5KP SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
Glass passivated junction
Low incremental surge resistance.
Excellent clamping capability
5000W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.05%
Fast response time
Typical IR less than 2μA above 10V.
High Temperature soldering guaranteed: 265℃/10 seconds/.375″,
(9.5mm) lead length, 5lbs (2.3kg) tension
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020.
Safety certification: UL: E244458
Mechanical Data
Case: Moulded plastic over glass passivated junction
Terminal: Plated Axial leads, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Mounting Position: Any
Weight: 2.10g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Fig.1)
PPPM
Minimum 5000
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
8.0
Watts
IFSM
400
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
8
℃/W
Typical thermal resistance junction to ambient
RθJA
40
℃/W
Steady state power dissipation at TL=75℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note2, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:TVS-5KP SERIES-001(A1)
1/6
http://brightking.pulseelectronics.com
5KP SERIES
Dimensions (P600)
Millimeters
Inches
Symbol
Cathode Band
d
DIA.
s
DIA.
T
L
L
Min.
Max.
Min.
Max.
L
25.40
1.000
T
8.60
9.10
0.340
0.360
d
8.60
9.10
0.340
0.360
s
1.19
1.32
0.047
0.052
Maximum
Peak
Reverse
Clamping
Pulse
Leakage
Voltage @IPP
Current
@VRWM
Electrical Characteristics (TA=25℃)
Part Number
Reverse
Breakdown
Stand-Off
Voltage
Voltage
@IT
Test
Current
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
5KP5.0A
5KP5.0CA
5.0
6.40~7.00
50
9.2
554.3
5000
5KP6.0A
5KP6.0CA
6.0
6.67~7.37
50
10.3
495.1
5000
5KP6.5A
5KP6.5CA
6.5
7.22~7.98
50
11.2
455.4
2000
5KP7.0A
5KP7.0CA
7.0
7.78~8.60
50
12.0
425.0
1000
5KP7.5A
5KP7.5CA
7.5
8.33~9.21
5
12.9
395.3
250
5KP8.0A
5KP8.0CA
8.0
8.89~9.83
5
13.6
375.0
150
5KP8.5A
5KP8.5CA
8.5
9.44~10.40
5
14.4
354.2
50
5KP9.0A
5KP9.0CA
9.0
10.00~11.10
5
15.4
331.2
5KP10A
5KP10CA
10.0
11.10~12.30
5
17.0
300.0
15
5KP11A
5KP11CA
11.0
12.20~13.50
5
18.2
280.2
2
5KP12A
5KP12CA
12.0
13.30~14.70
5
19.9
256.3
2
5KP13A
5KP13CA
13.0
14.40~15.90
5
21.5
237.2
2
5KP14A
5KP14CA
14.0
15.60~17.20
5
23.2
219.8
2
5KP15A
5KP15CA
15.0
16.70~18.50
5
24.4
209.0
2
5KP16A
5KP16CA
16.0
17.80~19.70
5
26.0
196.2
2
5KP17A
5KP17CA
17.0
18.90~20.90
5
27.6
184.8
2
5KP18A
5KP18CA
18.0
20.00~22.10
5
29.2
174.7
2
5KP20A
5KP20CA
20.0
22.20~24.50
5
32.4
157.4
2
5KP22A
5KP22CA
22.0
24.40~26.90
5
35.5
143.7
2
5KP24A
5KP24CA
24.0
26.70~29.50
5
38.9
131.1
2
5KP26A
5KP26CA
26.0
28.90~31.90
5
42.1
121.1
2
2/6
5KP SERIES
Part Number
Reverse
Breakdown
Stand-Off
Voltage
Voltage
@IT
Test
Current
Maximum
Peak
Reverse
Clamping
Pulse
Leakage
Voltage @IPP
Current
@VRWM
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
5KP28A
5KP28CA
28.0
31.10~34.40
5
45.4
112.3
2
5KP30A
5KP30CA
30.0
33.30~36.80
5
48.4
105.4
2
5KP33A
5KP33CA
33.0
36.70~40.60
5
53.3
95.7
2
5KP36A
5KP36CA
36.0
40.00~44.20
5
58.1
87.8
2
5KP40A
5KP40CA
40.0
44.40~49.10
5
64.5
79.1
2
5KP43A
5KP43CA
43.0
47.80~52.80
5
69.4
73.5
2
5KP45A
5KP45CA
45.0
50.00~55.30
5
72.7
70.2
2
5KP48A
5KP48CA
48.0
53.30~58.90
5
77.4
65.9
2
5KP51A
5KP51CA
51.0
56.70~62.70
5
82.4
61.9
2
5KP54A
5KP54CA
54.0
60.00~66.30
5
87.1
58.6
2
