2R-8*8 SERIES
DATA SHEET
GAS DISCHARGE TUBE – 2R-8*8 SERIES
FEATURES
Provide ultra-fast response to surge voltage from slow-rising surge of
100V/s to rapid-rising surge of 1KV/ȝs.
Stable breakdown voltage.
High insulation resistance.
Low capacitance (1.5pF).
High holdover voltage.
Large absorbing transient current capability.
Micro-Gap Design
Storage and operational temperature: -40ć ~ +85ć
Meets MSL level 1, per J -STD-020
APPLICATION
Repeaters, Modems.
Telephone Interface, Line cards.
Data communication equipment.
Line test equipment.
PART NUMBER CODE
2
R
8
Electrical
Characteristics
H : 2.5KA
K : 3KA
L : 5KA
Electrode Numbers
2R : 2 Electrodes
Revision:09-Feb-12
Lead Type
L : Lead
M : SMD
DC
Spark-over
Dimensions
8 : 8.0mm*8.0mm
Voltage
www.brightking.com
2R-8*8 SERIES
DIMENSIONS
unit :mm
d
Dimension
Items
Spec.
Tolerance
D
8.0
+0.3,-0.5
T
8.0
+0.6,-0.1
0.8
±0.05
1.0
±0.05
L
30.0
Max.
D
8.0
+0.3,-0.5
T
8.0
+0.6,-0.1
B
1.1
±0.4
L
D
T
d
ELECTRICAL CHARACTERISTIC
DC
Spark-over
Voltage
Maximum
Impulse
Breakdown
Voltage
100V/s
1000V/ȝs
Part Number
Nominal
Impulse
Discharge
Current
8/20ȝs
10times
Altemating
Discharge
Current
Impulse
Life
Minimum
Insulation
Resistance
50Hz,1sec
10/1000ȝs
100A
Test
Voltage
Maximum
Capacitance
1MHz
Device
Marking
Code
(G)
(V)
(V)
(KA)
(A)
(times)
DC(V)
2RH1400L-8 2RH1400M-8
1400±20%
2200
2.5
2.5
100
500
1.0
1.5
2RH1400-8
2RH1600L-8 2RH1600M-8
1600±20%
2400
2.5
2.5
100
500
1.0
1.5
2RH1600-8
2RH2000L-8 2RH2000M-8
2000±20%
2800
2.5
2.5
100
500
1.0
1.5
2RH2000-8
2RH2500L-8 2RH2500M-8
2500±20%
3600
2.5
2.5
100
500
1.0
1.5
2RH2500-8
2RH2700L-8 2RH2700M-8
2700±20%
3800
2.5
2.5
300*
1000
1.0
1.5
2RH2700-8
2RH3000L-8 2RH3000M-8
3000±20%
4200
2.5
2.5
100
1000
1.0
1.5
2RH3000-8
2RH3500L-8 2RH3500M-8
3500±20%
5000
2.5
2.5
100
1000
1.0
1.5
2RH3500-8
2RK2700L-8 2RK2700M-8
2700±20%
3800
3.0
3.0
300*
1000
1.0
1.5
2RK2700-8
2RK3000L-8 2RK3000M-8
3000±20%
4200
3.0
3.0
300*
1000
1.0
1.5
2RK3000-8
2RK3500L-8 2RK3500M-8
3500±20%
5000
3.0
3.0
100
1000
1.0
1.5
2RK3500-8
2RK4000L-8 2RK4000M-8
4000±20%
5500
3.0
3.0
100
1000
1.0
1.5
2RK4000-8
2RK5000L-8 2RK5000M-8
5000±20%
6400
3.0
3.0
100
1000
1.0
1.5
2RK5000-8
2RK6000L-8 2RK6000M-8
6000±20%
7800
3.0
3.0
100
1000
1.0
1.5
2RK6000-8
2RL1000L-8 2RL1000M-8
1000±20%
1400
5.0
5.0
100
500
1.0
1.5
2RL1000-8
2RL1400L-8 2RL1400M-8
1400±20%
2200
5.0
5.0
100
500
1.0
1.5
2RL1400-8
2RL1600L-8 2RL1600M-8
1600±20%
2400
5.0
5.0
100
500
1.0
1.5
2RL1600-8
2RL2000L-8 2RL2000M-8
2000±20%
2800
5.0
5.0
100
500
1.0
1.5
2RL2000-8
2RL2500L-8 2RL2500M-8
2500±20%
3600
5.0
5.0
100
1000
1.0
1.5
2RL2500-8
(pF)
*Measured with an 8/20ȝs waveform ,100A
Revision:09-Feb-12
www.brightking.com
2R-8*8 SERIES
ELECTRICAL RATING
Item
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition / Description
Requirement
The voltage is measured with a low rate of rise dv / dt=100V/s
The maximum impulse breakdown voltage is measured with a rise time of
dv / dt=1000V/ s
The maximum current applying a waveform of 8/20ȝs that can be applied
across the terminals of the gas tube without causing the gas tube to
change more than ±25% from its initial measured DC breakdown voltage.
Dwell time between pulses is 3 minutes.
Impulse
Discharge Current
To meet
the specified
value
Alternating
Discharge Current
Rated RMS value of AC current at 50Hz, 1 sec. 10 times. Intervals: 3min.
DC breakdown voltage may not change more than ±25% from its initial
IR > 108 ohms (-20%, +30% for 70 – 90V).
The resistance of gas tube shall be measured each terminal each other
Insulation Resistance terminal.please see above spec
Capacitance
Revision:09-Feb-12
The capacitance of gas tube shall be measured each terminal to each
other terminal.
Test frequency :1MHz
www.brightking.com
很抱歉,暂时无法提供与“2RH3500L-8/B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.53887
- 50+2.00686
- 200+1.77898
- 国内价格
- 1+1.74900
- 50+1.34200
- 500+1.24300
- 国内价格
- 5+2.80952
- 50+2.26606
- 200+1.87143
