25Φ SERIES
Metal Oxide Varistor (MOV) Data Sheet
Features
Wide operating voltage (V1mA) range from 18V to 1800V
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
Operating Temperature:-40℃ ~ +85℃
Storage Temperature:-40℃ ~ +125℃
Safety certification: UL: E327997
CSA: 246579
VDE: 40027827
Applications
Transistor, diode, IC, thyristor or triac semiconductor protection
Surge protection in consumer electronics
Surge protection in industrial electronics
Surge protection in electronic home appliances, gas and petroleum appliances
Relay and electromagnetic valve surge absorption
Part number code
Revision:13-Apr.-18
1/9
www.brightking.com
25Φ SERIES
Dimensions
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H
27.0~31.5
180K
2.5~4.8
1.7
361K
3.4~5.9
2.9
L(min.)
20.0
220K
2.6~4.9
1.8
391K
3.5~6.1
3.0
D
25.0~28.0
270K
2.6~5.0
2.0
431K
3.7~6.4
3.2
F(±1.0)
10.0/12.5
330K
2.7~5.2
1.9
471K
3.8~6.7
3.4
T
Table 2
390K
2.6~5.5
2.0
511K
3.9~7.0
3.6
e(±0.8)
Table 2
470K
2.7~5.1
2.1
561K
4.1~7.3
3.8
d(±0.1)
1.0
560K
2.8~5.4
2.3
621K
4.3~7.6
4.1
680K
2.9~5.7
2.6
681K
4.5~7.8
4.4
820K
2.6~4.5
2.0
751K
4.8~8.0
4.5
101K
2.9~4.6
2.2
781K
4.9~8.1
4.6
121K
2.9~4.8
2.4
821K
5.1~8.4
4.8
151K
2.7~4.9
2.0
911K
5.3~8.9
5.2
181K
2.8~5.2
2.1
102K
5.9~9.5
5.2
201K
2.9~5.2
2.2
112K
6.3~10.1
5.6
221K
3.0~5.3
2.3
122K
6.4~10.7
6.0
241K
3.1~5.8
2.4
142K
7.4~12.6
6.8
271K
3.1~5.3
2.6
162K
7.9~13.2
7.6
301K
3.2~5.5
2.7
182K
8.1~14.5
8.4
331K
3.2~5.7
2.7
Revision:13-Apr.-18
2/9
www.brightking.com
25Φ SERIES
Electrical characteristics
Part
Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
(J)
(W)
@1KHz (pf)
180KD25
11
14
18(15~21.6)
30
36
4500
45000
220KD25
14
18
22(19.5~26)
30
43
4500
25
0.25
29000
270KD25
17
22
27(24~31)
30
53
4500
30
0.25
26500
330KD25
33(29.5~36.5)
30
65
4500
35
0.25
18000
390KD25
25
31
39(35~43)
30
77
4500
40
0.25
13500
470KD25
30
38
47(42~52)
30
93
4500
50
0.25
11500
560KD25
35
45
56(50~62)
30
110
4500
60
0.25
10500
680KD25
40
56
68(61~75)
30
135
4500
70
0.25
9050
820KD25
50
65
82(74~90)
150
135
15000
80
1.2
7700
101KD25
60
85
100(90~110)
150
165
15000
100
1.2
6300
121KD25
75
100
120(108~132)
150
200
15000
120
1.2
5200
151KD25
95
125
150(135~165)
150
250
15000
160
1.2
4300
181KD25
115
150
180(162~198)
150
300
15000
175
1.2
3500
201KD25
130
170
200(180~220)
150
340
15000
190
1.2
3200
221KD25
140
180
220(198~242)
150
360
15000
200
1.2
2900
241KD25
150
200
240(216~264)
150
395
15000
220
1.2
2650
271KD25
175
225
270(243~297)
150
455
15000
255
1.2
2400
301KD25
190
250
300(270~330)
150
500
15000
275
1.2
2100
331KD25
210
275
330(297~363)
150
550
15000
300
1.2
1900
361KD25
230
300
360(324~396)
150
595
15000
330
1.2
1750
391KD25
250
320
390(351~429)
150
650
15000
360
1.2
1600
431KD25
275
350
430(387~473)
150
710
15000
380
1.2
1500
471KD25
300
385
470(423~517)
150
775
15000
400
1.2
1400
511KD25
320
415
510(459~561)
150
845
15000
420
1.2
1250
561KD25
350
460
560(504~616)
150
925
15000
440
1.2
1150
621KD25
385
505
620(558~682)
150
1025
15000
450
1.2
1050
681KD25
420
560
680(612~748)
150
1120
15000
460
1.2
950
751KD25
460
615
750(675~825)
150
1240
15000
510
1.2
850
781KD25
485
640
780(702~858)
150
1290
15000
530
1.2
850
821KD25
510
670
820(738~902)
150
1355
15000
570
1.2
800
911KD25
550
745
910(819~1001)
150
1500
15000
620
1.2
700
102KD25
625
825
1000(900~1100)
150
1650
15000
685
1.2
650
112KD25
680
895
1100(990~1210)
150
1815
15000
720
1.2
600
122KD25
750
990
1200(1080~1320)
150
1980
15000
792
1.2
550
142KD25
880
1140
1400(1260~1540)
150
2310
15000
850
1.2
500
162KD25
1000
1280
1600(1440~1760)
150
2640
15000
970
1.2
450
182KD25
1100
1465
1800(1620~1980)
150
2970
15000
1092
1.2
400
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K)
IR≤40μA (820K~182K)
Revision:13-Apr.-18
3/9
www.brightking.com
25Φ SERIES
Electrical Ratings
Items
Varistor Voltage
Maximum Allowable
Voltage
Test Condition/Description
Requirement
The voltage between two terminals with the specified measuring
current 1mA.DC applied is called Vb.
