15KPA170CA/B
15KPA170CA/B
    BRIGHTKING(君耀)
    R-6(P-600)
    双向 VRWM:170V
15KPA170CA/B 数据手册
15KPA SERIES Transient Voltage Suppressors (TVS) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ Glass passivated junction Low incremental surge resistance Excellent clamping capability 15000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.05% Fast response time Typical IR less than 2μA above 30V. High Temperature soldering guaranteed: 265℃/10 seconds/.375″, (9.5mm) lead length, 5lbs (2.3kg) tension Plastic package has underwriters laboratory flammability 94V-0 Meets MSL level 1, per J-STD-020. Safety certification: UL: E244458 IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ ■ ■ ■ ■ Case: Moulded plastic over glass passivated junction Terminal: Plated Axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode except bi-directional models Mounting Position: Any Weight: 2.30g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Fig.1) PPPM Minimum 15000 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 8.0 Watts IFSM 400 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 8 ℃/W Typical thermal resistance junction to ambient RθJA 40 ℃/W Steady state power dissipation at TL=75℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note2, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Revision:TVS-15KPA SERIES-001(A2) 1/6 http://brightking.yageo.com 15KPA SERIES Dimensions (P600) Millimeters Inches Symbol Cathode Band d DIA. s DIA. T L L Min. Max. Min. Max. L 25.40 - 1.000 - T 8.60 9.10 0.340 0.360 d 8.60 9.10 0.340 0.360 s 1.19 1.32 0.047 0.052 Maximum Peak Reverse Clamping Pulse Leakage Voltage @IPP Current @VRWM Electrical Characteristics (TA=25℃) Part Number Reverse Breakdown Stand-Off Voltage Voltage @IT Test Current Unidirectional Bidirectional VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 15KPA17A 15KPA17CA 17.0 18.99~21.22 50 29.3 515.4 5000 15KPA18A 15KPA18CA 18.0 20.11~22.65 50 30.9 488.7 5000 15KPA20A 15KPA20CA 20.0 22.34~24.96 20 34.3 440.2 1500 15KPA22A 15KPA22CA 22.0 24.57~27.46 10 37.1 407.0 500 15KPA24A 15KPA24CA 24.0 26.81~29.95 5 40.7 371.0 150 15KPA26A 15KPA26CA 26.0 29.04~32.45 5 44.0 343.2 50 15KPA28A 15KPA28CA 28.0 31.28~34.95 5 47.5 317.9 25 15KPA30A 15KPA30CA 30.0 33.51~37.44 5 50.7 297.8 15 15KPA33A 15KPA33CA 33.0 36.90~41.19 5 54.7 276.1 2 15KPA36A 15KPA36CA 36.0 40.20~44.93 5 59.8 252.5 2 15KPA40A 15KPA40CA 40.0 44.70~49.92 5 65.8 229.5 2 15KPA43A 15KPA43CA 43.0 48.00~53.67 5 69.8 216.3 2 15KPA45A 15KPA45CA 45.0 50.30~56.16 5 72.8 207.4 2 15KPA48A 15KPA48CA 48.0 53.60~59.91 5 77.7 194.3 2 15KPA51A 15KPA51CA 51.0 57.00~63.65 5 82.9 182.1 2 15KPA54A 15KPA54CA 54.0 60.30~67.39 5 87.7 172.2 2 15KPA58A 15KPA58CA 58.0 64.80~72.39 5 93.8 161.0 2 Revision:TVS-15KPA SERIES-001(A2) 2/6 http://brightking.yageo.com 15KPA SERIES Electrical Characteristics (TA=25℃) Part Number Reverse Breakdown Stand-Off Voltage Voltage @IT Test Current Maximum Peak Reverse Clamping Pulse Leakage Voltage @IPP Current @VRWM Unidirectional Bidirectional VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 15KPA60A 15KPA60CA 60.0 67.00~74.88 5 97.4 155.0 2 15KPA64A 15KPA64CA 64.0 71.50~79.87 5 104.2 144.9 2 15KPA70A 15KPA70CA 70.0 78.20~87.36 5 113.6 132.9 2 15KPA75A 15KPA75CA 75.0 83.80~93.60 5 122.0 123.8 2 15KPA78A 15KPA78CA 78.0 87.10~97.35 5 