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
■ Operating Temperature:-40℃ ~ +105℃
■ Storage Temperature:-40℃ ~ +125℃
■ Safety certification:UL、CSA、VDE
Applications
■ Transistor, diode, IC, thyristor or triac semiconductor protection
■ Surge protection in consumer electronics
■ Surge protection in industrial electronics
■ Surge protection in electronic home appliances, gas and petroleum appliances
■ Relay and electromagnetic valve surge absorption
Part Number Code
1
5
1
K
D
1
Tolerance
K: ±10%
Type
D: Disk
J
Surge Series
J: High Surge type
C10:Internal Control Code
Varistor Voltage
151: 150V
Revision:MOV-151KD10J-C10-001(A0)
Element Diameter
http://brightking.pulseelectronics.com
151KD10J-C10
Dimensions
D
Symbol
Dimension (mm)
H
10.5~16.0
L(±1.0)
10.0
D
10.0~12.5
F(±0.8)
7.5
T
2.2~5.4
d(±0.05)
0.8
e(±0.8)
1.8
H
T
F
K≤3.0
e
L
d
Electrical Characteristics
Model Number:151KD10J
Maximum
Part Number:151KD10J-C10
Varistor
Allowable
Voltage
Voltage
Maximum
Withstanding
Maximum
Clamping
Surge
Energy
Voltage
current
(10/1000μs)
Rated
Leakage
Power
Current
Typical
Capacitance
(Reference)
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
(J)
(W)
@80% of
V1mA (μA)
@1KHz (pf)
95
125
150(135~165)
25
250
3500
25.0
0.4
≤25
670
Marking Code
① Brightking Logo
② Varistor Voltage
①
③ UL Accreditation Logo
XXXKDXXX
②
③
④
XXX Y
VDE
⑤
⑥
⑦
④ VDE Accreditation Logo
⑤“J”is High Surge Code, no“J”is Standard Surge
⑥ Disk Size
⑦ Internal control code
151KD10J-C10
Electrical Ratings
Items
Varistor Voltage
Maximum Allowable
Voltage
Test Condition/Description
Requirement
The voltage between the two terminals with the specified measuring
current 1mA.DC applied is called Vb.
The recommended maximum sine wave voltage (RMS) or the
Maximum DC voltage can be applied continuously.
The maximum voltage between the two terminals with the
specification standard impulse current.
Applied waveform: 8/20μs
Crest value
100
90
Current (%)
Maximum Clamping
Voltage
To meet the
50
Specified value
20µs
10
8µs
Time
Impulse Width
Rated Wattage
Energy
Withstanding Surge
Current
The maximum average power that can be applied within the
specified ambient temperature.
The maximum energy within the varistor voltage change of ±10%
when one impulse of 10/1000μs or 2ms is applied.
The maximum current within the varistor voltage change of ±10%
with the standard impulse current (8/20μs) applied one time.
V1mA@105℃-V1mA@25℃
V1mA@25℃
Varistor Voltage
1
× 100%(%/℃)
80
≤0.05%/℃
Temp. Coefficient
V1mA@-40℃-V1mA@25℃
V1mA@25℃
1
× 100%(%/℃)
65
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
Surge Life
180K to 680K
50A (8/20μs)
820K to 112K
100A (8/20μs)
10Φ series
151KD10J-C10
Mechanical Characteristics
Items
Test conditions / Methods
Specifications
Gradually applying the force specified and keeping the unit
fixed for 10±1 sec.
Tensile Strength
of Terminals
Bending Strength
of Terminals
Vibration
Terminal diameter (mm)
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
1.0
2.0
4.0
Hold specimen and apply the force specified below to each
lead. Bend the specimen to 90°, then return to the original
position. Repeat the procedure in the opposite direction.
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
0.5
1.0
2.0
Frequency range: 10~55 Hz
2
Amplitude: 0.75mm or 98m/s
Direction: 3 mutually perpendicular directions, 2hrs each.
Solder ability
Solder Temp: 245±5℃
Dipping Time: 2±0.5 sec
Resistance to
Soldering Heat
Solder Temp: 260±5℃
Dipping Time: 10±1 sec
No visible damage
| V1mA/V1mA |≤5%
No visible damage
| V1mA/V1mA |≤5%
No visible damage
| V1mA/V1mA |≤5%
At least 95% of terminal
electrode is covered by
new solder
No visible damage
| V1mA/V1mA |≤10%
Reliability
Items
Specifications
High Temperature
Storage
Ambient Temp: 125±2℃
Duration: 1000hrs
| V1mA/V1mA |≤5%
Low Temperature
Storage
Ambient Temp: -40±2℃
Duration: 1000hrs
| V1mA/V1mA |≤5%
Ambient Temp: 40±2℃, 90~95% R.H.
Duration: 1000hrs
| V1mA/V1mA |≤5%
Humidity
The conditions shown below shall be repeated 5 cycles
Temperature Cycle
Step
Temperature (℃)
Period (minutes)
1
-40±3
30±3
2
Room temperature
15±3
3
125±3
30±3
4
Room temperature
15±3
No visible damage
| V1mA/V1mA |≤5%
High Temperature
Load
Ambient Temp: 105±2℃
Duration: 1000hrs
Load: Max. Allowable Voltage In AC eara.
| V1mA/V1mA|≤10%
Damp Heat Load
Duration: 1000hrs
No visible damage
| V1mA/V1mA |≤10%
Metal balls method, 2500Vac 1 min.
No visible damage
Voltage Proof
151KD10J-C10
Maximum Surge Current Derating Curve
151KD10J
10000
1
2
Max. Surge Current (A)
1000
100
10
102
103
1045
106
10
10
1
0.1
10
100
1000
10000
Td (μs)
Maximum Leakage Current and Maximum Clamping Voltage Curve
151KD10J-C10
Soldering Recommendation
Lead-free Wave Soldering Recommendation
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
Taping Dimensions
Packaging Dimensions (Unit: mm)
Quantity
0M
ax
In bulk for Terminals Trimmed Products
16
66 Max.
500pcs/bag
4bags/box
252 Max.
很抱歉,暂时无法提供与“151KD10J-C10”相匹配的价格&库存,您可以联系我们找货
