3KP SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
Glass passivated junction
Low inductance
Excellent clamping capability
3000W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 2μA above 10V.
High Temperature soldering guaranteed: 265℃/10 seconds/.375″,
(9.5mm) lead length, 5lbs (2.3kg) tension
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
Mechanical Data
Case: Moulded plastic over glass passivated junction
Terminal: Plated Axial leads, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Mounting Position: Any
Weight: 2.02g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Fig.1)
PPPM
Minimum
3000
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
7.0
Watts
IFSM
300
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
8
℃/W
Typical thermal resistance junction to ambient
RθJA
40
℃/W
Steady state power dissipation at TL=75℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note2, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:TVS-3KP SERIES-001(A2)
1/6
http://brightking.yageo.com
3KP SERIES
Dimensions (P600)
Millimeters
Cathode Band
d
DIA.
T
Min.
Max.
Min.
Max.
L
25.40
1.000
T
8.60
9.10
0.340
0.360
d
8.60
9.10
0.340
0.360
s
1.19
1.32
0.047
0.052
s
DIA.
L
Inches
Symbol
L
Electrical Characteristics (TA=25℃)
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage @IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
3KP5.0A
3KP5.0CA
5.0
6.40~7.00
10
9.2
326.1
5000
3KP6.0A
3KP6.0CA
6.0
6.67~7.37
10
10.3
291.3
5000
3KP6.5A
3KP6.5CA
6.5
7.22~7.98
10
11.2
267.9
2000
3KP7.0A
3KP7.0CA
7.0
7.78~8.60
10
12.0
250.0
1000
3KP7.5A
3KP7.5CA
7.5
8.33~9.21
1
12.9
232.6
250
3KP8.0A
3KP8.0CA
8.0
8.89~9.83
1
13.6
220.6
150
3KP8.5A
3KP8.5CA
8.5
9.44~10.40
1
14.4
208.3
50
3KP9.0A
3KP9.0CA
9.0
10.00~11.10
1
15.4
194.8
3KP10A
3KP10CA
10.0
11.10~12.30
1
17.0
176.5
15
3KP11A
3KP11CA
11.0
12.20~13.50
1
18.2
164.8
2
3KP12A
3KP12CA
12.0
13.30~14.70
1
19.9
150.8
2
3KP13A
3KP13CA
13.0
14.40~15.90
1
21.5
139.5
2
3KP14A
3KP14CA
14.0
15.60~17.20
1
23.2
129.3
2
3KP15A
3KP15CA
15.0
16.70~18.50
1
24.4
123.0
2
3KP16A
3KP16CA
16.0
17.80~19.70
1
26.0
115.4
2
3KP17A
3KP17CA
17.0
18.90~20.90
1
27.6
108.7
2
3KP18A
3KP18CA
18.0
20.00~22.10
1
29.2
102.7
2
3KP20A
3KP20CA
20.0
22.20~24.50
1
32.4
92.6
2
3KP22A
3KP22CA
22.0
24.40~26.90
1
35.5
84.5
2
3KP24A
3KP24CA
24.0
26.70~29.50
1
38.9
77.1
2
3KP26A
3KP26CA
26.0
28.90~31.90
1
42.1
71.3
2
3KP28A
3KP28CA
28.0
31.10~34.40
1
45.4
66.1
2
3KP30A
3KP30CA
30.0
33.30~36.80
1
48.4
62.0
2
2/6
3KP SERIES
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage @IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
3KP33A
3KP33CA
33.0
36.70~40.60
1
53.3
56.3
2
3KP36A
3KP36CA
36.0
40.00~44.20
1
58.1
51.6
2
3KP40A
3KP40CA
40.0
44.40~49.10
1
64.5
46.5
2
3KP43A
3KP43CA
43.0
47.80~52.80
1
69.4
43.2
2
3KP45A
3KP45CA
45.0
50.00~55.30
1
72.7
41.3
2
3KP48A
3KP48CA
48.0
53.30~58.90
1
77.4
38.8
2
3KP51A
3KP51CA
51.0
56.70~62.70
1
82.4
36.4
2
3KP54A
3KP54CA
54.0
60.00~66.30
1
87.1
34.4
2
3KP58A
3KP58CA
58.0
64.40~71.20
1
93.6
32.1
2