126.1 119.7 2 15KPA85A 15KPA85CA 85.0 94.90~106.08 5 137.6 109.7 2 15KPA90A 15KPA90CA 90.0 100.50~112.32 5 145.6 103.7 2 15KPA100A 15KPA100CA 100.0 111.70~124.80 5 161.3 93.6 2 15KPA110A 15KPA110CA 110.0 122.90~137.28 5 178.6 84.5 2 15KPA120A 15KPA120CA 120.0 134.00~149.76 5 192.3 78.5 2 15KPA130A 15KPA130CA 130.0 145.20~162.25 5 208.3 72.5 2 15KPA150A 15KPA150CA 150.0 167.60~187.21 5 241.9 62.4 2 15KPA160A 15KPA160CA 160.0 178.70~199.69 5 258.6 58.4 2 15KPA170A 15KPA170CA 170.0 189.90~212.17 5 272.7 55.4 2 15KPA180A 15KPA180CA 180.0 201.10~224.65 5 288.5 52.3 2 15KPA200A 15KPA200CA 200.0 223.40~249.61 5 319.1 47.3 2 15KPA220A 15KPA220CA 220.0 245.70~274.57 5 352.5 42.8 2 15KPA240A 15KPA240CA 240.0 268.10~299.53 5 384.6 39.3 2 15KPA260A 15KPA260CA 260.0 290.40~324.49 5 416.7 36.2 2 15KPA280A 15KPA280CA 280.0 312.80~349.45 5 454.5 33.2 2 Revision:TVS-15KPA SERIES-001(A2) 3/6 http://brightking.yageo.com 15KPA SERIES Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 1000 100 10 1 1 10 100 td-Pulse Width (µs) 25 0 50 75 100 125 150 175 200 Figure 4. Typical Junction Capacitance 100000 Bi-directional V=0V 10000 Uni-directional V=0V Peak Value IPPM 100 Half Value IPPM (IPPM/2) 1000 Uni-directional @VR 100 Bi-directional @VR 50 10/1000µs Waveform as defined by R.E.A 10 td 0 0 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 1.0 2.0 3.0 0 4.0 Figure 5. Steady State Power Dissipation Derating IFSM - Peak Forward Surve Current (A) 8 7 6 5 4 L= 0.375″(9.5mm) Lead Lengths 1 0 0 25 150 200 250 300 350 Surge Current Uni-Directional Only 9 2 100 Figure 6. Maximum Non-Repetitive Forward Curve 3 50 VBR-Reverse Breakdown Voltage (V) t-Time (ms) PM(AV), Steady State Power Dissipation (W) 25 TA-Ambient Temperature (℃) Cj (pF) IPPM - Peak Pulse Current, %IRSM 50 0 TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 75 1000 Figure 3. Pulse Waveform 150 100 50 75 100 125 150 TL-Lead Temperature (℃) Revision:TVS-15KPA SERIES-001(A2) 175 200 450 400 350 300 250 200 150 100 50 0 1 10 100 Number of Cycles at 60Hz 4/6 http://brightking.yageo.com 15KPA SERIES Recommended Soldering Conditions Wave Soldering 300 Preheating Soldering Cooling Maximum Wave 265℃ Temperature (℃) 250 200 150 100 50 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Time (minutes) Item Conditions Peak Temperature 265℃ Dipping Time 10 seconds Soldering 1 time Marking Code Cathode Band YXXX YXXX Logo 15KPA17A Intermal Control Code Logo 15KPA17CA Intermal Control Code Marking Code Marking Code Part Number Code 15KPA XXX C A / XXXX Package Code B: Box package TR13: Reel package 5% VBR Voltage Tolerance Bidirectional VRWM Voltage Series Code Revision:TVS-15KPA SERIES-001(A2) 5/6 http://brightking.yageo.com 15KPA SERIES Ordering Code for Different Package Box package: Add suffix “/B” at the end of the part number, such as 15KPAXXXCA/B Reel package: Add suffix “/TR13” at the end of the part number, such as 15KPAXXXCA/TR13 Packaging Tape Z Dimension (mm) A 10.0±0.5 B 53.0±1.0 Z 1.2Max. T 6.0±0.4 E 0.8Max. L1-L2 1.0Max. L 250.0±5.0 W 75.0±5.0 H 114.0±5.0 ±5° A E Symbol L1 B L2 T E Box H L W Quantity: 300PCS Reel D0 D1 D Revision:TVS-15KPA SERIES-001(A2) W1 D 330.0±3.0 D0 16.4±2.0 D1 86.0±2.0 W1 76.0±3.0 Quantity: 800PCS 6/6 http://brightking.yageo.com
15KPA170CA/B 价格&库存
很抱歉,暂时无法提供与“15KPA170CA/B”相匹配的价格&库存,您可以联系我们找货