5KP58A
5KP58CA
58.0
64.40~71.20
5
93.6
54.5
2
5KP60A
5KP60CA
60.0
66.70~73.70
5
96.8
52.7
2
5KP64A
5KP64CA
64.0
71.10~78.60
5
103.0
49.5
2
5KP70A
5KP70CA
70.0
77.80~86.00
5
113.0
45.1
2
5KP75A
5KP75CA
75.0
83.30~92.10
5
121.0
42.1
2
5KP78A
5KP78CA
78.0
86.70~95.80
5
126.0
40.5
2
5KP85A
5KP85CA
85.0
94.40~104.00
5
137.0
37.2
2
5KP90A
5KP90CA
90.0
100.00~111.00
5
146.0
34.9
2
5KP100A
5KP100CA
100.0
110.00~123.00
5
162.0
31.5
2
5KP110A
5KP110CA
110.0
122.00~135.00
5
177.0
28.8
2
5KP120A
5KP120CA
120.0
133.00~147.00
5
193.0
26.4
2
5KP130A
5KP130CA
130.0
144.00~159.00
5
209.0
24.4
2
5KP150A
5KP150CA
150.0
167.00~185.00
5
243.0
21.0
2
5KP160A
5KP160CA
160.0
178.00~197.00
5
259.0
19.7
2
5KP170A
5KP170CA
170.0
189.00~209.00
5
275.0
18.5
2
5KP180A
5KP180CA
180.0
201.00~222.00
5
292.0
17.5
2
5KP190A
5KP190CA
190.0
211.00~233.00
5
310.0
16.5
2
5KP200A
5KP200CA
200.0
224.00~247.00
5
329.2
15.5
2
5KP210A
5KP210CA
210.0
237.00~263.00
5
349.5
14.6
2
5KP220A
5KP220CA
220.0
246.00~272.00
5
371.1
13.7
2
5KP250A
5KP250CA
250.0
277.00~306.00
5
425.0
12.0
2
Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double.
3/6
5KP SERIES
Ratings and Characteristic Curves (TA=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
100
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
100
10
1
0.1
0.1
1
10
100
1000
75
50
25
td-Pulse Width (µs)
150 175
200
100000
Bi-directional V=0V
10000
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
100 125
Uni-directional V=0V
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
Uni-directional @VR
1000
100
Bi-directional @VR
50
10/1000µs Waveform
as defined by R.E.A
10
td
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
1.0
2.0
3.0
1
4.0
Figure 5. Steady State Power Dissipation Derating
IFSM - Peak Forward Surve Current (A)
8
7
6
5
4
L= 0.375″(9.5mm)
Lead Lengths
1
450
400
350
300
250
200
150
100
1000
Surge Current Uni-Directional Only
9
2
100
Figure 6. Maximum Non-Repetitive Forward
Curve
3
10
VBR-Reverse Breakdown Voltage (V)
t-Time (ms)
PM(AV), Steady State Power Dissipation (W)
75
Figure 4. Typical Junction Capacitance
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
50
TA-Ambient Temperature (℃)
Figure 3. Pulse Waveform
150
25
50
75 100 125 150
TL-Lead Temperature (℃)
175
200
50
10
100
Number of Cycles at 60Hz
4/6
5KP SERIES
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
Marking Code
Cathode Band
Logo
YXXX
5KP5.0A
Date Code
Logo
Marking Code
YXXX
5KP5.0CA
Date Code
Marking Code
5/6
5KP SERIES
Part Number Code
5KP XXX C A
5% VBR Voltage Tolerance
Bidirectional
VRWM Voltage
Series Code
Ordering Code for Different Package
Box package: Add suffix “/B” at the end of the part number, such as 5KP15A-AT/B
Reel package: Add suffix “/TR13” at the end of the part number, such as 5KP100CA-AT/TR13
Packaging
Tape
Z
±5°
A
E
L1
B
L2
T
E
Box
H
Symbol
Dimension (mm)
A
10.0±0.5
B
53.0±1.0
Z
1.2Max.
T
6.0±0.4
E
0.8Max.
L1-L2
1.0Max.
L
250.0± 5.0
W
75.0± 5.0
H
114.0±5.0
L
W
Quantity: 300PCS
Reel
D0
D
D1
D
330.0±3.0
D0
16.4±2.0
D1
86.0±2.0
W1
76.0±3.0
W1
Quantity: 800PCS
6/6
很抱歉,暂时无法提供与“5KP64CA/B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.16424
- 10+3.99860
- 30+3.26776
- 300+2.92648
- 600+2.75584
- 900+2.67052
- 国内价格
- 1+2.64000
- 50+2.02400
- 300+1.88100