3KP60A
3KP60CA
60.0
66.70~73.70
1
96.8
31.0
2
3KP64A
3KP64CA
64.0
71.10~78.60
1
103.0
29.1
2
3KP70A
3KP70CA
70.0
77.80~86.00
1
113.0
26.5
2
3KP75A
3KP75CA
75.0
83.30~92.10
1
121.0
24.8
2
3KP78A
3KP78CA
78.0
86.70~95.80
1
126.0
23.8
2
3KP85A
3KP85CA
85.0
94.40~104.00
1
137.0
21.9
2
3KP90A
3KP90CA
90.0
100.00~111.00
1
146.0
20.5
2
3KP100A
3KP100CA
100.0
111.00~123.00
1
162.0
18.5
2
3KP110A
3KP110CA
110.0
122.00~135.00
1
177.0
16.9
2
3KP120A
3KP120CA
120.0
133.00~147.00
1
193.0
15.5
2
3KP130A
3KP130CA
130.0
144.00~159.00
1
209.0
14.4
2
3KP150A
3KP150CA
150.0
167.00~185.00
1
243.0
12.3
2
3KP160A
3KP160CA
160.0
178.00~197.00
1
259.0
11.6
2
3KP170A
3KP170CA
170.0
189.00~209.00
1
275.0
10.9
2
3KP180A
3KP180CA
180.0
201.00~222.00
1
292.0
10.3
2
3KP190A
3KP190CA
190.0
211.00~233.00
1
308.0
9.7
2
3KP200A
3KP200CA
200.0
224.00~247.00
1
324.0
9.3
2
3KP210A
3KP210CA
210.0
237.00~263.00
1
340.0
8.8
2
3KP220A
3KP220CA
220.0
246.00~272.00
1
356.0
8.4
2
3/6
3KP SERIES
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 2. Pulse Derating Curve
100
10
1
0.1
100
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
1000
1
10
100
75
50
25
td-Pulse Width (µs)
150 175
200
Bi-directional V=0V
10000
Uni-directional V=0V
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
100 125
100000
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
1000
Uni-directional @VR
100
50
Bi-directional @VR
10/1000µs Waveform
as defined by R.E.A
10
td
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
1.0
2.0
3.0
1
4.0
Figure 5. Steady State Power Dissipation Derating
Curve
7
6
5
4
3
L= 0.375″(9.5mm)
Lead Lengths
1
50
75
100
125
150
175
200
TL-Lead Temperature (℃)
100
1000
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
IFSM - Peak Forward Surve Current (A)
8
2
10
VBR-Reverse Breakdown Voltage (V)
t-Time (ms)
PM(AV), Steady State Power Dissipation (W)
75
Figure 4. AC Line Protection Application
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
50
TA-Ambient Temperature (℃)
Figure 3. Pulse Waveform
150
25
4/6
350
300
250
200
150
100
50
10
Number of Cycles at 60Hz
100
3KP SERIES
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Recommended Conditions
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
Marking Code
Cathode Band
YXXX
Logo
3KP5.0A
YXXX
Intermal Control Code
Logo
3KP5.0CA
Marking Code
Marking Code
Part Number Code
3KP XXX C A / XXXX
Package Code
B: Box package
TR13: Reel package
5% VBR Voltage Tolerance
Bidirectional
VRWM Voltage
Series Code
5/6
3KP SERIES
Ordering Code for Different Package
Box package: Add suffix “/B” at the end of the part number, such as 3KPXXXCA/B
Reel package: Add suffix “/TR13” at the end of the part number, such as 3KPXXXCA/TR13
Packaging
Tape
Z
±5°
A
E
Symbol
Dimension (mm)
A
10.0±0.5
B
53.0±1.0
Z
1.2Max.
T
6.0±0.4
E
0.8Max.
L1-L2
1.0Max.
L
250.0±5.0
W
75.0±5.0
H
114.0±5.0
L1
B
L2
T
E
Box
H
L
Quantity: 300PCS
W
Reel
D
330.0±3.0
D0
16.4±2.0
D1
86.0±2.0
W1
76.0±3.0
D0
D1
D
W1
Quantity: 800PCS
6/6
很抱歉,暂时无法提供与“3KP26CA/B”相匹配的价格&库存,您可以联系我们找货