The recommended maximum sine wave voltage (RMS) or the
Maximum DC voltage can be applied continuously.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
Maximum Clamping
Voltage
To meet the
Specified value
Rated Wattage
The maximum average power that can be applied within the
specified ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10%
when one impulse of 10/1000μs or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10%
with the standard impulse current (8/20μs) applied one time.
Varistor Voltage
Temp. Coefficient
≤0.05%/℃
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
Surge Life
25Φ series
Revision:13-Apr.-18
180K to 680K
250A (8/20μs)
820K to 182K
450A (8/20μs)
4/9
ΔVb
Vb
10%
www.brightking.com
25Φ SERIES
Soldering Recommendation
Wave Lead Free Soldering Recommendation
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Revision:13-Apr.-18
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
5/9
www.brightking.com
25Φ SERIES
Mechanical Characteristics
Items
Test conditions / Methods
Specifications
Gradually applying the force specified and keeping the unit
fixed for 10±1 sec.
Tensile Strength
of Terminals
Bending Strength
of Terminals
Vibration
No visible damage
|ΔV1mA/V1mA |≤5%
Hold specimen and apply the force specified below to each
lead. Bend the specimen to 90°, then return to the original
position. Repeat the procedure in the opposite direction.
Frequency range: 10~55 Hz
Amplitude: 0.75mm or 98m/s2
Direction: 3 mutually perpendicular directions, 2hrs each.
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Solder ability
Solder Temp: 245±5℃
Dipping Time: 2±0.5 sec
At least 95% of terminal
electrode is covered by
new solder
Resistance to
Soldering Heat
Solder Temp: 260±5℃
Dipping Time: 10±1 sec
No visible damage
|ΔV1mA/V1mA |≤10%
Reliability
Items
Specifications
High Temperature
Storage
Ambient Temp: 125±2℃
Duration: 1000hrs
|ΔV1mA/V1mA |≤5%
Low Temperature
Storage
Ambient Temp: -40±2℃
Duration: 1000hrs
|ΔV1mA/V1mA |≤5%
Ambient Temp: 40±2℃, 90~95% R.H.
Duration: 1000hrs
|ΔV1mA/V1mA |≤5%
Humidity
The conditions shown below shall be repeated 5 cycles
Temperature Cycle
Step
Temperature (℃)
Period (minutes)
1
-40±3
30±3
2
Room temperature
15±3
3
125±3
30±3
4
Room temperature
15±3
No visible damage
|ΔV1mA/V1mA |≤5%
High Temperature
Load
Ambient Temp: 105±2℃
Duration: 1000hrs
Load: Max. Allowable Voltage In AC eara.
|ΔV1mA/V1mA|≤10%
Damp Heat Load
Duration: 1000hrs
No visible damage
|ΔV1mA/V1mA |≤10%
Metal balls method, 2500Vac 1 min.
No visible damage
Voltage Proof
Revision:13-Apr.-18
6/9
www.brightking.com
25Φ SERIES
Maximum Surge Current Derating Curve
180KD25 to 680KD25
10000
1
2
Max. Surge Current (A)
1000
100
10
102
103
104
105
106
10
1
0.1
10
100
1000
10000
Td (μs)
820KD25 to 182KD25
100000
10000
1
2
10
102
1000
103
104
105
100
106
10
1
10
100
1000
10000
Td (μs)
Revision:13-Apr.-18
7/9
www.brightking.com
25Φ SERIES
Maximum Leakage Current and Maximum Clamping Voltage Curve
Revision:13-Apr.-18
8/9
www.brightking.com
25Φ SERIES
Marking code
VDE
Quantity
Packaging Dimensions (Unit: mm)
Quantity
Exposure in bulk
100pcs/bag
4bags/box
(180K~621K)
50pcs/bag
4bags/box
(681K~182K)
Cut the feet in bulk
100pcs/bag
4bags/box
(180K~621K)
50pcs/bag
4bags/box
(681K~182K)
Revision:13-Apr.-18
9/9
www.brightking.com
很抱歉,暂时无法提供与“471KD25”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.77330
- 100+3.65150
- 200+3.52980
